java递归查询三级菜单
小影 发表于 2022/04/01 10:27:39 2022/04/01
【摘要】 以上小编学习开发中使用&总结,如果对你有帮助就帮忙点个小赞(^人^),如有侵权联系小编!
方式一:纯SQL查询树状菜单
@Data
public class Menu {
    private String menuid;      //主键ID
    private String menuname;        //菜单名称
    private String parentid;    //上一级菜单
    private List<Menu> menus;   //子菜单列表
<resultMap id="menuMap" type="com.ying.model.Menu">
    <id column="menuid" property="menuid"/>
    <result column="menuname" property="menuname"/>
    <result column="parentid" property="parentid"/>
    <collection property="menus" ofType="com.ying.model.Menu" column="menuid" select="findMenuByParentId"/>
</resultMap>
<select id="getRootMenu" resultMap="menuMap">
    SELECT * FROM menu WHERE parentid ='' or parentid is NULL
</select>
<select id="findMenuByParentId" parameterType="java.lang.String" resultMap="menuMap">
    SELECT * from menu where parentid = #{parentid}
</select>
@Resource
private MenuMapper menuMapper;
 * sql 查询三级菜单
 * @return
public List<Menu> getf() {
    long start = System.currentTimeMillis();
    Menu rootMenu = menuMapper.getRootMenu();
    List<Menu> menuByParentId = menuMapper.findMenuByParentId(rootMenu.getMenuid());
    long end = System.currentTimeMillis();
    System.out.println("sql查询三级菜单耗时:" + (end - start));
    return menuByParentId;
方式二:单条递归查询树状菜单
<select id="queryAll" resultType="com.ying.model.Menu">
    select * from menu where parentid=#{menuid}
</select>
public Menu getmm() {
    Menu rootMenu = menuMapper.getRootMenu(); //查询最大的那个根菜单
    Menu menu = recursiveTree(rootMenu);
    System.out.println("递归单条查询三级菜单耗时:" + (end - start));
    return menu;
public Menu recursiveTree(Menu rootNode) {
    List<Menu> childNodes = getChildren(rootNode);
    if (childNodes != null) {
        for (Menu childNode : childNodes) {
            recursiveTree(childNode);
        rootNode.setMenus(childNodes);
    return rootNode;
public List<Menu> getChildren(Menu node) {
    List<Menu> childNodes = menuMapper.queryById(node.getMenuid());
    return childNodes;
方式三:一次性递归查询树状菜单
<select id="queryAllList" resultType="com.ying.model.Menu">
    select * from menu
</select>
public List<Menu> queryCategory() {
    // 1. 查出所有分类
    List<Menu> entities = menuMapper.queryAllList();
    // 2. 组装成父子的树形结构
    // 2.1 找到所有的一级分类
    List<Menu> level1Menus = entities.stream().filter(categoryEntity ->
            categoryEntity.getMenuid().equals("0")).map(menu -> {
        // 2.2 设置子菜单
        menu.setMenus(getChildren(menu, entities));
        return menu;
        // 2.3 排序
    }).collect(Collectors.toList());
    System.out.println("递归全部查询三级菜单耗时:" + (end - start));
    return level1Menus;
 * 递归查找所有菜单的子菜单
private List<Menu> getChildren(Menu root, List<Menu> all) {
    List<Menu> children = all.stream().filter(categoryEntity ->
            categoryEntity.getParentid().equals(root.getMenuid())
    ).map(categoryEntity -> {
        // 1. 找到子菜单
        categoryEntity.setMenus(getChildren(categoryEntity, all));
        return categoryEntity;
    return children;
    // 1. 查出所有分类
    // 2. 组装成父子的树形结构
    // 2.1 找到所有的一级分类
        // 2.2 设置子菜单
        return menu;
        // 2.3 排序
查询结果耗时 :
递归全部查询三级菜单耗时:28
递归单条查询三级菜单耗时:1607
sql查询三级菜单耗时:1465
