Redis cluster三主三从集群快速部署(十一)
jiangxl 发表于 2022/04/01 00:21:52 2022/04/01
【摘要】 部署三主三从redis cluster集群 架构图 环境准备 IP主机名端口号节点192.168.81.210redis-16380master192.168.81.210redis-16381...
架构图
请添加图片描述
环境准备
IP 主机名 端口号 节点
192.168.81.210 redis-1 6380 master
192.168.81.210 redis-1 6381 slave—>redis-2
192.168.81.220 redis-2 6380 master
192.168.81.220 redis-2 6381 slave—>redis-3
192.168.81.230 redis-3 6380 master
192.168.81.230 redis-3 6381 slave—>redis-1
1.redis运维脚本
使用这个脚本管理redis
#!/bin/bash
#redis控制脚本
redis_port=$2
redis_name="redis_${redis_port}"
redis_home=/data/redis_cluster/${redis_name}
redis_conf=${redis_home}/conf/${redis_name}.conf
redis_host=`ifconfig ens33 | awk 'NR==2{print $2}'`
redis_pass=$3
red="\e[031m"
green="\e[032m"
yellow="\e[033m"
black="\e[0m"
Usage(){
	echo "usage: sh $0 {start|stop|restart|login|ps|logs|-h} PORT"
Start(){
        redis_cz=`netstat -lnpt | grep redis | grep "${redis_port}" | wc -l`
        if [ $redis_cz -eq 0 ];then
                redis-server ${redis_conf}
                if [ -z $state ];then
                        echo -e "${green}redis ${redis_port}实例启动成功!${black}"
                else
                        echo -e "${green}redis ${redis_port}实例重启成功!${black}"
                fi
                netstat -lnpt | grep ${redis_port}
        else
                        echo -e "${yellow}redis "${redis_port}"实例已经是启动状态!${black}"
                fi
        fi
Stop(){
        if [ $redis_cz -gt 0 ];then
                redis-cli -h $redis_host -p $redis_port shutdown
                        echo -e "${green}redis ${redis_port}实例关闭成功!"
                fi
        else
                        echo -e "${red}redis "${redis_port}"实例没有启动!${black}"
                fi
        fi
Restart(){
	state=restart
	Stop
	Start
Login(){
	else
		echo -e "${red}redis ${redis_port}实例没有启动!${black}"
		echo -en  "${yellow}是否要启动reis? [y/n]${black}"
		read action
		case $action in
		y|Y)
			Start
			Login
		n|N)
			exit 1
		esac
	fi
Ps(){
	ps aux | grep redis
Logs(){
	tail -f ${redis_home}/logs/${redis_name}.log
Help(){
	Usage
	echo "+-------------------------------------------------------------------------------+"
	echo "| start		启动redis							|"
	echo "| stop		关闭redis							|"
	echo "| restart	重启redis							|"
	echo "| login		登陆redis							|"
	echo "| ps		查看redis的进程信息,不需要加端口号				|"
	echo "| logs		查看redis日志持续输出						|"
	echo "| 除ps命令外,所有命令后面都需要加端口号						|"
if [ $# -ne 2 ];then
	if [ "$1" != "ps" ] &&  [ "$1" != "-h" ];then
		Usage
		exit 1
	fi
fi
case $1 in
start)
	Start
stop)
	Stop
restart)
	Restart
login)
	Login
ps)
	Ps
logs)
	Logs
-h)
	Help
	Help
esac
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
2.部署redis节点
三个主机都执行,共部署两个redis节点,一个6380一个6381端口
1.创建部署路径
mkdir -p /data/redis_cluster/redis_{6380,6381}/{conf,data,logs,pid}
2.准备配置文件
cat > /data/redis_cluster/redis_6380/conf/redis_6380.conf <<EOF
bind $(ifconfig | awk 'NR==2{print $2}')
port 6380
daemonize yes
logfile /data/redis_cluster/redis_6380/logs/redis_6380.log
pidfile /data/redis_cluster/redis_6380/pid/redis_6380.log
dbfilename "redis_6380.rdb"
dir /data/redis_cluster/redis_6380/data
cluster-enabled yes
cluster-config-file node_6380.conf
cluster-node-timeout 15000
save 60 10000
save 300 10
save 900 1
EOF
cat > /data/redis_cluster/redis_6381/conf/redis_6381.conf <<EOF
port 6381
daemonize yes
logfile /data/redis_cluster/redis_6381/logs/redis_6381.log
pidfile /data/redis_cluster/redis_6381/pid/redis_6381.log
dbfilename "redis_6381.rdb"
dir /data/redis_cluster/redis_6381/data
cluster-enabled yes
cluster-config-file node_6381.conf
save 60 10000
save 300 10
save 900 1
EOF
3.启动
[root@redis-1 ~]# ./redis_shell.sh start 6380
redis 6380实例启动成功!
tcp        0      0 192.168.81.210:6380     0.0.0.0:*               LISTEN      127999/redis-server
tcp        0      0 192.168.81.210:16380    0.0.0.0:*               LISTEN      127999/redis-server
[root@redis-1 ~]# ./redis_shell.sh start 6381
redis 6381实例启动成功!
