爬虫管道
冬晨夕阳 发表于 2022/03/29 23:33:47 2022/03/29
【摘要】 from datetime import datetime from scrapy.exporters import JsonItemExporter, CsvItemExporter import py...
import pymongo
import redis
from .settings import REDIS_HOST, REDIS_PORT, MONGO_HOST, MONGO_PORT
数据源的管道
class AqiDataPipeline(object):
    def process_item(self, item, spider):
        # 记录爬取时间
        item[‘crawl_time‘] = datetime.utcnow()
        # 记录爬虫
        item[‘spider‘] = spider.name
        return item
Json的管道
class AqiJsonPipeline(object):
    def open_spider(self, spider):
        self.file = open("aqi.json", ‘wb‘)
        self.write = JsonItemExporter(self.file)
        self.write.start_exporting()
        self.write.export_item(item)
        return item
    def close_spider(self, spider):
        self.write.finish_exporting()
        self.file.close()
Csv的管道
class AqiVscPipeline(object):
        self.file = open("aqi.csv", ‘wb‘)
        self.write = CsvItemExporter(self.file)
        return item
        self.file.close()
mongodb数据库管道
class AqiMongoPipeline(object):
        self.client = pymongo.MongoClient(host=MONGO_HOST, port=MONGO_PORT)
        self.db = self.client[‘Aqi‘]
        self.collection = self.db[‘aqi‘]
        self.collection.insert(dict(item))
        return item
        self.client.close()
redis数据库管道
class AqiRedisPipeline(object):
        self.client = redis.Redis(host=REDIS_HOST, port=REDIS_PORT)
        self.client.lpush(‘aqi‘, dict(item))
        return item
文章来源: blog.csdn.net,作者:考古学家lx,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_43582101/article/details/89679364
