算法搬运之归并排序
DreamLife 发表于 2022/04/15 22:20:17 2022/04/15
【摘要】 原文连接:http://www.cnblogs.com/Braveliu/archive/2013/01/14/2860456.html #include<iostream> using n...
#include<iostream>
using namespace std;
//将有序数组ar[]和br[]合并到cr[]中
void MemeryArray(int a[], int n, int b[], int m, int c[])
    int i, j, k;
    i = j = k = 0;
    while (i < n && j < m)
        if (a[i] < b[j])
            c[k++] = a[i++];
        else
            c[k++] = b[j++];
    while (i < n)
        c[k++] = a[i++];
    while (j < m)
        c[k++] = b[j++];
void  PrintArr(int ar[],int n)
    for(int i = 0; i < n; ++i)
        cout<<ar[i]<<" ";
    cout<<endl;
void main()
    int ar[5] = {12, 23, 34, 45, 56};
    int br[5] = {13, 24, 35, 46, 60};
    int cr[10];
    cout<<"数组ar为:"<<endl;
    PrintArr(ar, 5);
    cout<<"数组br为:"<<endl;
    PrintArr(ar, 5);
    MemeryArray(ar, 5, br, 5, cr);
    cout<<"合并后结果为:"<<endl;
    PrintArr(cr, 10);
数组ar为:
12 23 34 45 56
数组br为:
12 23 34 45 56
合并后结果为:
12 13 23 24 34 35 45 46 56 60
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
#include<iostream>
#define  MAXSIZE  10
//将两个有序数列a[first...mid] 和 a[mid...last] 合并。
void mergearray(int a[], int first, int mid, int last, int temp[])
    int i = first, j = mid + 1;
    int m = mid, n = last;
    int k = 0;
    while (i <= m && j <= n)
        if (a[i] <= a[j])
            temp[k++] = a[i++];
        else
            temp[k++] = a[j++];
    while (i <= m)
        temp[k++] = a[i++];
    while (j <= n)
        temp[k++] = a[j++];
    for (i = 0; i < k; ++i)
        a[first + i] = temp[i];
void mergesort(int a[], int first, int last, int temp[])
    if (first < last)
        int mid = (first + last) / 2;
        mergesort(a, first, mid, temp);     //左边有序
        mergesort(a, mid + 1, last, temp);  //右边有序
        mergearray(a, first, mid, last, temp); //再将两个有序数列合并
bool MergeSort(int a[], int n)
    int *p = new int[n];
    if (p == NULL)
        return false;
    mergesort(a, 0, n - 1, p);
    delete[] p;
    return true;
        cout<<ar[i]<<" ";
    cout<<endl;
void main()
    int ar[MAXSIZE] = {23, 34, 45, 78, 90, 12, 49, 92, 32, 19};
    PrintArr(ar, MAXSIZE);
    bool bValue = MergeSort(ar, MAXSIZE);
    if(!bValue)
        cout<<"MergeSort  Failed!! "<<endl;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
#include<iostream>
#include<malloc.h>
#define   MAXSIZE  10
        cout<<ar[i]<<" ";
    cout<<endl;
static void merge(int ar[], int low, int mid, int high)
    int i, k = 0;
    //申请空间,使其大小为两个已经排序序列之和,该空间用来存放合并后的序列
    int *temp = (int *)malloc((high - low + 1)*sizeof(int));
    int begin1 = low;
    int end1 = mid;
    int begin2 = mid + 1;
    int end2 = high;
    //比较两个元素,选择相对小的元素放入到合并空间,并移动指针到下一位置
    for (k = 0; begin1 <= end1 && begin2 <= end2;)
        if(ar[begin1] < ar[begin2])
            temp[k++] = ar[begin1++];
        else
            temp[k++] = ar[begin2++];
    while(begin1 <= end1)  //若第一个序列有剩余,直接拷贝出来粘到合并序列尾
    while(begin2 <= end2)  //若第二个序列有剩余,直接拷贝出来粘到合并序列尾
    for (i = 0;i < k; i++)   //将排序好的序列拷贝回数组中
        ar[low+i] = temp[i];
    free(temp);
void merge_sort(int ar[],int begin,int end)
    int mid = 0;
    if(begin < end)
        mid = (begin + end) / 2;
        merge_sort(ar, begin, mid);
        merge_sort(ar, mid + 1, end);
        merge(ar, begin, mid, end);
void  main()
    int  ar[] = {12, 14, 54, 5, 6, 3, 9, 8, 47, 89};
    merge_sort(ar, 0, MAXSIZE-1);
*3 5 6 8 9 12 14 47 54 89
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
这里写图片描述
文章来源: dreamlife.blog.csdn.net,作者:DreamLife.,版权归原作者所有,如需转载,请联系作者。
原文链接:dreamlife.blog.csdn.net/article/details/50969791
