轻松掌握Mybatis(上)
wangweijun 发表于 2022/03/29 23:55:39 2022/03/29
【摘要】 入门案例 现有一张数据表: mysql> use mybatis; Database changed mysql> select * from tbl_employee; +----+--...
入门案例
现有一张数据表:
mysql> use mybatis;
Database changed
| id | last_name | gender | email       |
|  1 | tom       | 0      | tom@163.com |
1 row in set (0.00 sec)
该如何通过MyBatis对其进行查询?
首先创建对应的Java类:
package com.wwj.mybatis.bean;
public class Employee {
	private Integer id;
	private String lastName;
	private String email;
	private String gender;
	public Integer getId() {
		return id;
	public void setId(Integer id) {
		this.id = id;
	public String getLastName() {
		return lastName;
	public void setLastName(String lastName) {
		this.lastName = lastName;
	public String getEmail() {
		return email;
	public void setEmail(String email) {
		this.email = email;
	public String getGender() {
		return gender;
	public void setGender(String gender) {
		this.gender = gender;
	@Override
	public String toString() {
		return "Employee [id=" + id + ", lastName=" + lastName + ", email=" + email + ", gender=" + gender + "]";
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
其次编写MyBatis的全局配置文件(mybatis-config.xml):
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE configuration
  PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
  "http://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
 	<environments default="development">
		<environment id="development">
			<transactionManager type="JDBC"/>
      			<dataSource type="POOLED">
        			<property name="driver" value="com.mysql.jdbc.Driver"/>
        			<property name="url" value="jdbc:mysql:///mybatis"/>
      				<property name="username" value="root"/>
        			<property name="password" value="123456"/>
      			</dataSource>
    	</environment>
	</environments>
	<mappers>
		<mapper resource="EmployeeMapper.xml"/>
	</mappers>
</configuration>
全局配置文件中主要配置的是数据源信息,然后是最后的mappers标签,该标签配置的是sql语句的映射文件。
所以我们接着创建sql语句的映射文件(EmployeeMapper.xml):
<!DOCTYPE mapper
  PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
  "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.wwj.mybatis.bean.Employee">
 	<select id="selectEmp" resultType="com.wwj.mybatis.bean.Employee">
    	select id,last_name lastName,email,gender from tbl_employee where id = #{id}
  	</select>
</mapper>
其中mapper标签的namespace属性设置的是需要映射的类全名;select标签表示查询语句,其中的id属性是该sql的唯一标识,resultType表示返回值的类型;然后在select标签中编写需要执行的sql语句。
一切准备就绪后,开始编写测试代码:
@Test
void test() throws IOException {
	String resource = "mybatis-config.xml";
	InputStream inputStream = Resources.getResourceAsStream(resource);
	SqlSessionFactory sessionFactory = new SqlSessionFactoryBuilder().build(inputStream);
	SqlSession session = sessionFactory.openSession();
	Employee employee = session.selectOne("com.wwj.mybatis.bean.Employee.selectEmp",1);
	System.out.println(employee);
	session.close();
通过全局的配置文件去创建一个SqlSessionFactory,并通过该对象获得SqlSession,就可以使用SqlSession进行增删改查了。这里调用了selectOne方法,表示从数据表中查询一行数据,其中的第一个参数需要填入刚才在sql映射文件中设置的id,但为了避免该id与其它sql语句重复,一般都会在id前加上namespace;第二个参数则是需要传入sql的参数。
增删改查的新方式
