2021全网最全Activiti7教程02(Activiti7入门使用-欢迎收藏)
全网最详细Activiti系列文章,强烈建议收藏加关注哦!
Activiti的入门应用
1Activiti的基本使用
1.1 创建Maven项目
创建一个普通的Maven项目,并添加相关的依赖
<properties>
<slf4j.version>1.6.6</slf4j.version>
<log4j.version>1.2.12</log4j.version>
<activiti.version>7.0.0.Beta1</activiti.version>
</properties>
<dependencies>
<dependency>
<groupId>org.activiti</groupId>
<artifactId>activiti-engine</artifactId>
<version>${activiti.version}</version>
</dependency>
<dependency>
<artifactId>activiti-spring</artifactId>
</dependency>
<!-- bpmn 模型处理 -->
<dependency>
<artifactId>activiti-bpmn-model</artifactId>
</dependency>
<!-- bpmn 转换 -->
<dependency>
<artifactId>activiti-bpmn-converter</artifactId>
</dependency>
<!-- bpmn json数据转换 -->
<dependency>
<artifactId>activiti-json-converter</artifactId>
</dependency>
<!-- bpmn 布局 -->
<dependency>
<artifactId>activiti-bpmn-layout</artifactId>
<exclusions>
<exclusion>
<groupId>com.github.jgraph</groupId>
<artifactId>jgraphx</artifactId>
</exclusion>
</exclusions>
</dependency>
<!-- activiti 云支持 -->
<dependency>
<groupId>org.activiti.cloud</groupId>
<artifactId>activiti-cloud-services-api</artifactId>
</dependency>
<!-- mysql驱动 -->
<dependency>
<groupId>mysql</groupId>
<artifactId>mysql-connector-java</artifactId>
<version>5.1.40</version>
</dependency>
<!-- mybatis -->
<dependency>
<groupId>org.mybatis</groupId>
<artifactId>mybatis</artifactId>
<version>3.4.5</version>
</dependency>
<!-- 链接池 -->
<dependency>
<groupId>commons-dbcp</groupId>
<artifactId>commons-dbcp</artifactId>
<version>1.4</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.12</version>
</dependency>
<!-- log start -->
<dependency>
<groupId>log4j</groupId>
<artifactId>log4j</artifactId>
<version>${log4j.version}</version>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>${slf4j.version}</version>
</dependency>
<dependency>
<artifactId>slf4j-log4j12</artifactId>
</dependency>
</dependencies>
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
- 27
- 28
- 29
- 30
- 31
- 32
- 33
- 34
- 35
- 36
- 37
- 38
- 39
- 40
- 41
- 42
- 43
- 44
- 45
- 46
- 47
- 48
- 49
- 50
- 51
- 52
- 53
- 54
- 55
- 56
- 57
- 58
- 59
- 60
- 61
- 62
- 63
- 64
- 65
- 66
- 67
- 68
- 69
- 70
- 71
- 72
- 73
- 74
- 75
- 76
- 77
- 78
- 79
- 80
- 81
- 82
- 83
- 84
- 85
- 86
- 87
- 88
- 89
- 90
- 91
- 92
1.2 log4j
添加一个日志文件log4j.properties
# Set root category priority to INFO and its only appender to CONSOLE.
#log4j.rootCategory=INFO, CONSOLE debug info warn error fatal
log4j.rootCategory=debug, CONSOLE, LOGFILE
# Set the enterprise logger category to FATAL and its only appender to CONSOLE.
log4j.logger.org.apache.axis.enterprise=FATAL, CONSOLE
# CONSOLE is set to be a ConsoleAppender using a PatternLayout.
log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
log4j.appender.CONSOLE.layout.ConversionPattern=%d{ISO8601} %-6r[%15.15t] %-5p %30.30c %x - %m\n
# LOGFILE is set to be a File appender using a PatternLayout.
log4j.appender.LOGFILE=org.apache.log4j.FileAppender
log4j.appender.LOGFILE.File=d:\log\act\activiti.log
log4j.appender.LOGFILE.Append=true
log4j.appender.LOGFILE.layout=org.apache.log4j.PatternLayout
log4j.appender.LOGFILE.layout.ConversionPattern=%d{ISO8601} %-6r[%15.15t] %-5p %30.30c %x - %m\n
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
1.3 添加Activiti配置文件
我们在本案例中使用的数据库是mysql8.0.
