SpringCloud微服务框架一套就够(下集)
摸鱼打酱油 发表于 2022/04/01 22:28:34 2022/04/01
【摘要】 个人简介作者是一个来自河源的大三在校生,以下笔记都是作者自学之路的一些浅薄经验,如有错误请指正,将来会不断的完善笔记,帮助更多的Java爱好者入门。@[toc] Spring Cloud Netflix 断路器springcloud Hystrix 服务降级在springcloud-02-comsumer-openFeign-dept80的Pom.xml<!-- Hystri...
个人简介
@[toc]
服务降级
<!--        Hystrix-->
          <dependency>
            <groupId>org.springframework.cloud</groupId>
            <artifactId>spring-cloud-starter-netflix-hystrix</artifactId>
        </dependency>
修改它的deptController
@RestController
public class deptController {
    @Autowired
    private deptService deptService;
    @HystrixCommand(fallbackMethod = "queryAllDept_Hystrix",commandProperties = {
            @HystrixProperty(name = "execution.isolation.thread.timeoutInMilliseconds",value = "1500") //添加超时服务降级
    @RequestMapping("/feign/queryAllDept")
    public List<dept> queryAllDept(String id){
        int i = Integer.parseInt(id);
        if(i<0){
            throw new RuntimeException(); //此处为了触发服务降级fallback
        return deptService.queryAllDept();
    //服务降级方法,这个方法直接从上面的正常方法复制过来,把名字修改一下即可,参数类型也和正常的方法要一致
    public List<dept> queryAllDept_Hystrix(String id){
        List<dept> depts = deptService.queryAllDept();
        depts.add(new dept("1000","Hystrix_fallback"));
        return depts;
主启动类
@SpringBootApplication
@EnableFeignClients
@EnableHystrix //开启Hystrix功能
public class springApplicationFeign80 {
        SpringApplication.run(springApplicationFeign80.class,args);
commandProperties支持什么参数属性
我们全局搜索HystrixCommandProperties,往下翻可以看到如下
protected HystrixCommandProperties(HystrixCommandKey key, HystrixCommandProperties.Setter builder, String propertyPrefix) {
        this.key = key;
        this.circuitBreakerEnabled = getProperty(propertyPrefix, key, "circuitBreaker.enabled", builder.getCircuitBreakerEnabled(), default_circuitBreakerEnabled);
        this.circuitBreakerRequestVolumeThreshold = getProperty(propertyPrefix, key, "circuitBreaker.requestVolumeThreshold", builder.getCircuitBreakerRequestVolumeThreshold(), default_circuitBreakerRequestVolumeThreshold);
        this.circuitBreakerSleepWindowInMilliseconds = getProperty(propertyPrefix, key, "circuitBreaker.sleepWindowInMilliseconds", builder.getCircuitBreakerSleepWindowInMilliseconds(), default_circuitBreakerSleepWindowInMilliseconds);
        this.circuitBreakerErrorThresholdPercentage = getProperty(propertyPrefix, key, "circuitBreaker.errorThresholdPercentage", builder.getCircuitBreakerErrorThresholdPercentage(), default_circuitBreakerErrorThresholdPercentage);
        this.circuitBreakerForceOpen = getProperty(propertyPrefix, key, "circuitBreaker.forceOpen", builder.getCircuitBreakerForceOpen(), default_circuitBreakerForceOpen);
        this.circuitBreakerForceClosed = getProperty(propertyPrefix, key, "circuitBreaker.forceClosed", builder.getCircuitBreakerForceClosed(), default_circuitBreakerForceClosed);
        this.executionIsolationStrategy = getProperty(propertyPrefix, key, "execution.isolation.strategy", builder.getExecutionIsolationStrategy(), default_executionIsolationStrategy);
        this.executionTimeoutInMilliseconds = getProperty(propertyPrefix, key, "execution.isolation.thread.timeoutInMilliseconds", builder.getExecutionIsolationThreadTimeoutInMilliseconds(), default_executionTimeoutInMilliseconds);