在入门案例中我们已经成功通过MyBatis查询了数据表的数据,但是这种方式的缺点也是显而易见的,为此,MyBatis提供了一种更加完美的方式来操作数据表。
定义一个接口:
package com.wwj.mybatis.dao;
public interface EmployeeMapper {
	public Employee getEmpById(Integer id);
MyBatis神奇的地方就在于你不需要去实现该接口,只需要将该接口与对应的sql映射文件绑定即可,MyBatis会自动创建代理对象调用对应的方法。
所以我们需要对sql的映射文件做一个小小的改动:
<!DOCTYPE mapper
<mapper namespace="com.wwj.mybatis.dao.EmployeeMapper">
 	<select id="getEmpById" resultType="com.wwj.mybatis.bean.Employee">
  	</select>
</mapper>
首先是namespace,现在该属性应该指向的是接口的全类名;然后是select标签的id属性,该属性也应该指向接口中对应的方法名,其它地方不变。
测试代码:
@Test
void test2() throws IOException{
	//Mybatis会为接口自动创建代理对象,并由代理对象执行增删改查
	EmployeeMapper mapper = session.getMapper(EmployeeMapper.class);
	Employee employee = mapper.getEmpById(1);
	session.close();
这里同样是通过全局配置文件创建SqlSessionFactory,并通过该对象获得SqlSession,不同的是,这里需要通过SqlSession对象调用getMapper方法去获得指定的接口的实现类,该实现类是MyBatis自动生成的代理对象,并通过该对象调用指定的方法完成数据表的操作。
通过properties标签引入外部属性文件
这个操作已经是再熟悉不过了,这里直接贴出代码:
<configuration>
	<!-- 使用properties标签引入外部的属性文件内容 -->
	<properties resource="dbconfig.properties"></properties>
        			<property name="driver" value="${jdbc.driver}"/>
        			<property name="url" value="${jdbc.url}"/>
      				<property name="username" value="${jdbc.username}"/>
        			<property name="password" value="${jdbc.password}"/>
      			</dataSource>
    	</environment>
	</environments>
	<mappers>
	</mappers>
</configuration>
typeAliases
这是一个全局配置文件的标签,通过该标签能够为某个Java类型设置别名,比如:
<typeAliases>
	<!-- type:指定要起别名的类型全类名,默认别名为类名字母小写:employee
		 也可以使用alias属性为其设置指定的别名
	<typeAlias type="com.wwj.mybatis.bean.Employee" alias="employee"/>
</typeAliases>
这样我们就可以修改sql映射文件中的返回值类型:
<select id="getEmpById" resultType="employee">
    select * from tbl_employee where id = #{id}
</select>
该标签还能够批量起别名,比如:
<typeAliases>
		批量起别名
	<package name="com.wwj.mybatis.bean"/>
</typeAliases>
若是子包下也有一个重名的类,则MyBatis会因为别名重复而报错,为此,可以通过@Alias注解在类上设置新的别名。
environments
全局配置文件标签,可以通过其子标签environment配置多种环境,比如:
      		</dataSource>
   	</environment>
    <environment id="test">
    	<transactionManager type="JDBC"></transactionManager>
    	<dataSource type="POOLED"></dataSource>
    </environment>
</environments>
environment需要配置两个子标签:transactionManager和dataSource,否则就会报错。
transactionManager标签的type属性可以指定两个属性值:
  1. JDBC:这个配置直接使用了 JDBC 的提交和回滚设施,它依赖从数据源获得的连接来管理事务作用域
  2. MANAGED:这个配置几乎没做什么。它从不提交或回滚一个连接,而是让容器来管理事务的整个生命周期(比如 JEE 应用服务器的上下文), 默认情况下它会关闭连接
dataSource标签的type属性可以指定三个属性值:
  1. UNPOOLED : 这个数据源的实现会每次请求时打开和关闭连接。虽然有点慢,但对那些数据库连接可用性要求不高的简单应用程序来说,是一个很好的选择。 性能表现则依赖于使用的数据库,对某些数据库来说,使用连接池并不重要,这个配置就很适合这种情形。
  2. POOLED: 这种数据源的实现利用“池”的概念将 JDBC 连接对象组织起来,避免了创建新的连接实例时所必需的初始化和认证时间。 这种处理方式很流行,能使并发 Web 应用快速响应请求
  3. JNDI: 这个数据源实现是为了能在如 EJB 或应用服务器这类容器中使用,容器可以集中或在外部配置数据源,然后放置一个 JNDI 上下文的数据源引用
mappers
sql映射文件标签,用于将sql映射注册到全局配置中,比如:
<mappers>
</mappers>
使用子标签mapper注册一个sql映射。
mapper还有一个用法, 就是注册接口,比如:
<mappers>
	<mapper class="com.wwj.mybatis.dao.EmployeeMapper"/>
</mappers>
需要注意的是,若要通过这样的方式注册接口,则需要将该sql映射文件名设置为与接口名一致,并与接口放在同一目录下。
mappers同样支持批量注册,使用package标签即可,若使用批量注册,sql映射文件也需要与接口同目录,否则MyBatis将无法找到文件而报错。
增删改查
熟悉了MyBatis配置文件中的一些标签后,我们来看看MyBatis是如何实现增删改查操作的?
