Qt&Vtk-014-CustomLinkView
【摘要】
这个Demo已经拖了好久好久了,今天整理文章的时候,发现躲不过了呀,前面的几篇都发出了。
文章目录
1 官方示例展示2 官方源码2.1CustomLinkView.h2.2 Custom...
1 官方示例展示
啊呀,今天终于更新到这里了,一直拖延症到现在,还是没有弄明白这个项目是干啥的。仅仅展示官方代码,在项目中建了对应的文件。不要给我寄刀片哈。
点击打开按钮,显示让我打开一个XML文档,实在搞不懂这个项目是干啥的。
2 官方源码
2.1CustomLinkView.h
#ifndef CustomLinkView_H
#define CustomLinkView_H
#include "vtkSmartPointer.h" // Required for smart pointer internal ivars.
#include <QMainWindow>
// Forward Qt class declarations
class Ui_CustomLinkView;
// Forward VTK class declarations
class vtkCommand;
class vtkEventQtSlotConnect;
class vtkGraphLayoutView;
class vtkObject;
class vtkQtTableView;
class vtkQtTreeView;
class vtkXMLTreeReader;
class CustomLinkView : public QMainWindow
Q_OBJECT
public:
// Constructor/Destructor
CustomLinkView();
~CustomLinkView() override;
public slots:
virtual void slotOpenXMLFile();
virtual void slotExit();
protected:
protected slots:
public slots:
// Qt signal (produced by vtkEventQtSlotConnect) will be connected to
// this slot.
// Full signature of the slot could be:
// MySlot(vtkObject* caller, unsigned long vtk_event,
// void* clientData, void* callData, vtkCommand*)
void selectionChanged(vtkObject*, unsigned long, void*, void* callData);
private:
// Methods
void SetupCustomLink();
// Members
vtkSmartPointer<vtkXMLTreeReader> XMLReader;
vtkSmartPointer<vtkGraphLayoutView> GraphView;
vtkSmartPointer<vtkQtTreeView> TreeView;
vtkSmartPointer<vtkQtTableView> TableView;
vtkSmartPointer<vtkQtTreeView> ColumnView;
// This class converts a vtkEvent to QT signal.
vtkSmartPointer<vtkEventQtSlotConnect> Connections;
// Designer form
Ui_CustomLinkView *ui;
#endif // CustomLinkView_H
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
- 27
- 28
- 29
- 30
- 31
- 32
- 33
- 34
- 35
- 36
- 37
- 38
- 39
- 40
- 41
- 42
- 43
- 44
- 45
- 46
- 47
- 48
- 49
- 50
- 51
- 52
- 53
- 54
- 55
- 56
- 57
- 58
- 59
- 60
- 61
- 62
- 63
- 64
- 65
- 66
- 67
2.2 CustomLinkView.cpp
#include "ui_CustomLinkView.h"
#include "CustomLinkView.h"
#include <vtkAnnotationLink.h>
#include <vtkCommand.h>
#include <vtkDataObjectToTable.h>
#include <vtkDataRepresentation.h>
#include <vtkEventQtSlotConnect.h>
#include "vtkGenericOpenGLRenderWindow.h"
#include <vtkGraphLayoutView.h>
#include <vtkQtTableView.h>
#include <vtkQtTreeView.h>
#include <vtkRenderer.h>
#include <vtkSelection.h>
#include <vtkSelectionNode.h>
#include <vtkTable.h>
#include <vtkTableToGraph.h>
#include <vtkTreeLayoutStrategy.h>
#include <vtkViewTheme.h>
#include <vtkViewUpdater.h>
#include <vtkXMLTreeReader.h>
#include <QDir>
#include <QFileDialog>
#include <QTreeView>
#define VTK_CREATE(type, name) \
vtkSmartPointer<type> name = vtkSmartPointer<type>::New()
// Constructor
CustomLinkView::CustomLinkView()
this->ui = new Ui_CustomLinkView;
this->ui->setupUi(this);
vtkNew<vtkGenericOpenGLRenderWindow> renderWindow;
this->ui->vtkGraphViewWidget->SetRenderWindow(renderWindow);
this->XMLReader = vtkSmartPointer<vtkXMLTreeReader>::New();
this->GraphView = vtkSmartPointer<vtkGraphLayoutView>::New();
this->TreeView = vtkSmartPointer<vtkQtTreeView>::New();
this->TableView = vtkSmartPointer<vtkQtTableView>::New();
this->ColumnView = vtkSmartPointer<vtkQtTreeView>::New();
this->ColumnView->SetUseColumnView(1);
// Tell the table view to sort selections that it receives (but does
// not initiate) to the top
this->TableView->SetSortSelectionToTop(true);
// Set widgets for the tree and table views
this->ui->treeFrame->layout()->addWidget(this->TreeView->GetWidget());
this->ui->tableFrame->layout()->addWidget(this->TableView->GetWidget());
this->ui->columnFrame->layout()->addWidget(this->ColumnView->GetWidget());
// Graph View needs to get my render window
this->GraphView->SetInteractor(
