python xls文件转为csv
IM_STONE 发表于 2022/04/14 01:52:05 2022/04/14
【摘要】 # coding = utf-8 import os import pandas as pd import csv import sys from openpyxl import load_workboo...
# coding = utf-8
import os
import pandas as pd
import csv
import sys
from openpyxl import load_workbook
########转换成csv文件############
def xlsx_to_csv_pd(xls_file):
    try:
        data_xls = pd.read_excel(xls_file, index_col=0)
        csv_file = xls_file.split('.')[0]
        data_xls.to_csv(csv_file + '.csv', encoding='utf-8')
    except:
        print(xls_file," err")
def walkFile_dat(file):
    m_count=0
    for root, dirs, files in os.walk(file):
        for f in files:
            m = os.path.join(root, f)
            ss=os.path.splitext(m)
            a = os.path.basename(m)
            if ".xls" == ss[1]:
                m_count+=1
                print("-------------------------------:",m,m_count)
                #readsavebin(m)
                xlsx_to_csv_pd(m)
def main(dirname):
    walkFile_dat(dirname)
if __name__ == "__main__":
    print(sys.argv)
    #sys.exit()
    main(sys.argv[1])
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
文章来源: blog.csdn.net,作者:IM-STONE,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/doubleintfloat/article/details/124116543