插入数据
仿照着实现查询的方式,我们很容易写出增删改查,先修改接口:
	public void addEmp(Employee employee);
	public void updateEmp(Employee employee);
	public void deleteEmp(Integer id);
在接口中新添加了三个方法,分别对应着增删改。
然后修改sql映射文件:
<!DOCTYPE mapper
  	</select>
  	<insert id="addEmp" parameterType="com.wwj.mybatis.bean.Employee">
  		insert into tbl_employee(last_name,email,gender) values(#{lastName},#{email},#{gender})
  	</insert>
  	<update id="updateEmp">
  		update tbl_employee set last_name = #{lastName},email = #{email},gender = #{gender} where id = #{id}
  	</update>
  	<delete id="deleteEmp">
  		delete from tbl_employee where id = #{id}
  	</delete>
</mapper>
这已经很简单了,无需做过多解释,唯一要说的是parameterType属性,该属性的作用是指定方法参数的类型,该属性可以省略不写。这样准备工作就完成了,来测试一下:
@Test
void test3() throws IOException{
	Employee employee = new Employee(null,"Jack","jack@163.com","1");
	mapper.addEmp(employee);
	session.commit();
	session.close();
需要注意的是,SqlSession是不会自动提交数据的,所以在进行增删改操作的时候,最后一定要记得提交。
删除数据
做删除操作只需要改变一下调用的方法即可:
@Test
	mapper.deleteEmp(2);
	session.commit();
	session.close();
修改数据
修改数据同样是这样:
@Test
	Employee employee = new Employee(1,"Jack","jack@163.com","0");
	mapper.updateEmp(employee);
	session.commit();
	session.close();
Mybatis还直接允许增删改操作直接定义以下返回值:Integer、Long、Boolean,直接在接口方法上定义即可,比如:
	public Long addEmp(Employee employee);
查询数据
查询就不说了,入门案例已经写过了。
获取自增主键的值
MyBatis支持获取自增主键的值,而且非常方便:
<insert id="addEmp" useGeneratedKeys="true" keyProperty="id">
</insert>
只需要设置useGeneratedKeys属性值为true即可,MyBatis就会将主键的值封装到keyProperty属性指定的参数中,这里指定了id,表示将自增主键的值获取出来并存入Employee对象的id属性中,接下来要想获取主键的值就可以直接获取该对象的id属性了。
参数处理
下面介绍一下MyBatis对于参数的处理,在前面的案例中,我们都是通过#{参数名}的方式来获取参数,而事实上,对于单个的参数,MyBatis不会对其进行特殊处理,这个参数名是可以随便写的,写个a、b、c都可以,比如:
    select * from tbl_employee where id = #{aaa}
</select>
那么对于多参数的方法该如何处理呢?
	//新增一个多参数的方法
	public Employee getEmpByIdAndLastName(String id,String lastName);
在接口中新增一个getEmpByIdAndLastName方法,并添加对应的sql配置:
<select id="getEmpByIdAndLastName" resultType="employee">
 	select * from tbl_employee where id = #{id} and last_name = #{lastName}
</select>
可能大家会想当然地这样写,但告诉大家,这样是错误的。
MyBatis会对多个参数进行特殊处理,将这些参数封装成一个map,所以我们需要从map中取值,如下:
 	select * from tbl_employee where id = #{param1} and last_name = #{param2}
</select>
MyBatis有着自己的封装规则,它将传递过来的参数封装到map中,指定键为:param1、param2、param3...,而这些键对应的就是我们需要取出的值。
当然,你也可以这样写:
 	select * from tbl_employee where id = #{0} and last_name = #{1}
</select>
通过索引获取map中的值。
命名参数
这两种获取参数方式的缺点是显而易见的,当参数足够多时,这样的参数名会使开发者眼花缭乱,为此,我们应该使用命名参数的方式进行参数值的获取。
这里需要借助@Param注解对map的键重命名:
//新增一个多参数的方法
public Employee getEmpByIdAndLastName(@Param("id")String id,@Param("lastName")String lastName);
这样我们就能直接通过指定的参数名从map中获取值了:
</select>
处理POJO
若是传入的参数过多,而且正好符合业务逻辑的模型对象,我们就可以直接传入POJO,在取出数据值的时候就可以直接使用POJO的属性名:#{POJO属性名}。
而如果多个参数并不符合模型对象,为了方便,我们也可以自己将其封装成一个map,比如:
//新增一个多参数的方法
public Employee getEmpByIdAndLastName(Map<String, Object> map);
那么你在传递参数的时候就需要传递一个map:
@Test
void test4() throws IOException{
	Map<String, Object> map = new HashMap<String, Object>();
	map.put("id", "1");
	map.put("lastName", "Jack");
	Employee employee = mapper.getEmpByIdAndLastName(map);
	session.close();
而在取出map数据的时候就可以直接通过键获取:
</select>
特别需要注意的是,Mybatis会对Collection类型及数组做特殊处理,比如:
public Employee getEmpById(List<Integer> ids);
该参数是一个id的集合,若是想从该集合中获取第一个id的值,则需要#{list[0]}。
因为对于Collection类型,包括:Collection、List、Set,MyBatis都会将其封装到map中,其对应的键为collection,如果是List类型,还可以使用list作为键,数组的键为array。
#{}与${}的区别
MyBatis中除了可以使用#{}取值外,还可以使用${},它们的用法是相同的,那么这两种方式到底有什么区别呢?
