Google Earth Engine ——数据全解析专辑(ASTER L1T Radiance)
此星光明 发表于 2022/04/14 01:30:40 2022/04/14
【摘要】 The Advanced Spaceborne Thermal Emission and Reflection Radiometer (ASTER) is a multispectral imager that was launched on board NASA's Terra spacecraft in December, 1999...
The Advanced Spaceborne Thermal Emission and Reflection Radiometer (ASTER) is a multispectral imager that was launched on board NASA's Terra spacecraft in December, 1999. ASTER can collect data in 14 spectral bands from the visible to the thermal infrared. Each scene covers an area of 60 x 60 km. These scenes, produced by the USGS, contain calibrated at-sensor radiance, ortho-rectified and terrain corrected.
Not all 14 bands were collected in each scene. An asset property named ORIGINAL_BANDS_PRESENT contains the list of bands that are present in each scene.
To convert from Digital Numbers (DN) to radiance at the sensor, the unit conversion coefficients are available in the metadata. See ASTER L1T Product Users' Guide and ASTER L1T Product Specification for more information.
先进的星载热发射和反射辐射计 (ASTER) 是一种多光谱成像仪,于 1999 年 12 月在 NASA 的 Terra 航天器上发射。ASTER 可以收集从可见光到热红外的 14 个光谱波段的数据。每个场景的面积为 60 x 60 公里。这些场景由 USGS 制作,包含校准的传感器辐射、正射校正和地形校正。
并非每个场景中都收集了所有 14 个波段。名为 ORIGINAL_BANDS_PRESENT 的资产属性包含每个场景中存在的波段列表。
为了在传感器处从数字数 (DN) 转换为辐射,元数据中提供了单位转换系数。有关更多信息,请参阅 ASTER L1T 产品用户指南和 ASTER L1T 产品规格。
文档:
算法理论基础文件 (ATBD)
用户指导
ASTER Level-1T 产品规格
[ASTER L1T 快速参考指南](ASTER L1T 快速参考指南)](https://lpdaac.usgs.gov/documents/174/AST_L1T_Quick_Reference_Guide.pdf)
Documentation:
Dataset Availability
2000-03-04T00:00:00 - 2021-08-31T00:00:00
Dataset Provider
NASA LP DAAC at the USGS EROS Center
Collection Snippet
ee.ImageCollection("ASTER/AST_L1T_003")
Bands Table
Name Description Min Max Resolution Wavelength
B01 VNIR_Band1 (visible green/yellow) 1 255 15 meters 0.520-0.600µm
B02 VNIR_Band2 (visible red) 1 255 15 meters 0.630-0.690µm
B3N VNIR_Band3N (near infrared, nadir pointing) 1 255 15 meters 0.780-0.860µm
B04 SWIR_Band4 (short-wave infrared) 1 255 30 meters 1.600-1.700µm
B05 SWIR_Band5 (short-wave infrared) 1 255 30 meters 2.145-2.185µm
B06 SWIR_Band6 (short-wave infrared) 1 255 30 meters 2.185-2.225µm
B07 SWIR_Band7 (short-wave infrared) 1 255 30 meters 2.235-2.285µm
B08 SWIR_Band8 (short-wave infrared) 1 255 30 meters 2.295-2.365µm
B09 SWIR_Band9 (short-wave infrared) 1 255 30 meters 2.360-2.430µm
B10 TIR_Band10 (thermal infrared) 1 4095 90 meters 8.125-8.475µm
B11 TIR_Band11 (thermal infrared) 1 4095 90 meters 8.475-8.825µm
B12 TIR_Band12 (thermal infrared) 1 4095 90 meters 8.925-9.275µm
B13 TIR_Band13 (thermal infrared) 1 4095 90 meters 10.250-10.950µm
B14 TIR_Band14 (thermal infrared) 1 4095 90 meters 10.950-11.650µm
影像属性:
Name Type Description
BAD_PIXELS_B01 Double Number of bad pixels
BAD_PIXELS_B02 Double Number of bad pixels
BAD_PIXELS_B03 Double Number of bad pixels
BAD_PIXELS_B04 Double Number of bad pixels
BAD_PIXELS_B05 Double Number of bad pixels
BAD_PIXELS_B06 Double Number of bad pixels
BAD_PIXELS_B07 Double Number of bad pixels
BAD_PIXELS_B08 Double Number of bad pixels
BAD_PIXELS_B09 Double Number of bad pixels
BAD_PIXELS_B10 Double Number of bad pixels
BAD_PIXELS_B11 Double Number of bad pixels
BAD_PIXELS_B12 Double Number of bad pixels
BAD_PIXELS_B13 Double Number of bad pixels
BAD_PIXELS_B14 Double Number of bad pixels
CLOUDCOVER Double Cloud coverage
COARSE_DEM_DATE String Coarse DEM issuance date
COARSE_DEM_NOTE String Coarse DEM comments
COARSE_DEM_VERSION String Coarse DEM version number
FLYING_DIRECTION String The satellite flight direction when observation is done: 'AS' - ascending direction, 'DE' - descending direction
GAIN_COEFFICIENT_B01 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B02 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B03 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B04 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B05 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B06 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B07 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B08 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B09 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B10 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B11 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B12 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B13 Double Coefficient used for radiance conversion
