Java数组元素的默认初始化值
YuShiwen 发表于 2022/03/30 23:22:18 2022/03/30
【摘要】 数组元素是整型默认初始化值为0数组元素是浮点型默认初始化值为0.0数组元素是char型默认初始化值为0或’\u0000’,而非字符型’0’数组元素是boolean型默认初始化值为false数组元素是引用数...
  • 数组元素是整型默认初始化值为0
  • 数组元素是浮点型默认初始化值为0.0
  • 数组元素是char型默认初始化值为0或’\u0000’,而非字符型’0’
  • 数组元素是boolean型默认初始化值为false
  • 数组元素是引用数据类型默认初始化值为null
代码测试:
 * @Author: YuShiwen
 * @Date: 2020/11/12 7:14 PM
 * @Version: 1.0
public class ArrayTest {
        //整型默认初始化值为0
        int[] arr = new int[3];
        for (int i : arr) {
            System.out.print(i);
        System.out.println();
        byte[] arr1 = new byte[3];
        for (byte b : arr1) {
            System.out.print(b);
        short[] arr2 = new short[3];
        for (short i : arr2) {
        //浮点型默认初始化值为0.0
        float[] floats = new float[3];
        for (float aFloat : floats) {
            System.out.print(aFloat);
        double[] doubles = new double[3];
        for (double aDouble : doubles) {
            System.out.print(aDouble);
        //char型默认初始化值为0或'\u0000',而非字符型'0'
        char[] chars = new char[3];
        for (char aChar : chars) {
            System.out.print(aChar);
        if(chars[0] == 0){
            System.out.println("char型默认初始化值为0或'\\u0000',而非字符型'0'");
        //boolean默认初始化值为false
        boolean[] booleans = new boolean[3];
        for (boolean aBoolean : booleans) {
            System.out.print(aBoolean);
        //引用数据类型为null
        String[] strings = new String[3];
        for (String string : strings) {
            System.out.print(string);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
测试结果:
000
000
000
0.00.00.0
0.00.00.0
falsefalsefalse
nullnullnull
Process finished with exit code 0
文章来源: blog.csdn.net,作者:Mr.Yushiwen,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/MrYushiwen/article/details/109653837