我分别用#{}和${}进行取值,并执行测试代码,下面是运行结果:
DEBUG 04-16 13:46:27,992 ==>  Preparing: select * from tbl_employee where id = ? and last_name = ?   (BaseJdbcLogger.java:145)
DEBUG 04-16 14:31:13,054 ==>  Preparing: select * from tbl_employee where id = 1 and last_name = Jack   (BaseJdbcLogger.java:145)
会发现,两者的区别在于,${}会将传递的参数显示到生成的sql语句上。
select元素
select标签用来定义查询操作,其中有三个比较重要的参数:
  1. id:唯一标识符,用来引用这条语句,需要与接口的方法名一致
  2. parameterType:参数类型,可以不传,MyBatis会根据TypeHandler自动判断
  3. resultType:返回值类型,别名或者全类名,如果返回的是集合,则写的是集合中元素的类型;不能与resultMap同时使用
在前面的案例中,我们已经使用过select标签,接下来让我们深入了解一下该标签。
比如在接口中定义这样的一个方法:
public List<Employee> getEmpsByLastNameLike(String lastName);
该方法的返回值是集合类型,那么在编写sql配置的时候就得这样写:
<select id="getEmpsByLastNameLike" resultType="employee">
 	select * from tbl_employee where last_name like #{lastName}
</select>
resultType写的是集合中的元素类型。
若凡返回值是map类型,比如:
public Map<String,Object> getEmpMapById(Integer id);
sql配置应该这样写:
<select id="getEmpMapById" resultType="map">
</select>
resultType写的是map,为什么能够直接写map而不用写全类名,因为MyBatis已经帮我们取好了别名。
通过这样的方式,MyBatis会将表中的列名和记录作为键和值一一封装到map中。
我们还可以通过返回map来查询表中的某一行数据,并直接将其封装成对象返回:
@MapKey("id")
public Map<Integer,Employee> getEmpByLastNameLike(String lastName);
该方法能将查询到的每一行数据封装成一个对象,其键由@MapKey注解指定,比如这里是指定以id为键,接下来是sql配置:
<select id="getEmpByLastNameLike" resultType="employee">
</select>
resultType同样是集合元素类型,但是通过该sql查询返回的结果将是以id为键,对应的行数据为值的map集合。
当然,select标签可不止id、parameterType和resultType这三个参数,下面介绍一下该标签的一些其它参数。
resultMap
我们知道,通过resultType指定返回值类型后,MyBatis会自动将得到的数据封装进去,然而当数据表的列名和返回值属性不一致时,就会导致封装失败,这时候我们会有两种办法:一种就是设置别名;另一种就是使用resultMap来自定义返回值类型。
比如:
按照之前的写法,应该是这样:
 </select>
但现在,倘若Employee类中的某些属性名和表中的列名并不一致,此时MyBatis将无法进行自动封装,我们就需要通过resultMap来自定义封装规则。
<!-- 自定义某个JavaBean的封装规则 -->
<resultMap type="employee" id="emp">
 		指定主键列的封装规则
 		column:指定哪一列
 		property:指定对应的JavaBean属性
 	<id column="id" property="id"/>
 	<!-- 指定非主键列的封装规则 -->
 		<result column="last_name" property="lastName"/>
 		<result column="email" property="email"/>
 		<result column="gender" property="gender"/>
 	</resultMap>
<select id="getEmpById" resultMap="emp">
</select>
事实上,对于主键列,你也可以使用result标签来指定规则, 但是使用id标签的好处就是MyBatis会知道该属性是主键从而自动设置一些功能,对于一些属性名和列名已经一致的属性,你也可以不进行自定义,MyBatis还是会自动进行封装的。
resultMap可以用来解决数据表的联合查询问题,现有两张数据表,一张员工表:
| Field     | Type         | Null | Key | Default | Extra          |
| id        | int(11)      | NO   | PRI | NULL    | auto_increment |
| last_name | varchar(255) | YES  |     | NULL    |                |
| gender    | char(1)      | YES  |     | NULL    |                |
| email     | varchar(255) | YES  |     | NULL    |                |
| d_id      | int(11)      | YES  | MUL | NULL    |                |
一张部门表:
| dept_name | varchar(255) | YES  |     | NULL    |                |
其中员工表的d_id列与部门表的id列存在外键约束关系。
