干货|app自动化测试之Appium问题分析及定位
霍格沃兹测试学社 发表于 2022/04/10 17:22:09 2022/04/10
【摘要】 使用 Appium 进行测试时,会产生大量日志,一旦运行过程中遇到报错,可以通过 Appium 服务端的日志以及客户端的日志分析排查问题。 Appium Server日志-开启服务通过命令行的方式启动 Appium Server,下面来分析一下启动日志,日志第一行显示了 Appium 版本信息和服务在本地的运行地址。$ appium -g appium.log[Appium] Welcome...
[Appium] Welcome to Appium v1.8.0-beta3 (REV \
  40e40975ebd3593d08c3f83de2546258f7ddf11d)
  [Appium] Appium REST http interface listener started \
    on 0.0.0.0:4723
    如果启动 Appium 服务时添加了参数,会在启动日志中展示,比如添加了 defaultCapabilities,启动日志也会显示出来。
    Hogwarts $ appium --log-timestamp --log-no-colors --no-reset
    2021-04-29 10:11:58:545 - [Appium] Welcome to Appium v1.17.0
    2021-04-29 10:11:58:547 - [Appium] Non-default server args:
    2021-04-29 10:11:58:547 - [Appium]   logTimestamp: true
    2021-04-29 10:11:58:547 - [Appium]   logNoColors: true
    2021-04-29 10:11:58:547 - [Appium]   noReset: true
    2021-04-29 10:11:58:548 - [Appium] Deprecated server args:
    2021-04-29 10:11:58:548 - [Appium]   --no-reset => --default-capabilities '{"noReset":true}'
    2021-04-29 10:11:58:548 - [Appium] Default capabilities, which will be added to each request unless overridden by desired capabilities:
    2021-04-29 10:11:58:548 - [Appium]   noReset: true
    2021-04-29 10:11:58:567 - [Appium] Appium REST http interface listener started on 0.0.0.0:4723
    - Appium 参数:http://appium.io/docs/en/writing-running-appium/server-args/
    - defaultCapabilities 详见:http://appium.io/docs/en/writing-running-appium/default-capabilities-arg/
    ## 运行时的Session日志
    自动化测试运行起来之后,Appium Server 的日志提供了一些基本的 Session 信息,特别是 desired capabilities 的配置信息。应该时刻注意 Appium 服务是否正确接收了请求内容。
    [debug] [BaseDriver] Creating session with W3C capabilities: {
    [debug] [BaseDriver]   "alwaysMatch": {
    [debug] [BaseDriver]     "platformName": "android",
    [debug] [BaseDriver]     "appium:appActivity": ".view.WelcomeActivityAlias",
    [debug] [BaseDriver]     "appium:appPackage": "com.xueqiu.android",
    [debug] [BaseDriver]     "appium:automationName": "UiAutomator2",
    [debug] [BaseDriver]     "appium:deviceName": "emulator-5554",
    [debug] [BaseDriver]     "appium:noReset": "true",
    [debug] [BaseDriver]     "appium:udid": "emulator-5554"
    [debug] [BaseDriver]   },
    上面的日志创建了一个 Session,设置了 Capabilities 参数,以 JSON 格式告诉 AppiumServer 被测试设备的一些重要信息。
    ## Appium GET 请求的日志
    Appium 是一个 REST 服务,接收 HTTP 请求,返回结果。Appium 服务端日志用 [HTTP] --> 和 [HTTP] <--展示了请求和返回的信息。
    [HTTP] --> GET /wd/hub/status {}
    [debug] [MJSONWP] Calling AppiumDriver.getStatus() with args: []
    [debug] [MJSONWP] Responding to client with driver.getStatus()\
     result: {"build":{"version":"1.8.0-beta3","revision":"30e7b45bdc5668124af33c41492aa5195fcdf64d"}}
     [HTTP] <-- GET /wd/hub/status 200 121 ms - 126
     “-->”代表发出 HTTP 请求,“<--”代表响应,中间是指令细节。[MJSONWP] 指使用 MJSONWP(Mobile JSON Wire Protocol 协议),调用 AppiumDriver.getStatus( )这个方法(无参),返回给客户端 result 信息,整个过程耗时 121 毫秒,传输了 126 个字节。
     ## 通过日志进行错误排查
     利用日志可以非常容易的排查和定位问题,问题通常发生在 automation Session 之后,如果 Session 持续存在,错误也可能发生。
     [HTTP] --> POST /wd/hub/session
     [debug] [ADB] 1 device(s) connected
     [debug] [ADB] Running '/home/user/Android/Sdk/platform-tools//adb' \
     with args: ["-P",5037,"-s","ec8c4df","shell","am","force-stop",\
     "io.appium.unlock"]
     [debug] [AndroidDriver] Not cleaning generated files. Add \
     `clearSystemFiles` capability if wanted.
