Hadoop之HDFS04【JavaAPI操作】
波波烤鸭 发表于 2022/03/30 02:14:46 2022/03/30
【摘要】   前面项目中我们是创建的java项目来演示的,但是hadoop相关的依赖太多了,不方便,本文通过maven项目来演示HDFS的java API操作 创建maven项目 相关的依赖 <depe...
创建maven项目
相关的依赖
<dependencies>
	<dependency>
		<groupId>org.apache.hadoop</groupId>
		<artifactId>hadoop-hdfs</artifactId>
		<version>2.5.0</version>
	</dependency>
	<dependency>
		<artifactId>hadoop-client</artifactId>
		<version>2.5.1</version>
	</dependency>
	<dependency>
		<artifactId>hadoop-common</artifactId>
	</dependency>
	<dependency>
		<groupId>junit</groupId>
		<artifactId>junit</artifactId>
		<version>4.12</version>
	</dependency>
</dependencies>
CRUD 操作
package com.sxt.test;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.URI;
import java.util.Iterator;
import java.util.Map.Entry;
import org.apache.commons.io.IOUtils;
import org.apache.hadoop.conf.Configuration;
import org.apache.hadoop.fs.BlockLocation;
import org.apache.hadoop.fs.FSDataInputStream;
import org.apache.hadoop.fs.FSDataOutputStream;
import org.apache.hadoop.fs.FileStatus;
import org.apache.hadoop.fs.FileSystem;
import org.apache.hadoop.fs.LocatedFileStatus;
import org.apache.hadoop.fs.Path;
import org.apache.hadoop.fs.RemoteIterator;
import org.junit.Before;
import org.junit.Test;
public class HdfsTest {
	FileSystem fs = null;
	Configuration conf = null;
	@Before
	public void test() throws Exception {
		// 1.加载配置文件
		conf = new Configuration(true);
		// 2.获取FileSystem对象
		fs = FileSystem.get(new URI("hdfs://hadoop-node01:9000"),conf,"root");
	 * 上传文件
	 * @throws IOException
	 * @throws IllegalArgumentException
	@Test
	public void updateFile() throws IllegalArgumentException, IOException{
		fs.copyFromLocalFile(true, true, new Path("c:/unintall.log"), new Path("/"));
		fs.close();
	 * 下载文件
	 * @throws Exception
	@Test
	public void testDownload() throws Exception {
		fs.copyToLocalFile(new Path("/a.txt"), new Path("c:/tools"));
		fs.close();
	 * 打印参数
	@Test
	public void testConf(){
		Iterator<Entry<String, String>> it = conf.iterator();
		while(it.hasNext()){
			Entry<String, String> ent = it.next();
			System.out.println(ent.getKey() + " : " + ent.getValue());
	 * 创建文件夹
	 * @throws Exception
	@Test
	public void testMkdir() throws Exception {
		boolean mkdirs = fs.mkdirs(new Path("/testmkdir/aaa/bbb"));
		System.out.println(mkdirs);
	 * 删除文件夹
	 * @throws Exception
	@Test
	public void testDelete() throws Exception {
		// recursive 是否递归删除
		boolean flag = fs.delete(new Path("/testmkdir/aaa"), true);
		System.out.println(flag);
	 * 递归列出指定目录下所有子文件夹中的文件
	 * @throws Exception
	@Test
	public void testLs() throws Exception {
		RemoteIterator<LocatedFileStatus> listFiles = fs.listFiles(new Path("/"), true);
		while(listFiles.hasNext()){
			LocatedFileStatus fileStatus = listFiles.next();
			System.out.println("blocksize: " +fileStatus.getBlockSize());
			System.out.println("owner: " +fileStatus.getOwner());
			System.out.println("Replication: " +fileStatus.getReplication());
			System.out.println("Permission: " +fileStatus.getPermission());
			System.out.println("Name: " +fileStatus.getPath().getName());
			System.out.println("------------------");
			BlockLocation[] blockLocations = fileStatus.getBlockLocations();
			for(BlockLocation b:blockLocations){
				System.out.println("块起始偏移量: " +b.getOffset());
				System.out.println("块长度:" + b.getLength());
				//块所在的datanode节点
				String[] datanodes = b.getHosts();
				for(String dn:datanodes){
				System.out.println("datanode:" + dn);
	 * 获取文件的类型
	 * @throws Exception
	@Test
	public void testLs2() throws Exception {
		FileStatus[] listStatus = fs.listStatus(new Path("/"));
		for(FileStatus file :listStatus){
			System.out.println("name: " + file.getPath().getName());
			System.out.println((file.isFile()?"file":"directory"));
	 * 通过流的方式将文件上传到HDFS系统中
	 * @throws Exception
	@Test
	public void testStreamUpload() throws Exception, IOException{
		// 输出流
		FSDataOutputStream out = fs.create(new Path("/dpb.txt"), true);
		// 字节输入流
		InputStream in = new FileInputStream("c:/tools/aaaaa.txt");
		IOUtils.copy(in, out);
		in.close();
		out.close();
	 * 通过流的方式获取HDFS上的数据
	 * @throws Exception
	@Test
	public void testStreamDownload() throws IllegalArgumentException, Exception{
		FSDataInputStream in = fs.open(new Path("/dpb.txt"));
		OutputStream out = new FileOutputStream("c:/tools/a1.txt");
		out.close();
		in.close();
	 * 获取HDFS中的文件的一部分内容
	 * @throws Exception
	@Test
	public void testRandomAccess() throws IllegalArgumentException, Exception{
		in.seek(4);
		OutputStream out = new FileOutputStream("c:/tools/a2.txt");
		out.close();
		in.close();
	 * 显示HDFS上文件的内容
	@Test
	public void testCat() throws IllegalArgumentException, IOException{
		// 将输出的目的地执行控制台即可~
		IOUtils.copy(in, System.out);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
只放出最后一个方法的输出。其他方法执行效果请各自尝试
文章来源: dpb-bobokaoya-sm.blog.csdn.net,作者:波波烤鸭,版权归原作者所有,如需转载,请联系作者。
原文链接:dpb-bobokaoya-sm.blog.csdn.net/article/details/88981296
