iOS自动化真机测试验证环境过程中常见问题解析
ceshiren 发表于 2022/04/02 14:48:02 2022/04/02
【摘要】 本章节主要讲解 iOS 自动化真机配置以及在 iOS 真机执行自动化时常见问题与解决方法。 真机使用的Capability与模拟器不同,真机测试需要如下的 Capability方式一:设置 App 路径,启动 App(自动安装 App){ "app": "/Users/seveniruby/Library/Developer/Xcode/DerivedData/UICatalog-ftyz...
真机使用的Capability
  "app": "/Users/seveniruby/Library/Developer/Xcode/DerivedData/UICatalog-ftyzdbgapjmxxobezrnrxsshpdqh/Build/Products/Debug-iphoneos/UICatalog.app",
    "automationName": "XCUITest",
      "platformName": "ios",
        "xcodeOrgId": "xxxxxx",
          "xcodeSigningId": "iPhone Developer",
            "udid": "9df22446af15919c494c85b4c1c8b00eaa3a5bd0"
方式二:根据 App 包名启动 App
                "bundleId": "com.example.apple-samplecode.UICatalog",
                    "deviceName": "iPhone",
                      "udid": "auto",
                        "xcodeOrgId": "xxxxx",
使用Appium Desktop验证环境
以上步骤完成后,出现下图表示真机环境配置成功
常见问题
问题一
问题二
问题三
  • 解决方法:重启手机或者拔掉 IOS 数据线,重新连接电脑
    问题四
                          note: Using new build system
                          note: Building targets in parallel
                          note: Planning build
                          note: Constructing build description
                          error: No signing certificate "iOS Development" found: No "iOS Development" signing certificate matching team ID "L62JHCGMQW" with a private key was found. (in target 'WebDriverAgentLib' from project 'WebDriverAgent')
                          error: No profiles for 'com.facebook.WebDriverAgentRunner.xctrunner' were found: Xcode couldn't find any iOS App Development provisioning profiles matching 'com.facebook.WebDriverAgentRunner.xctrunner'. Automatic signing is disabled and unable to generate a profile. To enable automatic signing, pass -allowProvisioningUpdates to xcodebuild. (in target 'WebDriverAgentRunner' from project 'WebDriverAgent')
问题五
                          Assertions: System: Early unexpected exit, operation never finished bootstrapping - no restart will be
                          attempted. (Underlying Error: The test runner exited with code 74 before checking in. If you believe this
                          error represents a bug, please attach the result bundle at
                          /Users/dzkair/Library/Developer/Xcode/DerivedData/WebDriverAgent-
                          alwvnomvwrdtzoaxbbkniqrpcdpp/Logs/Test/Test-WebDriverAgentRunner-2020.11.26_10-47-38-+0800.xcresult)
