为SAP Analytics Cloud的story创建持久化页面
汪子熙 发表于 2022/03/31 22:16:07 2022/03/31
【摘要】 在SAP Analytics Cloud Story标签页里新建一个页面,或者选中默认的page,选择Rename进行重命名:例如改成Jerry first page.工具栏里点击如下按钮,插入一个新的Table:为table添加Measure/Dimension:添加AccountID到table之后的效果如下图:更改table的风格,从Template下拉菜单里选择Report-Styl...
更改table的风格,从Template下拉菜单里选择Report-Styling:
将这个制作好的表格,通过菜单项Pin to Home添加到Home页面,方便以后使用:
SAP Analytics Cloud部署在SAP Cloud Platform的Neo或者CloudFoundry环境上:
SAP官方帮助文档:
https://help.sap.com/viewer/00f68c2e08b941f081002fd3691d86a7/release/en-US/11b4e5ff76eb4747bc255d7037be1f01.html
查看System Requirements and Technical Prerequisites
在Live connection的场景里,Analytics Cloud只存储metadata. SAP Analytics Cloud stores queries for building the stories, measure names, columns names, filter values, and so on. Basically, the metadata lets SAP Analytics Cloud rebuild the query. But none of the actual data, not even the query results or part of the results, such as totals, are saved to SAP Analytics Cloud. Metadata is transferred to your browser and encrypted in memory.
在System Sizing,Tuning and Limits里有数据导入相关的大小限制说明:
Excel最大支持200MB,CSV文件2GB;
Model和Story最多800000行,datasets 1000000行。
Model和Story最多支持100列,Datasets支持1000列。
官方文档:https://help.sap.com/viewer/00f68c2e08b941f081002fd3691d86a7/release/en-US/5f61b6509a5e4d499e8cb9685f32db73.html
从open SAP的课程能看出,SAP Analytics Cloud也是部署在SAP Cloud Platform上:
https://open.sap.com/courses/cp6
关于Smart Predict的Note:
https://launchpad.support.sap.com/#/notes/2661746
A key strategic goal of SAP Analytics Cloud (SAC) is to bring BI, Planning and Predictive together into one simple cloud application.
Smart Predict is currently available in all regions except China for all new SAP Analytics Cloud tenants. Additional availability options will be added on a phased basis.
截至今天(2020年3月27日),中国的tenant上不支持Smart Predict.
支持Smart Predict的tenant全部部署在SAP Cloud Platform CloudFoundry环境上,包括US10, EU10, BR10, JA10, AP10.
我们使用的tenant在中国(AP1),部署在SAP云平台的Neo环境上,所以不支持Smart Predict