this->ui->vtkGraphViewWidget->GetInteractor());
this->GraphView->SetRenderWindow(
this->ui->vtkGraphViewWidget->GetRenderWindow());
// Set up the theme on the graph view :)
vtkViewTheme* theme = vtkViewTheme::CreateNeonTheme();
this->GraphView->ApplyViewTheme(theme);
theme->Delete();
// Set up action signals and slots
connect(this->ui->actionOpenXMLFile, SIGNAL(triggered()), this,
SLOT(slotOpenXMLFile()));
connect(this->ui->actionExit, SIGNAL(triggered()), this,
SLOT(slotExit()));
// Apply application stylesheet
QString css =
"* { font: bold italic 18px \"Calibri\"; color: midnightblue }";
css +=
"QTreeView { font: bold italic 16px \"Calibri\"; color: midnightblue }";
//qApp->setStyleSheet(css); // Seems to cause a bug on some systems
// But at least it's here as an example
this->GraphView->Render();
// Set up the annotation between the vtk and qt views
void CustomLinkView::SetupCustomLink()
this->TreeView->GetRepresentation()->SetSelectionType(
vtkSelectionNode::PEDIGREEIDS);
this->TableView->GetRepresentation()->SetSelectionType(
this->ColumnView->GetRepresentation()->SetSelectionType(
this->GraphView->GetRepresentation()->SetSelectionType(
this->GraphView->Update();
theme->Delete();
// Create vtkEventQtSlotConnect and make the connections.
Connections = vtkEventQtSlotConnect::New();
// Make the connection here.
// Requires vtkObject which generates the event of type
// vtkCommand::SelectionChangedEvent, pointer to object
// which has the given slot. vtkEvent of type SelectionChangedEvent
// from reach representation should invoke selectionChanged.
Connections->Connect(
this->GraphView->GetRepresentation(),
this,
SLOT(selectionChanged(vtkObject*, unsigned long, void*, void*)));
this->TreeView->GetRepresentation(),
this,
this->TableView->GetRepresentation(),
this,
this->ColumnView->GetRepresentation(),
this,
CustomLinkView::~CustomLinkView()
// Action to be taken upon graph file open
void CustomLinkView::slotOpenXMLFile()
// Browse for and open the file
QDir dir;
// Open the text data file
QString fileName = QFileDialog::getOpenFileName(
this,
"Select the text data file",
QDir::homePath(),
"XML Files (*.xml);;All Files (*.*)");
if (fileName.isNull())
cerr << "Could not open file" << endl;
return;
// Create XML reader
this->XMLReader->SetFileName( fileName.toLatin1() );
this->XMLReader->ReadTagNameOff();
this->XMLReader->Update();
// Set up some hard coded parameters for the graph view
this->GraphView->SetVertexLabelArrayName("id");
this->GraphView->VertexLabelVisibilityOn();
this->GraphView->SetVertexColorArrayName("VertexDegree");
this->GraphView->ColorVerticesOn();
this->GraphView->SetEdgeColorArrayName("edge id");
this->GraphView->ColorEdgesOn();
// Create a tree layout strategy
VTK_CREATE(vtkTreeLayoutStrategy, treeStrat);
treeStrat->RadialOn();
treeStrat->SetAngle(360);
treeStrat->SetLogSpacingValue(1);
this->GraphView->SetLayoutStrategy(treeStrat);
// Set the input to the graph view
this->GraphView->SetRepresentationFromInputConnection(
this->XMLReader->GetOutputPort());
// Okay now do an explicit reset camera so that
// the user doesn't have to move the mouse
// in the window to see the resulting graph
this->GraphView->ResetCamera();
// Now hand off tree to the tree view
this->TreeView->SetRepresentationFromInputConnection(
this->ColumnView->SetRepresentationFromInputConnection(
// Extract a table and give to table view
VTK_CREATE(vtkDataObjectToTable, toTable);
toTable->SetInputConnection(this->XMLReader->GetOutputPort());
toTable->SetFieldType(vtkDataObjectToTable::VERTEX_DATA);
this->TableView->SetRepresentationFromInputConnection(
toTable->GetOutputPort());
this->SetupCustomLink();
// Hide an unwanted column in the tree view.