        this.executionTimeoutEnabled = getProperty(propertyPrefix, key, "execution.timeout.enabled", builder.getExecutionTimeoutEnabled(), default_executionTimeoutEnabled);
        this.executionIsolationThreadInterruptOnTimeout = getProperty(propertyPrefix, key, "execution.isolation.thread.interruptOnTimeout", builder.getExecutionIsolationThreadInterruptOnTimeout(), default_executionIsolationThreadInterruptOnTimeout);
        this.executionIsolationThreadInterruptOnFutureCancel = getProperty(propertyPrefix, key, "execution.isolation.thread.interruptOnFutureCancel", builder.getExecutionIsolationThreadInterruptOnFutureCancel(), default_executionIsolationThreadInterruptOnFutureCancel);
        this.executionIsolationSemaphoreMaxConcurrentRequests = getProperty(propertyPrefix, key, "execution.isolation.semaphore.maxConcurrentRequests", builder.getExecutionIsolationSemaphoreMaxConcurrentRequests(), default_executionIsolationSemaphoreMaxConcurrentRequests);
        this.fallbackIsolationSemaphoreMaxConcurrentRequests = getProperty(propertyPrefix, key, "fallback.isolation.semaphore.maxConcurrentRequests", builder.getFallbackIsolationSemaphoreMaxConcurrentRequests(), default_fallbackIsolationSemaphoreMaxConcurrentRequests);
        this.fallbackEnabled = getProperty(propertyPrefix, key, "fallback.enabled", builder.getFallbackEnabled(), default_fallbackEnabled);
        this.metricsRollingStatisticalWindowInMilliseconds = getProperty(propertyPrefix, key, "metrics.rollingStats.timeInMilliseconds", builder.getMetricsRollingStatisticalWindowInMilliseconds(), default_metricsRollingStatisticalWindow);
        this.metricsRollingStatisticalWindowBuckets = getProperty(propertyPrefix, key, "metrics.rollingStats.numBuckets", builder.getMetricsRollingStatisticalWindowBuckets(), default_metricsRollingStatisticalWindowBuckets);
        this.metricsRollingPercentileEnabled = getProperty(propertyPrefix, key, "metrics.rollingPercentile.enabled", builder.getMetricsRollingPercentileEnabled(), default_metricsRollingPercentileEnabled);
        this.metricsRollingPercentileWindowInMilliseconds = getProperty(propertyPrefix, key, "metrics.rollingPercentile.timeInMilliseconds", builder.getMetricsRollingPercentileWindowInMilliseconds(), default_metricsRollingPercentileWindow);
        this.metricsRollingPercentileWindowBuckets = getProperty(propertyPrefix, key, "metrics.rollingPercentile.numBuckets", builder.getMetricsRollingPercentileWindowBuckets(), default_metricsRollingPercentileWindowBuckets);
        this.metricsRollingPercentileBucketSize = getProperty(propertyPrefix, key, "metrics.rollingPercentile.bucketSize", builder.getMetricsRollingPercentileBucketSize(), default_metricsRollingPercentileBucketSize);
        this.metricsHealthSnapshotIntervalInMilliseconds = getProperty(propertyPrefix, key, "metrics.healthSnapshot.intervalInMilliseconds", builder.getMetricsHealthSnapshotIntervalInMilliseconds(), default_metricsHealthSnapshotIntervalInMilliseconds);
        this.requestCacheEnabled = getProperty(propertyPrefix, key, "requestCache.enabled", builder.getRequestCacheEnabled(), default_requestCacheEnabled);