GAIN_COEFFICIENT_B14 Double Coefficient used for radiance conversion
GAIN_SETTING_B01 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B02 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B03 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B04 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B05 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B06 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B07 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B08 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B09 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B10 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B11 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B12 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B13 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GAIN_SETTING_B14 String Band gain setting: 'HGH' - high, 'NOR' - normal, 'LOW' - low, 'LO1' - low 1, or 'LO2' - low 2
GCP_CHIPS_CORRELATED Double How many chips correlated during correlation statistics creation
GEOMETRIC_DB_DATE String Geometric correction data issuance date
GEOMETRIC_DB_VERSION String Geometric correction data version number
GRANULE_REPROCESSING String What reprocessing has been performed on the granule: 'not reprocessed', 'reprocessed once', 'reprocessed twice', or 'reprocessing n times'
ORBIT_NUMBER Double The orbit number of the satellite when data is acquired
ORIGINAL_BANDS_PRESENT Double List of bands that are present in each scene
PGE_VERSION String The version of PGE
PRODUCTION_TIME Double Generation time of this product
QA_PERCENT_INTERPOLATED_DATA Double The percentage of interpolated data in the scene
QA_PERCENT_MISSING_DATA Double The percentage of missing data in the scene
QA_PERCENT_OUT_OF_BOUNDS_DATA Double The percentage of out of bounds data in the scene
RADIOMETRIC_DB_DATE String Radiometric correction data issuance date
RADIOMETRIC_DB_VERSION String Radiometric correction data version number
RESAMPLING_METHOD_B01 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B02 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B03 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B04 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B05 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B06 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B07 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B08 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B09 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B10 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B11 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B12 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B13 String Resampling method: 'BL', 'NN', or 'CC'
RESAMPLING_METHOD_B14 String Resampling method: 'BL', 'NN', or 'CC'
SATELLITE_RECURRENT_CYCLENUMBER Double The satellite recurrent cycle number
SATELLITE_REVOLUTION_NUMBER Double The satellite revolution number in the cycle
SCENE_PATH Double Scene path
SCENE_ROW Double Scene row
SCENE_VIEW Double Scene view
SOLAR_AZIMUTH Double Sun direction as seen from the scene center; azimuth angle in degrees measured eastward from North (0.0<az<360)
SOLAR_ELEVATION Double Sun direction as seen from the scene center; elevation angle in degrees (-90.0<el<90.0)
SOURCE_DATA_GRANULE String ID of input AST_L1A data granule used for generating this product
SWIR_POINTING_ANGLE Double Pointing angle in degrees
TIR_POINTING_ANGLE Double Pointing angle in degrees
VNIR_POINTING_ANGLE Double Pointing angle in degrees
 代码:
  1. var dataset = ee.ImageCollection('ASTER/AST_L1T_003')
  2. .filter(ee.Filter.date('2018-01-01', '2018-08-15'));
  3. var falseColor = dataset.select(['B3N', 'B02', 'B01']);
  4. var falseColorVis = {
  5. min: 0.0,
  6. max: 255.0,
  7. };
  8. Map.setCenter(-122.0272, 39.6734, 11);
  9. Map.addLayer(falseColor.median(), falseColorVis, 'False Color');
 这个影像是覆盖全球的!
文章来源: blog.csdn.net,作者:此星光明2021年博客之星云计算Top3,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_31988139/article/details/120115798