若有这样的需求,查询员工表的某位员工信息,同时查出它的部门信息,该需求涉及到联合查询的问题,resultMap则能够很好地解决这一问题。
首先我们创建两张数据表对应的类,员工类:
	private Integer id;
	private Department department;
    public Employee() {
	public Department getDepartment() {
		return department;
	public void setDepartment(Department department) {
		this.department = department;
		return id;
		this.id = id;
		return lastName;
		return email;
		this.email = email;
		return gender;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
部门类:
public class Department {
	private Integer id;
	private String departmentName;
		return id;
		this.id = id;
	public String getDepartmentName() {
		return departmentName;
	public void setDepartmentName(String departmentName) {
		this.departmentName = departmentName;
那么接下来就非常简单了,在接口中定义查询方法:
public Employee getEmpAndDept(Integer id);
编写sql配置:
<resultMap type="employee" id="empy">
 	<result column="did" property="dept.id"/>
 	<result column="dept_name" property="dept.departmentName"/>
</resultMap>
<select id="getEmpAndDept" resultMap="empy">
	select * from tbl_employee e,tbl_dept d where e.d_id=d.id and e.id=#{id}
</select>
这里通过级联属性为部门类的属性定义规则。
除了级联属性,你也可以使用association标签来定义规则:
 		association可以指定联合的Java对象
		property:指定哪个属性为联合的Java对象
		javaType:指定联合Java对象的类型
 	<association property="dept" javaType="com.wwj.mybatis.bean.Department">
 		<id column="did" property="id"/>
 		<result column="dept_name" property="departmentName"/>
 	</association>
</resultMap>
</select>
而有些情况,我们在查询员工信息的时候并不需要查询它的部门信息,此时可以使用延迟加载,实现非常简单,在MyBatis的配置文件中进行两个配置即可:
<settings>
	<setting name="lazyLoadingEnabled" value="true"></setting>
	<setting name="aggressiveLazyLoading" value="false"/>
</settings>
此时当我们不去查询员工的部门信息时,Mybatis就不会发送sql去查询部门表,避免了资源的浪费。
而当查询对象中包含集合数据时,比如:
	private Integer id;
	private List<Employee> emps;
	public List<Employee> getEmps() {
		return emps;
	public void setEmps(List<Employee> emps) {
		this.emps = emps;
		return id;
		this.id = id;
	@Override
		return "Department [id=" + id + ", departmentName=" + departmentName + ", emps=" + emps + "]";
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
一个部门包含若干员工,这些员工将封装到一个集合中,该如何对其进行处理呢?
在接口中定义方法:
public Department getDeptById(Integer id);
sql配置:
<resultMap type="com.wwj.mybatis.bean.Department" id="MyDept">
 	<collection property="emps" ofType="com.wwj.mybatis.bean.Employee">
 		<!-- 定义集合中的元素封装规则 -->
 		<id column="eid" property="id"/>
 	</collection>
 </resultMap>
 <!-- 查询部门的时候将部门对应的所有员工信息查询出来 -->
 <select id="getDeptById" resultMap="MyDept">
 	SELECT * FROM tbl_dept d LEFT JOIN tbl_employee e ON d.id=e.d_id WHERE d.id=#{id}
 </select>
其中collection用于定义集合中的元素封装规则,ofType属性指定集合的元素类型。
文章来源: blizzawang.blog.csdn.net,作者:·wangweijun,版权归原作者所有,如需转载,请联系作者。
原文链接:blizzawang.blog.csdn.net/article/details/105820573