        this.requestLogEnabled = getProperty(propertyPrefix, key, "requestLog.enabled", builder.getRequestLogEnabled(), default_requestLogEnabled);
        this.executionIsolationThreadPoolKeyOverride = HystrixPropertiesChainedProperty.forString().add(propertyPrefix + ".command." + key.name() + ".threadPoolKeyOverride", (Object)null).build();
例如:超时降级execution.isolation.thread.timeoutInMilliseconds和服务熔断的circuitBreaker.enabled和circuitBreaker.requestVolumeThreshold等等都在上面可以找到
全局服务降级
实现全局服务降级主要就是靠@DefaultProperties和@HystrixCommand
进入@DefaultProperties
@Target({ElementType.TYPE})
@Retention(RetentionPolicy.RUNTIME)
@Inherited
@Documented
public @interface DefaultProperties {
    String groupKey() default "";
    String threadPoolKey() default "";
    HystrixProperty[] commandProperties() default {};
    HystrixProperty[] threadPoolProperties() default {};
    Class<? extends Throwable>[] ignoreExceptions() default {};
    HystrixException[] raiseHystrixExceptions() default {};
    String defaultFallback() default "";
使用方法:这个注解加到消费者的controller层上,必要配置(defaultFallback)也就是默认服务降级方法名称,然后在需要使用默认服务降级的方法上加上@HystrixCommand(不加任何参数)即可
小坑:注意=======>默认服务降级的方法也就是defaultFallback方法“”不能有任何参数“”,不然就会报错
比如如下配置
@RestController
@DefaultProperties(defaultFallback = "queryAllDept_Hystrix") //默认全局服务降级,也就是配置上去后,需要服务降级的方法加上@HystrixCommand不加参数即可
    @Autowired
//    @HystrixCommand(fallbackMethod = "queryAllDept_Hystrix",commandProperties = {
//            @HystrixProperty(name = "execution.isolation.thread.timeoutInMilliseconds",value = "1500")
    @HystrixCommand //触发全局服务降级
        if(i<0){
        return deptService.queryAllDept(id);
//    //服务降级方法,全局服务降级方法不能有参数
    public List<dept> queryAllDept_Hystrix(){
        List<dept> depts = new ArrayList<>();
        return depts;
服务熔断
Pom.xml
 <!--        Hystrix-->
        <dependency>
        </dependency>
在springcloud-02-provider-dept8001和8002的controller
@RestController
    @Value("${server.port}")
    private String port;
    @Autowired
    @Qualifier("deptServiceImpl")
    public void setDeptService(com.boot.service.deptService deptService) {
        this.deptService = deptService;
    @GetMapping(path = "/queryAllDept")
            @HystrixProperty(name = "circuitBreaker.enabled",value = "true"),
            @HystrixProperty(name = "circuitBreaker.requestVolumeThreshold",value = "10"),
            @HystrixProperty(name = "circuitBreaker.sleepWindowInMilliseconds",value = "20000"),//注意这是毫秒。1秒=1000毫秒
            @HystrixProperty(name = "circuitBreaker.errorThresholdPercentage",value = "50")
        depts.add(new dept("999",port));
//        try {
//            Thread.sleep(1500);
//        } catch (InterruptedException e) {
//            e.printStackTrace();
        if(Integer.parseInt(id)<0){
        return depts;
     * 服务熔断
        depts.add(new dept("1066","Break"));
        return depts;
提供者主启动类:
@EnableEurekaClient //eureka客户端
@EnableCircuitBreaker //开启服务熔断功能
public class SpringBootApplication8001 {
        SpringApplication.run(SpringBootApplication8001.class,args);
Hystrix-Dashboard
创建子模块springcloud-02-hystrix-Dashboard8110
仪表盘的访问页面:
假如端口号是8110:http://localhost:8110/hystrix
Pom.xml
 <dependencies>
        <!--      web和actuator是必备的,******除了gateway网关不能加入web包  -->
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <!--        actuator用来监控-->
