2022虎年烟花代码
川川菜鸟 发表于 2022/04/14 03:02:14 2022/04/14
【摘要】 一、演示效果 b站:虎年烟花演示 二、python代码 import pygame from math import * from pygame.locals import * import ra...
一、演示效果
b站:虎年烟花演示
二、python代码
import pygame
from math import *
import random
class firew:
    def __init__(self, pos, color, light, size, move):
        self.pos = list(pos)
        self.color = list(color)
        self.light = light
        self.size = size
        self.move = list(move)
    def force(self, force):
        self.move[0] += force[0]
        self.move[1] += force[1]
        self.move[0] *= force[2]
        self.move[1] *= force[2]
    def update(self):
        self.pos[0] += self.move[0]
        self.pos[1] += self.move[1]
    def render(self, fenster, glitter):
        glitter = (glitter and random.randint(40, 100)/100) or 1
        c = rund( mult(self.color, self.light*glitter) )
        rad = int(round(self.light* self.size))
        rad += rad < 1
        #print(c)
        pygame.draw.circle(fenster, c, rund(self.pos), rad)
def summon(fws, pos, pre_move = [0,0]):
    mix.stop()
    #anz = random.randint(30, 250)
    anz = random.randint(200, 350)
    r = random.randint(0, 255)
    g = random.randint(0, 255)
    b = random.randint(0, 255)
    for i in range(anz):
        ang = random.randint(0, 360)
        speed = random.randint(100, 1000) / 250
        move = (cos(radians(ang))*speed + pre_move[0],
                sin(radians(ang))*speed + pre_move[1])
        light = random.randint(60, 100)/100
        size = random.randint(100, 300)/100
        fws.append( firew(pos, (r,g,b), light, size, move) )
    # Sound abspielen
    l, r = ( 0.2 + 0.8*(ww-pos[0])/ww, 0.2 + 0.8*pos[0]/ww )
    mix.set_volume(l, r)
    mix.play(sound)
    return fws
def rund(liste):
    new = []
    for i in liste:
        new.append(int(round(i)))
    return new
def mult(color, multi):
    new = list(color)
    new[0] *= multi
    new[1] *= multi
    new[2] *= multi
    return new
pygame.init()
sound = pygame.mixer.Sound("firew.wav")
mix = pygame.mixer.Channel(0)
mix.set_volume(1, 1)
bg = (0, 0, 0)
ww, wh = (1200, 800)
fenster = pygame.display.set_mode((ww, wh))
#pygame.display.set_caption("[Leertaste] für Pause; [c] für automatisches Feuerwerk")
fws = [] # firework particles
rockets = []
force = [0, 0.02, 0.985]
max_counter = random.randint(0, 200)
counter = max_counter
auto  = True
pause = False
run = 1
clock = pygame.time.Clock()
while run:
    pygame.display.set_caption("[Spacebar] to pause; [c] disable automatic fireworks")
    counter -= (auto and not pause)
    if counter <= 0: # neues erstellen
        #pos = [random.randint(ww*1/4, ww*3/4), random.randint(wh*1/4, wh*3/5)]
        pos = [random.randint(ww*2/5, ww*3/5), wh]
        move = [random.randint(-100, 100)/100, -random.randint(800, 1500)/110]
        rockets.append( firew(pos, (255, 255, 255), 1, 2, move) )
        #fuse = random.randint(50, 150) # Zuendschnur
        fuse = random.randint(50, 80)
        rockets[-1].fuse = fuse
        #fws = summon(fws, pos)
        max_counter = random.randint(10, 100)
    for e in pygame.event.get():
        if e.type == QUIT:
            run = 0
        if e.type == KEYDOWN:
            if e.key == K_c:
                auto = not auto
            if e.key == K_SPACE:
                pause = not pause
            if e.key == K_v:
                fws = []; rockets = []
        if e.type == MOUSEBUTTONDOWN:
            fws = summon(fws, e.pos)
    fenster.fill(bg)
    dellist1 = []
    dellist2 = []
    for i, rocket in enumerate(rockets):
        if not pause:
            rocket.force(force)
            rocket.update()
        rocket.render(fenster, False)
        rocket.fuse -= not pause
        if rocket.fuse < 0:
            dellist1.append(i)
            # explosion erschaffen
            fws = summon(fws, rocket.pos, rocket.move)
    for i, f in enumerate(fws):
        if not pause:
            f.force(force)
            f.update()
        f.render(fenster, True and not pause)
        f.light -= (not pause) * random.randint(0, 150) / 7500
        if f.light < 0:
            dellist2.append(i)
    dellist1.reverse()
    dellist2.reverse()
    for d in dellist1:
        del rockets[d]
    for d in dellist2:
        del fws[d]
    pygame.display.update()
    clock.tick(80)
pygame.quit()
演示:
三、前端代码
效果:
四、完整源码
公众号:玩转大数据
回复:烟花
前端交流群:681606329
文章来源: chuanchuan.blog.csdn.net,作者:川川菜鸟,版权归原作者所有,如需转载,请联系作者。
原文链接:chuanchuan.blog.csdn.net/article/details/122686170
