Google Earth Engine(GEE)——将城区、森林区和水域实现光谱分离!
此星光明 发表于 2022/04/14 00:02:18 2022/04/14
【摘要】 光谱分离是在地球引擎中实现的image.unmix()方法。以下是将 Landsat 5 与预先确定的城市、植被和水端元混合的示例: unmix(endmembers, sumToOne, nonNegative) Unmix each pixel with the given endmembers, by co...
Unmix each pixel with the given endmembers, by computing the pseudo-inverse and multiplying it through each pixel. Returns an image of doubles with the same number of bands as endmembers.
通过计算伪逆并将其乘以每个像素,将每个像素与给定的端元分开。返回具有与末端成员相同数量的带图像。
Arguments:
this:image (Image):
The input image.
endmembers (List):
The endmembers to unmix with.
sumToOne (Boolean, default: false):
Constrain the outputs to sum to one.
nonNegative (Boolean, default: false):
Constrain the outputs to be non-negative.
Returns: Image
 直接上代码:
  1. // 加载影像并且选择波段,之后选择位置显示中心和加载影像
  2. var bands = ['B1', 'B2', 'B3', 'B4', 'B5', 'B6', 'B7'];
  3. var image = ee.Image('LANDSAT/LT05/C01/T1/LT05_044034_20080214')
  4. .select(bands);
  5. Map.setCenter(-122.1899, 37.5010, 10);
  6. Map.addLayer(image, {bands: ['B4', 'B3', 'B2'], min: 0, max: 128}, 'image');
  7. // 定义光谱端元,这个参数具体要看更加详细的光谱内容
  8. var urban = [88, 42, 48, 38, 86, 115, 59];
  9. var veg = [50, 21, 20, 35, 50, 110, 23];
  10. var water = [51, 20, 14, 9, 7, 116, 4];
  11. // 取消混合,这样就进行了分解
  12. var fractions = image.unmix([urban, veg, water]);
  13. Map.addLayer(fractions, {}, 'unmixed');
文章来源: blog.csdn.net,作者:此星光明2021年博客之星云计算Top3,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_31988139/article/details/119302820