     [MJSONWP] Encountered internal error running command: Error: \
     Cannot stop and clear com.company.app. Original error: Error \
     executing adbExec. Original error: 'Command '/home/user/Android\
     /Sdk/platform-tools//adb -P 5037 -s ec8c4df shell pm clear com.\
     company.app' exited with code 1'; Stderr: 'Error: java.lang.SecurityException:\
      PID 22126 does not have permission android.permission.CLEAR_APP_USER_DATA to \
       clear data of package com.company.app'; Code: '1'
       at Object.wrappedLogger.errorAndThrow (../../lib/logging.js:63:13)
       at ADB.callee$0$0$ (../../../lib/tools/adb-commands.js:334:9)
       at tryCatch (/home/linuxbrew/.linuxbrew/lib/node_modules/appium/node_modules\
       /babel-runtime/regenerator/runtime.js:67:40)
       at GeneratorFunctionPrototype.invoke [as _invoke] (/home/linuxbrew/.\
       linuxbrew/lib/node_modules/appium/node_modules/babel-runtime/regenerator\
       /runtime.js:315:22)
       [HTTP] <-- POST /wd/hub/session 500 40811 ms - 557
       Appium Driver 启动 Session ,清理 com.company.app 时发生错误。这个错误让我们知道两件事:“Appium 正在尝试做什么”,“哪里出错了”。
       在这个例子中,Appium 尝试运行 adb 命令(adb shell am force-stop),adb 参数在错误信息中也有显示。发生了 Android 系统权限错误。此时,可以手动运行这个 adb 命令,查看错误是否可以重现。如果错误重现,可以通过错误类型定位问题。
       这个例子只是众多错误中的一个,但它说明至关重要的一点,当错误发生时,日志可以提供更多的信息,如果没有完整的日志信息,对 Appium 排错难上加难。
       ## 改变日志输出的参数
       下面的参数可以改变 Appium 服务端的日志行为:
       --log-level:改变 Appium 日志显示级别。Appium 默认展示所有日志
       ,它有以下一些选项:'info', 'info:debug', 'info:info', 'info:warn', 'info:error', ...
       --log-no-colors:关闭颜色,如果日志是彩色的,可能会出现奇怪的字符,比如"TODO: find the color",你可以用这个参数关闭颜色。
       --log-timestamp:在日志前添加时间戳
       展示如下:
       2018-03-15 13:17:58:663 - [Appium] Welcome to Appium v1.8.0-beta3 (REV 30e7b45bdc5668124af33c41492aa5195fcdf64d)
       2018-03-15 13:17:58:664 - [Appium] Non-default server args:
       2018-03-15 13:17:58:665 - [Appium] logTimestamp: true
       2018-03-15 13:17:58:732 - [Appium] Appium REST http interface listener started on 0.0.0.0:4723
       内容全面升级,4 个月 20+ 项目实战强化训练,资深测试架构师、开源项目作者亲授 BAT 大厂前沿最佳实践,带你一站式掌握测试开发必备核心技能(对标阿里P6+,年薪50W+)!直推 BAT 名企测试经理,普遍涨薪 50%+!
       ⬇️ 点击“阅读原文”,提升测试核心竞争力!
       [原文链接](https://mp.weixin.qq.com/s?__biz=MzU3NDM4ODEzMg==&mid=2247497874&idx=1&sn=68b58b1dcd7bdbe7fd78529b1a190c84&chksm=fd319a59ca46134f765ac83105ee37bf1abbb2c85566b7b0acf50f9c70e045b2d849dbfb72ee#rd)
       获取更多内容:https://qrcode.testing-studio.com/f?from=hwyun&url=https://ceshiren.com/t/topic/16586
       [点击查看](https://qrcode.testing-studio.com/f?from=hwyun&url=https://ceshiren.com/t/topic/16586)