Activiti的默认的使用方式是要求我们在resources下创建activiti.cfg.xml文件,默认的方式的名称是不能修改的。
在配置文件中我们有两种配置方式:一种是单独配置数据源,另一种是不单独配置数据源
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd">
<bean class="org.activiti.engine.impl.cfg.StandaloneProcessEngineConfiguration" id="processEngineConfiguration">
<property name="jdbcDriver" value="com.mysql.cj.jdbc.Driver"/>
<property name="jdbcUrl" value="jdbc:mysql:///activiti2?characterEncoding=utf-8&nullCatalogMeansCurrent=true&serverTimezone=UTC" />
<property name="jdbcUsername" value="root" />
<property name="jdbcPassword" value="123456" />
<property name="databaseSchemaUpdate" value="true" />
<!--<property name="dataSource" ref="dataSource" />-->
</bean>
<bean class="org.apache.commons.dbcp.BasicDataSource" id="dataSource">
<property name="driverClassName" value="com.mysql.cj.jdbc.Driver" />
<property name="url" value="jdbc:mysql:///activiti2?characterEncoding=utf-8&nullCatalogMeansCurrent=true&serverTimezone=UTC" />
<property name="username" value="root"/>
<property name="password" value="123456"/>
<property name="maxActive" value="3" />
<property name="maxIdle" value="2" />
</bean>
</beans>
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
1.4 Java程序生成表结构
创建一个工具类,调用Activiti的工具类来生成activiti需要的表结构
public class Test01 {
* 生成Activiti的相关的表结构
@Test
public void test01(){
// 使用classpath下的activiti.cfg.xml中的配置来创建 ProcessEngine对象
ProcessEngine engine = ProcessEngines.getDefaultProcessEngine();
System.out.println(engine);
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
执行的效果
执行完成后我们查看数据库,在其中创建了25张表,结果如下:
2 表结构介绍
2.1 表的命名规则和作用
看到刚才创建的表,我们发现Activiti 的表都以 ACT_ 开头。
第二部分是表示表的用途的两个字母标识。 用途也和服务的 API 对应。
ACT_RE :'RE’表示 repository。 这个前缀的表包含了流程定义和流程静态资源 (图片,规则,等等)。
ACT_RU:'RU’表示 runtime。 这些运行时的表,包含流程实例,任务,变量,异步任务,等运行中的数据。 Activiti 只在流程实例执行过程中保存这些数据, 在流程结束时就会删除这些记录。 这样运行时表可以一直很小速度很快。
ACT_HI:'HI’表示 history。 这些表包含历史数据,比如历史流程实例, 变量,任务等等。
ACT_GE : GE 表示 general。 通用数据, 用于不同场景下
2.2 Activiti数据表介绍
表分类 | 表名 | 解释 |
一般数据 | ||
[ACT_GE_BYTEARRAY] | 通用的流程定义和流程资源 | |
[ACT_GE_PROPERTY] | 系统相关属性 | |
流程历史记录 | ||
[ACT_HI_ACTINST] | 历史的流程实例 | |
[ACT_HI_ATTACHMENT] | 历史的流程附件 | |
[ACT_HI_COMMENT] | 历史的说明性信息 | |
[ACT_HI_DETAIL] | 历史的流程运行中的细节信息 | |
[ACT_HI_IDENTITYLINK] | 历史的流程运行过程中用户关系 | |
[ACT_HI_PROCINST] | 历史的流程实例 | |
[ACT_HI_TASKINST] | 历史的任务实例 | |
[ACT_HI_VARINST] | 历史的流程运行中的变量信息 | |
流程定义表 | ||
[ACT_RE_DEPLOYMENT] | 部署单元信息 | |
[ACT_RE_MODEL] | 模型信息 | |
[ACT_RE_PROCDEF] | 已部署的流程定义 | |
运行实例表 | ||
[ACT_RU_EVENT_SUBSCR] | 运行时事件 | |
[ACT_RU_EXECUTION] | 运行时流程执行实例 | |
[ACT_RU_IDENTITYLINK] | 运行时用户关系信息,存储任务节点与参与者的相关信息 | |
[ACT_RU_JOB] | 运行时作业 | |
[ACT_RU_TASK] | 运行时任务 | |
[ACT_RU_VARIABLE] | 运行时变量表 |
3 ProcessEngine创建方式
前面使用的是getDefaultProcessEngine()方法来加载classpath下的 activiti.cfg.xml文件,有些情况下我们可能没有按照默认的方式来处理,那这时我们应该怎么办呢?