this->TreeView->HideColumn(2);
// Turn on some colors.
this->TreeView->SetColorArrayName("vertex id");
this->TreeView->ColorByArrayOn();
// Update all the views
this->TreeView->Update();
this->TableView->Update();
this->ColumnView->Update();
// Force a render on the graph view
void CustomLinkView::slotExit()
qApp->exit();
// This defines the QT slot. They way it works is first get the vtkSelection,
// push it to the default vtkAnnotationLink associated with each
// vtkDataRepresentation of each view type and then call Update or
// Render (if it is a vtkRenderView) on each view.
void CustomLinkView::selectionChanged(vtkObject*,
unsigned long,
void* vtkNotUsed(clientData),
void* callData)
vtkSelection* selection = reinterpret_cast<vtkSelection*>(callData);
if(selection)
this->GraphView->GetRepresentation()->GetAnnotationLink()->
SetCurrentSelection(selection);
this->TreeView->GetRepresentation()->GetAnnotationLink()->
this->TableView->GetRepresentation()->GetAnnotationLink()->
this->ColumnView->GetRepresentation()->GetAnnotationLink()->
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
- 27
- 28
- 29
- 30
- 31
- 32
- 33
- 34
- 35
- 36
- 37
- 38
- 39
- 40
- 41
- 42
- 43
- 44
- 45
- 46
- 47
- 48
- 49
- 50
- 51
- 52
- 53
- 54
- 55
- 56
- 57
- 58
- 59
- 60
- 61
- 62
- 63
- 64
- 65
- 66
- 67
- 68
- 69
- 70
- 71
- 72
- 73
- 74
- 75
- 76
- 77
- 78
- 79
- 80
- 81
- 82
- 83
- 84
- 85
- 86
- 87
- 88
- 89
- 90
- 91
- 92
- 93
- 94
- 95
- 96
- 97
- 98
- 99
- 100
- 101
- 102
- 103
- 104
- 105
- 106
- 107
- 108
- 109
- 110
- 111
- 112
- 113
- 114
- 115
- 116
- 117
- 118
- 119
- 120
- 121
- 122
- 123
- 124
- 125
- 126
- 127
- 128
- 129
- 130
- 131
- 132
- 133
- 134
- 135
- 136
- 137
- 138
- 139
- 140
- 141
- 142
- 143
- 144
- 145
- 146
- 147
- 148
- 149
- 150
- 151
- 152
- 153
- 154
- 155
- 156
- 157
- 158
- 159
- 160
- 161
- 162
- 163
- 164
- 165
- 166
- 167
- 168
- 169
- 170
- 171
- 172
- 173
- 174
- 175
- 176
- 177
- 178
- 179
- 180
- 181
- 182
- 183
- 184
- 185
- 186
- 187
- 188
- 189
- 190
- 191
- 192
- 193
- 194
- 195
- 196
- 197
- 198
- 199
- 200
- 201
- 202
- 203
- 204
- 205
- 206
- 207
- 208
- 209
- 210
- 211
- 212
- 213
- 214
- 215
- 216
- 217
- 218
- 219
- 220
- 221
- 222
- 223
- 224
- 225
- 226
- 227
- 228
- 229
- 230
- 231
- 232
- 233
- 234
- 235
- 236
- 237
- 238
- 239
- 240
- 241
- 242
- 243
- 244
- 245
- 246
- 247
- 248
- 249
- 250
- 251
- 252
- 253
- 254
- 255
- 256
- 257
★ 源码 ★
源码分享一时爽,一直分享一直爽, 链接如下:
文章来源: dreamlife.blog.csdn.net,作者:DreamLife.,版权归原作者所有,如需转载,请联系作者。
原文链接:dreamlife.blog.csdn.net/article/details/119632280
cloudbbs@huaweicloud.com
