使用Java Stream API将List按自定义分组规则转换成Map的一个例子
汪子熙 发表于 2022/04/15 18:17:10 2022/04/15
【摘要】 本文完整测试代码见文末。测试数据是List里的4个员工对象实例:根据员工所在的城市进行分组:结果分成了三组:第一组的员工在上海:第二组的员工在成都:统计每组员工个数:把员工进行分组,得分大于101分的在一组,小于等于101的在另一组:分组结果:package java8;import java.util.ArrayList;import java.util.List;import java....
本文完整测试代码见文末。
根据员工所在的城市进行分组:
结果分成了三组:
第一组的员工在上海:
第二组的员工在成都:
统计每组员工个数:
分组结果:
package java8;
import java.util.Map;
import java.util.Map.Entry;
import java.util.function.Consumer;
import java.util.stream.Collectors;
class Employee {
	private String city;
	private String name;
	private int score;
	public Employee(String name, String city, int score){
		this.city = city;
		this.name = name;
		this.score = score;
	public String getCity(){
		System.out.println("city: " + this.city);
		return this.city;
	public String getName() {
		return this.name;
	public int getScore() {
		return this.score;
	@Override
    public String toString() {
        return String.format("Employee: " + this.name + " city: " + this.city);
class Person {
    private int age;
    Person(String name, int age) {
        this.name = name;
        this.age = age;
    @Override
        return String.format("Person{name='%s', age=%d}", name, age);
// Jerry 2016-01-15 20:51PM ? 多用于extends generic的type,接受所有Object的sub class
public class StreamTest {
	private static void printMap(Map<? extends Object, ? extends Object> map) {
		 for(Entry<? extends Object, ? extends Object> entry:map.entrySet()) {
			    System.out.println("key = " + entry.getKey() + " , Value = " + entry.getValue());
		ArrayList<Employee> employees = new ArrayList<Employee>();
		employees.add(new Employee("A", "Shanghai",100));
		employees.add(new Employee("B", "Chengdu",101));
		employees.add(new Employee("C", "Shenzhen",102));
		employees.add(new Employee("D", "Chengdu",104));
		// group by City
		Map<String, List<Employee>> employeesByCity =
				employees.stream().collect( Collectors.groupingBy(Employee::getCity));
		//  default void forEach(Consumer<? super T> action) {
		for(Map.Entry<String, List<Employee>> entry:employeesByCity.entrySet()) {
		    System.out.println("key= " + entry.getKey() + " , Value = " + entry.getValue());
		    entry.getValue().forEach(System.out::println);
		 // 2016-01-15 20:37PM
		 Consumer<Employee> aa = a -> { System.out.println("Employee: " + a.getName() + " : " +  a.getScore()); };
		 List<Employee> chengduEmployee = employeesByCity.get("Chengdu");
		 chengduEmployee.forEach(aa);
		 // test for counting
		 Map<String, Long> employeesByCity2 =
				 employees.stream().collect( Collectors.groupingBy(Employee::getCity, Collectors.counting()));
		 printMap(employeesByCity2);
		 // calculate average score
		 Map<String, Double> employeesByCity3 =
						 Collectors.averagingInt(Employee::getScore)));
		 printMap(employeesByCity3);
		/*Stream<Person> people = Stream.of(new Person("Paul", 24), new Person("Mark", 30), new Person("Will", 28));
		Map<Integer, List<String>> peopleByAge = people.collect(groupingBy(p -> p.age, mapping((Person p) -> p.name, toList())));
		System.out.println(peopleByAge);*/
		  * 分区是一种特殊的分组,结果 map 至少包含两个不同的分组——一个true,一个false。
		  * 例如,如果想找出最优秀的员工,你可以将所有雇员分为两组,一组销售量大于 N,
		  * 另一组小于 N,使用 partitioningBy 收集器:
		 System.out.println("partition result");
		 Map<Boolean, List<Employee>> partitioned =
				 employees.stream().collect(Collectors.partitioningBy(e -> e.getScore() > 101));
		 printMap(partitioned);
		  * 你也可以将 groupingBy 收集器传递给 partitioningBy 收集器来将联合使用分区和分组。例如,你可以统计每个分区中的每个城市的雇员人数:
		Map<Boolean, Map<String, Long>> result =
		employees.stream().collect(partitioningBy(e -> e.getNumSales() > 150,
		groupingBy(Employee::getCity, counting())));
		这样会生成一个二级 Map:
		{false={London=1}, true={New York=1, Hong Kong=1, London=1}}
