Google Earth Engine ——高级星载热辐射和反射辐射计全球发射率数据库(ASTER-GED)地表温度数据集
此星光明 发表于 2022/04/15 23:18:15 2022/04/15
【摘要】 The Advanced Spaceborne Thermal Emission and Reflection Radiometer Global Emissivity Database (ASTER-GED) was developed by the National Aeronautics and Space Administrat...
The Advanced Spaceborne Thermal Emission and Reflection Radiometer Global Emissivity Database (ASTER-GED) was developed by the National Aeronautics and Space Administration's (NASA) Jet Propulsion Laboratory (JPL), California Institute of Technology. This product includes the mean emissivity and standard deviation for all 5 ASTER Thermal Infrared bands, mean land surface temperature (LST) and standard deviation, a re-sampled ASTER GDEM, land-water mask, mean Normalized Difference Vegetation Index (NDVI) and standard deviation, and observation count.
ASTER-GED land surface temperature and emissivity (LST&E) are generated using the ASTER Temperature Emissivity Separation (TES) algorithm in combination with a Water Vapor Scaling (WVS) atmospheric correction method using MODIS MOD07 atmospheric profiles and the MODTRAN 5.2 radiative transfer model.
This product was derived from clear-sky pixels for all available ASTER data (2000-2008).
[User's Guide] (https://lpdaac.usgs.gov/documents/120/ASTERGED_User_Guide_V3.pdf)
高级星载热辐射和反射辐射计全球发射率数据库(ASTER-GED)是由美国国家航空航天局(NASA)加州理工学院喷气推进实验室(JPL)开发。该产品包括所有5个ASTER热红外波段的平均发射率和标准差,平均陆地表面温度(LST)和标准差,重新采样的ASTER GDEM,陆地-水掩码,平均归一化植被指数(NDVI)和标准差,以及观测次数。
ASTER-GED地表温度和发射率(LST&E)是使用ASTER温度发射率分离(TES)算法,结合水汽缩放(WVS)大气校正方法,使用MODIS MOD07大气剖面和MODTRAN 5.2辐射传输模型生成。
这个产品是由所有可用的ASTER数据(2000-2008)的晴空像素得出的。
[用户指南] (https://lpdaac.usgs.gov/documents/120/ASTERGED_User_Guide_V3.pdf)
Dataset Availability
2000-01-01T00:00:00 - 2008-12-31T00:00:00
Dataset Provider
NASA LP DAAC at the USGS EROS Center
Collection Snippet
ee.Image("NASA/ASTER_GED/AG100_003")
Resolution
100 meters
Bands Table
Name Description Min Max Units Scale
emissivity_band10 Mean band 10 0 1000 0.001
emissivity_band11 Mean band 11 0 1000 0.001
emissivity_band12 Mean band 12 0 1000 0.001
emissivity_band13 Mean band 13 0 1000 0.001
emissivity_band14 Mean band 14 0 1000 0.001
emissivity_sdev_band10 Standard deviation band 10 -1000 1000 0.0001
emissivity_sdev_band11 Standard deviation band 11 -1000 1000 0.0001
emissivity_sdev_band12 Standard deviation band 12 -1000 1000 0.0001
emissivity_sdev_band13 Standard deviation band 13 -1000 1000 0.0001
emissivity_sdev_band14 Standard deviation band 14 -1000 1000 0.0001
temperature Temperature mean 0 65535 K 0.01
temperature_sdev Temperature standard deviation 0 65535 K 0.01
ndvi NDVI mean 0 100 0.01
ndvi_sdev NDVI standard deviation 0 100 0.01
elevation ASTER Global Digital Elevation Model V002 -500 9000 Meters 0
land_water_map Land water map 0
num_obs Number of observations Number per pixel 0
* = Values are estimated
Class Table: land_water_map
Value Color Color Value Description
1 #brown Land
2 #blue Water
使用说明:
ASTER data and products distributed by the LP DAAC, with the exception of the ASTER Global Digital Elevation Model (GDEM) dataset (ASTGTM) version 2 (v2), have no restrictions on data use, sale, or subsequent redistribution. For more information visit the [ASTER Policies] (LP DAAC - Data Citation and Policies) site.
引用:
Please visit LP DAAC 'Citing Our Data' page for information on citing LP DAAC datasets.https://doi.org/10.5067/COMMUNITY/ASTER_GED/AG100.003
代码:
  1. var dataset = ee.Image('NASA/ASTER_GED/AG100_003');
  2. var elevation = dataset.select('elevation');
  3. var elevationVis = {
  4. min: -15.0,
  5. max: 5000.0,
  6. palette: [
  7. '0602ff', '235cb1', '307ef3', '269db1', '30c8e2', '32d3ef', '3ae237',
  8. 'b5e22e', 'd6e21f', 'fff705', 'ffd611', 'ffb613', 'ff8b13', 'ff6e08',
  9. 'ff500d', 'ff0000', 'de0101', 'c21301'
  10. ],
  11. };
  12. Map.setCenter(89.12, 37.72, 3);
  13. Map.addLayer(elevation, elevationVis, 'Elevation');
文章来源: blog.csdn.net,作者:此星光明2021年博客之星云计算Top3,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_31988139/article/details/120485943