* 自定义的方式来加载配置文件
@Test
public void test02(){
// 首先创建ProcessEngineConfiguration对象
ProcessEngineConfiguration configuration =
ProcessEngineConfiguration.createProcessEngineConfigurationFromResource("activiti.cfg.xml");
// 通过ProcessEngineConfiguration对象来创建 ProcessEngine对象
ProcessEngine processEngine = configuration.buildProcessEngine();
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
4 Servcie服务接口
Service是工作流引擎提供用于进行工作流部署、执行、管理的服务接口,我们使用这些接口可以就是操作服务对应的数据表
4.1 Service创建方式
通过ProcessEngine创建Service
方式如下:
RuntimeService runtimeService = processEngine.getRuntimeService();
RepositoryService repositoryService = processEngine.getRepositoryService();
TaskService taskService = processEngine.getTaskService();
- 1
- 2
- 3
4.2 Service总览
service名称 | service作用 |
RepositoryService | activiti的资源管理类 |
RuntimeService | activiti的流程运行管理类 |
TaskService | activiti的任务管理类 |
HistoryService | activiti的历史管理类 |
ManagerService | activiti的引擎管理类 |
简单介绍:
RepositoryService
是activiti的资源管理类,提供了管理和控制流程发布包和流程定义的操作。使用工作流建模工具设计的业务流程图需要使用此service将流程定义文件的内容部署到计算机。
除了部署流程定义以外还可以:查询引擎中的发布包和流程定义。
暂停或激活发布包,对应全部和特定流程定义。 暂停意味着它们不能再执行任何操作了,激活是对应的反向操作。获得多种资源,像是包含在发布包里的文件, 或引擎自动生成的流程图。
获得流程定义的pojo版本, 可以用来通过java解析流程,而不必通过xml。
RuntimeService
Activiti的流程运行管理类。可以从这个服务类中获取很多关于流程执行相关的信息
TaskService
Activiti的任务管理类。可以从这个类中获取任务的信息。
HistoryService
Activiti的历史管理类,可以查询历史信息,执行流程时,引擎会保存很多数据(根据配置),比如流程实例启动时间,任务的参与者, 完成任务的时间,每个流程实例的执行路径,等等。 这个服务主要通过查询功能来获得这些数据。
ManagementService
Activiti的引擎管理类,提供了对 Activiti 流程引擎的管理和维护功能,这些功能不在工作流驱动的应用程序中使用,主要用于 Activiti 系统的日常维护。
5 流程绘制
5.1 绘制插件
由于Idea 在2019年之后就没有再更新维护Activiti的设计工具了,那么在高版本的IDEA中我们就没法使用actiBPM插件来绘制了,这时可以选择降低版本来使用,或者使用我们给大家提供的Eclipse来实现流程的设计。
我们提供给大家的Eclipse是已经集成好了Activiti插件的。
创建一个Activiti项目
5.2 绘制流程
使用滑板来绘制流程,通过从右侧把图标拖拽到左侧的面板,最终的效果
指定流程的主键
指定任务的负责人
在Properties视图中指定每个任务节点的负责人:
经理审批:lisi
总经理审批:wangwu
财务审批:xiaoming
当我们设置完成后保存文件,会同时生成png图片
然后将这两个文件拷贝到IDEA项目中即可
5.3 图标介绍
流程符号
BPMN 2.0是业务流程建模符号2.0的缩写。
它由Business Process Management Initiative这个非营利协会创建并不断发展。作为一种标识,BPMN 2.0是使用一些符号来明确业务流程设计流程图的一整套符号规范,它能增进业务建模时的沟通效率。
目前BPMN2.0是最新的版本,它用于在BPM上下文中进行布局和可视化的沟通。
接下来我们先来了解在流程设计中常见的 符号。
BPMN2.0的基本符合主要包含:
事件 Event
活动 Activity
活动是工作或任务的一个通用术语。一个活动可以是一个任务,还可以是一个当前流程的子处理流程; 其次,你还可以为活动指定不同的类型。常见活动如下:
网关 GateWay
网关用来处理决策,有几种常用网关需要了解:
排他网关 (x)**
——只有一条路径会被选择。流程执行到该网关时,按照输出流的顺序逐个计算,当条件的计算结果为true时,继续执行当前网关的输出流;
如果多条线路计算结果都是 true,则会执行第一个值为 true 的线路。如果所有网关计算结果没有true,则引擎会抛出异常。
排他网关需要和条件顺序流结合使用,default 属性指定默认顺序流,当所有的条件不满足时会执行默认顺序流。
并行网关 (+)
——所有路径会被同时选择
拆分 —— 并行执行所有输出顺序流,为每一条顺序流创建一个并行执行线路。
合并 —— 所有从并行网关拆分并执行完成的线路均在此等候,直到所有的线路都执行完成才继续向下执行。
包容网关 (+)
—— 可以同时执行多条线路,也可以在网关上设置条件
拆分 —— 计算每条线路上的表达式,当表达式计算结果为true时,创建一个并行线路并继续执行
事件网关 (+)
专门为中间捕获事件设置的,允许设置多个输出流指向多个不同的中间捕获事件。当流程执行到事件网关后,流程处于等待状态,需要等待抛出事件才能将等待状态转换为活动状态。
流向 Flow
流是连接两个流程节点的连线。常见的流向包含以下几种:
流程设计器使用
Palette(画板)
Connection—连接
Event—事件
Task—任务
Gateway—网关
Container—容器
Boundary event—边界事件
Intermediate event- -中间事件
- Activiti的基本应用就介绍到这儿,下篇开始给大家讲解如何具体的来使用。欢迎关注点赞加收藏哦 V_V
文章来源: dpb-bobokaoya-sm.blog.csdn.net,作者:波波烤鸭,版权归原作者所有,如需转载,请联系作者。
原文链接:dpb-bobokaoya-sm.blog.csdn.net/article/details/117824407