tcp        0      0 192.168.81.210:6381     0.0.0.0:*               LISTEN      128014/redis-server
tcp        0      0 192.168.81.210:16381    0.0.0.0:*               LISTEN      128014/redis-server
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
3.配置集群节点之间相互发现
互相发现只需要在一个节点上操作即可
[root@redis-2 ~]# redis-cli -h 192.168.81.210 -p 6380
192.168.81.210:6380> CLUSTER MEET 192.168.81.210 6381
OK
192.168.81.210:6380> CLUSTER MEET 192.168.81.220 6380
OK
192.168.81.210:6380> CLUSTER MEET 192.168.81.220 6381
OK
192.168.81.210:6380> CLUSTER MEET 192.168.81.230 6380
OK
192.168.81.210:6380> CLUSTER MEET 192.168.81.230 6381
OK
192.168.81.210:6380> CLUSTER NODES
34e698b929948c3c61c4ba40c129161b736ee5cc 192.168.81.230:6381 master - 0 1612334628247 5 connected
4827ff5cbc7122a4459b1d91bd15a89e0661a91b 192.168.81.220:6381 master - 0 1612334624212 2 connected
8d918c708db4a9fbe6b08d9f707d501eb328885e 192.168.81.230:6380 master - 0 1612334625222 0 connected
4e99bc582fede8e359fb25d163e7267f616409ff 192.168.81.210:6381 master - 0 1612334626229 1 connected
5f19db5c04ccaea18270819f5af37cacbf41a800 192.168.81.210:6380 myself,master - 0 0 3 connected
454fe9862588f97f969c181b3f8c5e24f6135265 192.168.81.220:6380 master - 0 1612334627241 4 connected
6个redis节点已经全部发现
4.配置cluster分配槽位
在redis-1上操作即可
1.分配槽位
[root@redis-1 ~]# redis-cli -h 192.168.81.210 -p 6380 cluster addslots {0..5461}
OK
[root@redis-1 ~]# redis-cli -h 192.168.81.220 -p 6380 cluster addslots {5462..10922}
OK
[root@redis-1 ~]# redis-cli -h 192.168.81.230 -p 6380 cluster addslots {10923..16383}
OK
2.查看集群状态
[root@redis-1 ~]# redis-cli -h 192.168.81.210 -p 6380 cluster info
cluster_state:ok
cluster_slots_assigned:16384
cluster_slots_ok:16384
cluster_slots_pfail:0
cluster_slots_fail:0
cluster_known_nodes:6
cluster_size:1
cluster_current_epoch:5
cluster_my_epoch:3
cluster_stats_messages_sent:488
cluster_stats_messages_received:488
5.配置三主三从集群
1.获取集群信息
[root@redis-1 ~]# redis-cli -h 192.168.81.210 -p 6380 cluster nodes | grep 6380 | awk '{print $1,$2}'
2.配置交叉复制
[root@redis-1 ~]# redis-cli -h 192.168.81.210 -p 6381
192.168.81.210:6381> CLUSTER REPLICATE 454fe9862588f97f969c181b3f8c5e24f6135265
OK
[root@redis-1 ~]# redis-cli -h 192.168.81.220 -p 6381
192.168.81.220:6381> CLUSTER REPLICATE 8d918c708db4a9fbe6b08d9f707d501eb328885e
OK
[root@redis-1 ~]# redis-cli -h 192.168.81.230 -p 6381
192.168.81.230:6381> CLUSTER REPLICATE 5f19db5c04ccaea18270819f5af37cacbf41a800
OK
454fe9862588f97f969c181b3f8c5e24f6135265 192.168.81.220:6380 master - 0 1612336046339 4 connected 5462-10922
4827ff5cbc7122a4459b1d91bd15a89e0661a91b 192.168.81.220:6381 slave 8d918c708db4a9fbe6b08d9f707d501eb328885e 0 1612336049371 2 connected
5f19db5c04ccaea18270819f5af37cacbf41a800 192.168.81.210:6380 myself,master - 0 0 3 connected 0-5461
8d918c708db4a9fbe6b08d9f707d501eb328885e 192.168.81.230:6380 master - 0 1612336047350 0 connected 10923-16383
34e698b929948c3c61c4ba40c129161b736ee5cc 192.168.81.230:6381 slave 5f19db5c04ccaea18270819f5af37cacbf41a800 0 1612336045330 5 connected
4e99bc582fede8e359fb25d163e7267f616409ff 192.168.81.210:6381 slave 454fe9862588f97f969c181b3f8c5e24f6135265 0 1612336048360 4 connected
  • 26
已经交叉复制,到此三主三从redis cluster集群部署完成
6.快速删除一个redis cluster集群方式
两种方法:
  • 将所有redis节点的数据文件全部删除包括rdb、node_6380.conf
  • 登陆每一个节点,执行cluster reset
文章来源: jiangxl.blog.csdn.net,作者:Jiangxl~,版权归原作者所有,如需转载,请联系作者。
原文链接:jiangxl.blog.csdn.net/article/details/121027823
