Google Earth Engine(GEE)—Julia Landsat 8 去云案例
此星光明 发表于 2022/04/15 23:54:35 2022/04/15
【摘要】 代码 using EarthEngineInitialize() # 这里的去云波段和之前的sr去云没有什么区别#Function to cloud mask from the pixel_qa band of Landsat 8 SR data.function maskL8sr(image) image = EE.Image...
代码
  1. using EarthEngine
  2. Initialize()
  3. # 这里的去云波段和之前的sr去云没有什么区别
  4. #Function to cloud mask from the pixel_qa band of Landsat 8 SR data.
  5. function maskL8sr(image)
  6. image = EE.Image(image) # cast to make sure we have the correct type
  7. # Bits 3 and 5 are cloud shadow and cloud, respectively.
  8. cloudShadowBitMask = 1 << 3
  9. cloudsBitMask = 1 << 5
  10. # G
文章来源: blog.csdn.net,作者:此星光明2021年博客之星云计算Top3,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_31988139/article/details/120013397