        <dependency>
            <artifactId>spring-boot-starter-actuator</artifactId>
        </dependency>
<!--     Hystrix-dashboard-->
         <dependency>
            <artifactId>spring-cloud-starter-netflix-hystrix-dashboard</artifactId>
        </dependency>
    </dependencies>
配置文件没有要求,就修改端口号即可
server:
  port: 8110
spring:
  application:
主启动类:
@EnableHystrixDashboard //开启了Hystrix仪表盘功能
public class springBootApplication8110 {
        SpringApplication.run(springBootApplication8110.class,args);
Bug:Hystrix仪表盘连接不上
image-20210227124135194
解决方法:在每一个需要监控的模块(比如微服务提供者8001和8002)加上如下配置
1.微服务提供者的Pom.xml
<!--     Hystrix-dashboard(微服务提供者)-->
         <dependency>
        </dependency>
2.在微服务提供者8001和8002加上一个bean
    //解决Hystrix-dashboard连接不上
    @Bean
    public ServletRegistrationBean getServlet() {
        HystrixMetricsStreamServlet streamServlet = new HystrixMetricsStreamServlet();
        ServletRegistrationBean registrationBean = new ServletRegistrationBean(streamServlet);
        registrationBean.setLoadOnStartup(1);
        registrationBean.addUrlMappings("/hystrix.stream");
        registrationBean.setName("HystrixMetricsStreamServlet");
        return registrationBean;
Bug:Hystrix仪表盘一直是loading
解决方法:用openFeign去调用一下即可
成功页面👇
image-20210227170129598
服务网关springcloud gateway
小坑:1.注意===》gateWay不能有springBoot-Web的启动器,不然会报错。。。。。。。。
小坑(负载均衡):2.注意==》需要把gateway当作提供者注册到注册中心eureka中,不然不能进行服务网关的负载均衡
服务网关gateway作用:把所有请求都先进入网关gateway,再由gateway进行分发请求,这样的好处就是隐藏分发到的微服务的端口号,安全性更高
配置gateway服务网关
1.创建子模块springcloud-02-gateWay9527
2.打开pom.xml,添加依赖
 		<dependency>
            <artifactId>spring-cloud-starter-gateway</artifactId>
        </dependency>
3.application.yml
server:
  port: 9527
spring:
  cloud:
    gateway:
      routes: #配置路由
        - id: providerGateway8001
          uri: http://localhost:8001
          predicates: #配置断言
            - Path=/queryAllDept
4.然后再访问http://localhost:9527/queryAllDept?id=1
gateway服务网关负载均衡(lb)
注意:需要把gateway当作提供者“”注册“”到注册中心eureka中,不然不能进行服务网关的负载均衡**
1.先导入这个
		<!--        eureka Client-->
        <dependency>
            <artifactId>spring-cloud-starter-netflix-eureka-client</artifactId>
        </dependency>
2.springBootApplication
@EnableEurekaClient
public class springBootApplication9527 {
        SpringApplication.run(springBootApplication9527.class,args);
3.application.yml
server:
  port: 9527
spring:
  application:
  cloud:
    gateway:
      routes:
          uri: lb://PROVIDER-DEPT
          predicates:
eureka:
  client:
    fetch-registry: true
    register-with-eureka: true
    service-url:
      defaultZone: http://eureka-server7001.com:7001/eureka/, http://eureka-server7002.com:7002/eureka/, http://eureka-server7003.com:7003/eureka/
分布式配置中心springcloud config
1.创建gitee或者GitHub,并把配置文件上传到git
image-20210302204336025
我们目的是拉取上面红框的配置文件
分布式配置中心服务器端(server)
2.创建子模块springcloud-02-config-server9001
3.导入依赖
<!--        config-server-->
      <dependency>
            <artifactId>spring-cloud-config-server</artifactId>
        </dependency>
4.application.yml
server:
  port: 9001
spring:
  cloud:
    config:
      server:
        git:
          default-label: master #文件所在git的分支,默认是master
          uri: https://gitee.com/youzhengjie/could-config #这个uri就是文件所在的网页地址。。。。
