yolov3训练误差可视化
小小谢先生 发表于 2022/04/14 00:32:32 2022/04/14
【摘要】 通过把yolov3训练出来的效果可视化: 可以用python可视化,也可以直接在代码里面用tensorboardX可视化。 import reimport pandas as pdfrom matplotlib import pyplot as plt def read_data(filename): # 1: 3983....
  1. import re
  2. import pandas as pd
  3. from matplotlib import pyplot as plt
  4. def read_data(filename):
  5. # 1: 3983.445801, 3983.445801 avg loss, 0.000000 rate, 8.518392 seconds, 128 images
  6. pattern = re.compile("^\\s*(\\d+):.*?, (.*?) avg loss")
  7. lines = None
  8. with open(filename) as r:
  9. lines = r.readlines()
  10. data = [pattern.findall(line)[0] for line in lines]
  11. data = [(int(row[0]), float(row[1])) for row in data]
  12. return pd.DataFrame(data, columns=['epoch', 'loss'])
  13. def show(filename, n=1):
  14. """
  15. 可视化yolov3训练loss
  16. :param filename 文件名
  17. :param n 设置若干个epoch的loss合并到一起,在相同区间内取最小值
  18. """
  19. df = read_data(filename)
  20. loss_min = min(df.loss)
  21. print("Loss最小值:", loss_min)
  22. print("对应epoch:", list(df.epoch[df.loss == loss_min]))
  23. epochs = max(df.epoch)
  24. y = [min(df.loss[(i*n < df.epoch) & (df.epoch <= (i+1)*n)])
  25. for i in range(epochs//n)]
  26. plt.title("Yolov3 train loss")
  27. plt.xlabel("Epoch")
  28. plt.ylabel("loss")
  29. plt.plot([(i+1)*n for i in range(epochs//n)], y)
  30. plt.show()
  31. if __name__ == '__main__':
  32. import fire
  33. fire.Fire(show)
参考链接:https://github.com/IBBD/IBBD.github.io/blob/b4848c548d1e9d56eb213e83f78da0d396c6b89e/machine-learning/yolov3-train-model.md
文章来源: blog.csdn.net,作者:小小谢先生,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/xiewenrui1996/article/details/109278444