5.启动类
@EnableConfigServer //开启分布式配置中心服务器端
public class springBootApplication9001 {
        SpringApplication.run(springBootApplication9001.class,args);
分布式配置中心客户端(client)
1.创建子模块springcloud-02-config-client8002
2.导入依赖(注意:web和config-client必须要导入,特别是web依赖,不导入不行)
		 <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <artifactId>spring-cloud-config-client</artifactId>
        </dependency>
3.主启动类====不用加什么,就一个普通的springBoot启动类即可
4.bootstrap.yml
server:
  port: 8200
spring:
  cloud:
    config:
      label: master
      uri: http://localhost:9001
5.controller(去测试有没有sys.version,有的话就说明成功了)
@RestController
public class testController {
    @Value("${sys.version}")
    private String version;
    @RequestMapping("/getVersion")
    public String getVersion(){
        return version;
image-20210303204534651
引入springcloud bus消息总线之前。。。。
我们用git去把sys.version更新成1.8
去访问一下config-server
image-20210303204818402
发现config-server是可以立刻更新到的,因为config-server和gitee是直连的。
我们去访问一下config-client
image-20210303204946992
发现还是1.7,只有重新启动config-client项目才能更新成1.8,这是我们要用到actuator的refresh端点,手动刷新。
actuator手动刷新config-client
修改如下:1.在controller加上@RefreshScope
@RestController
@RefreshScope //config client刷新注解
        return version;
2.暴露端点
server:
  port: 8200
spring:
  cloud:
    config:
      label: master
#开启所有端点
management:
  endpoints:
    web:
      exposure:
        include: "*"
3.用postman去发送post刷新请求
前提:1.发送POST请求到uri/actuator/refresh
2.前面几步工作做好,比如@RefreshScope。
image-20210303210634591
就ok了!!!
为什么要引入springcloud bus的原因
感想:假如有20个config-client,我们要去刷新他们,难道一个个去发送post请求/actuator/refresh???那肯定不行,这样可以是可以,但是效率太低了,所以我们就会引入消息总线springcloud bus,一次post刷新请求即可,不管有多少模块需要刷新。很方便
消息总线springcloud Bus
引入消息总线springcloud bus不需要创建新的模块。。。。只需要用config server和config client即可
为什么不需要创建新的模块呢?因为在下面的架构中可以说明一切
1202638-20180521203126866-1299643942
安装rabbitMQ环境
总教程:https://www.cnblogs.com/saryli/p/9729591.html
1.安装erlang
(1.)下载erlang
官网地址:https://www.erlang.org/
下载教程:https://www.cnblogs.com/minily/p/7398445.html
(2.)配置erlang环境
配置教程:https://blog.csdn.net/g6256613/article/details/80191402
需要配置环境变量
image-20210304210138086
image-20210304210211142
(3.)检查是否安装成功
打开cmd,输入erl,有输出说明成功
(4.)下载rabbitMQ
下载地址:https://www.cnblogs.com/saryli/p/9729591.html
。。。。。。。。。。。。省略,在总教程都有。
(5.)最后访问http://localhost:15672,如果访问成功,说明rabbitMQ安装成功
配置springcloud Bus
有了springcloud bus,我们只需要通知config server,config server就会去“”遍历“”config client,一个个发送刷新的通知,就比如一个个发送/actuator/refresh
1.在上面的基础上,config server9001的pom.xml添加依赖
		<!--        bus-->
        <dependency>
            <artifactId>spring-cloud-starter-bus-amqp</artifactId>
        </dependency>
注意===========》2.config server 9001的application.yml
spring:
  cloud:
    config:
      server:
        git:
  rabbitmq:
    port: 5672
    username: guest
    password: guest
    host: localhost
#########注意::::一定要开放bus-refresh端点
management:
  endpoints:
    web:
      exposure:
        include: "bus-refresh"
3.在上面的基础上,config client 8200 的pom.xml
		<!--        bus-->
        <dependency>
        </dependency>
4.config client 8200的application.yml
spring:
  cloud:
    config:
      label: master
  rabbitmq:
    host: localhost
    username: guest
    password: guest
    port: 5672
5.在postman发送刷新命令即可。http://localhost:9001/actuator/bus-refresh
image-20210304204839588
