数据结构哈夫曼树和哈夫曼编码 适合新手学习因为本人也是新手,嘻嘻嘻
肥学 发表于 2022/03/29 00:12:56 2022/03/29
【摘要】 哈夫曼树和哈夫曼编码 给大家两句口诀 “选择两小造新树,删除两小造新人” 先看懂图这里有篇代码 大家可以对照一下 都是大同小异 #include <stdio.h> #include...
哈夫曼树和哈夫曼编码
大家要先看懂这两张图
第二张
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <conio.h>
#define MAX  17
typedef struct
	unsigned int weight;
	unsigned int parent, lchild, rchild;
}HTnode, *Huffmantree;
typedef char * *Huffmancode;
void select(Huffmantree HT, int n, int *s1, int *s2)
	int i, t;
	t = 1000;
	for (i = 1; i <= n; i++)
		if (HT[i].parent == 0 && HT[i].weight < t)
			t = HT[i].weight;
			*s1 = i;
	t = 1000;
		if (HT[i].parent == 0 && HT[i].weight < t&&i!= *s1)
			t = HT[i].weight;
			*s2 = i;
void Huffmancoding(Huffmantree HT, Huffmancode HC, int *w, int n)
	int p1, q2;
	int *s1, *s2;
	int m, i, f, start, c;
	char *cd;
	Huffmantree p;
	s1 = &p1;
	s2 = &q2;
	if (n <= 1)  return;
	m = 2 * n - 1;     w = w + 1;
	HT = (Huffmantree)malloc((m + 1) * sizeof(HTnode));
	for (p = HT + 1, i = 1; i <= n; ++i, ++p, ++w)
		p->weight = *w;  p->parent = 0;  p->lchild = 0;   p->rchild = 0;
	for (; i <= m; ++i, ++p)
		p->weight = 0;   p->parent = 0;  p->lchild = 0;   p->rchild = 0;
	for (i = n + 1; i <= m; ++i)
		select(HT, i - 1, s1, s2);
		HT[p1].parent = i;
		HT[q2].parent = i;
		HT[i].lchild = p1;
		HT[i].rchild = q2;
		HT[i].weight = HT[p1].weight + HT[q2].weight;
	HC = (Huffmancode)malloc((n + 1) * sizeof(char *));
	cd = (char *)malloc(n * sizeof(char));
	cd[n - 1] = '\0';
	for (i = 1; i <= n; ++i)
		start = n - 1;
		for (c = i, f = HT[i].parent; f != 0; c = f, f = HT[f].parent)
			if (HT[f].lchild == c) cd[--start] = '0';
			else cd[--start] = '1';
		HC[i] = (char *)malloc((n - start) * sizeof(char));
		strcpy(HC[i], &cd[start]);
	free(cd);
	printf("Print the Huffmantree:\n");
	printf("  weight  parent  lchild  rchild\n");
	for (i = 1; i <= 2 * n - 1; i++)
		printf("%2d  %3d     %3d", i, HT[i].weight, HT[i].parent);
		printf("     %3d     %3d\n", HT[i].lchild, HT[i].rchild);
	printf("Print the Humancode :\n");
	for (i = 1; i < n + 1; i++)
		printf("the code of %2d is %s\n", i, HC[i]);
void main()
	Huffmantree HT = NULL;
	Huffmancode HC = NULL;
	int n = 1, data, i, w[MAX];
	printf("Please input the weight of the elements of huffmantree (input -1 to exit)\n");
	scanf_s("%d", &data);
	while (data != -1)
		w[n] = data;
		n++;
	n = n - 1;
	Huffmancoding(HT, HC, w, n);
	_getch();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
#include<stdio.h>
#include<iostream>
#include<malloc.h>
#include<stdlib.h>
#include<string.h>
#include<algorithm>//算法,头文件包含求最大最小等
#define MAX_NUM 100//最大数字个数为100
#define inf 2000000000 //最大值为
using namespace std;
typedef struct {
	unsigned int weight;//权值 数字无符号
	unsigned int parent, lchild, rchild;//父节点,孩子结点的权值
}HTNode, *HuffmanTree;
typedef char * * HuffmanCode;//二维字符数组
int s1, s2;//最小的两个结点
void Select(HuffmanTree &HT, int x)
{//选出无父结点,并且权值最小的两个结点,赋值给s1,s2
	int i, min1 = inf, min2 = inf;
	for (i = 1; i <= x; i++) {//找最小
		if (HT[i].weight < min1&&HT[i].parent == 0)
			 min1 = HT[i].weight;
			 s1 = i;//选出该权值是第几个
	for (i = 1; i <= x; i++) {//找次小
		if (HT[i].weight < min2&&i != s1 && HT[i].parent == 0)
			min2 = HT[i].weight;
			s2 = i;
void HuffmanCoding(HuffmanTree &HT, HuffmanCode &HC, int *w, int n)
 {//根据输入的结点的权值和个数来构建赫夫曼树 //创建数 和编码的地址
	if (n <= 1)return;
	int m = 2 * n - 1;//n个叶子,有2*n-1个结点
	int i;
	HT = (HuffmanTree)malloc((m + 1) * sizeof(HTNode));//0号单元未用 开辟空间
	HuffmanTree p;
	for (p = HT + 1, i = 1; i <= n; i++, p++, w++)
	{//叶子结点赋值
	for (; i <= m; i++, p++)
	{//非叶子结点初始化
	for (i = n + 1; i <= m; i++)
		Select(HT, i - 1);//选出最小的两个无父节点的结点
		HT[s1].parent = i; //找到第I个节点做双亲节点
		HT[s2].parent = i;
		HT[i].lchild = s1; //选择两个最小的来做左右孩子
		HT[i].rchild = s2;
		HT[i].weight = HT[s1].weight + HT[s2].weight;
HC = (HuffmanCode)malloc((n + 1) * sizeof(char *));//申请一段以HC为首地址的内存,可以看成二维字符数组 ,这里先申请了第一维
	char *cd = (char *)malloc(n * sizeof(char));//申请一段临时工作空间
	cd[n - 1] = '\0';//编码结束符
	for (i = 1; i <= n; i++) {
		int start = n - 1, c, f;
		for (c = i, f = HT[i].parent; f != 0; c = f, f = HT[f].parent) {//从叶子到根逆向求编码
			cd[--start] = '0';//如果当前结点是父节点的左孩子,则存一个1
			else
			cd[--start] = '1';//反之
		HC[i] = (char *)malloc((n - start) * sizeof(char));//申请第二维
		strcpy(HC[i], &cd[start]);//将编码从工作空间存入赫夫曼编码表中
	free(cd); //释放临时空间
int main() {
	HuffmanTree HT;//自定义结构体  ht
	HuffmanCode HC;
	int w[MAX_NUM], n;
	int i;
	printf("输入结点的个数:\n");
	scanf_s("%d", &n);
	printf("输入每个结点的权值:\n");
	for (i = 0; i < n; i++)
		scanf_s("%d", &w[i]);
	HuffmanCoding(HT, HC, w, n);
		printf("%d的赫夫曼编码为:%s\n", HT[i].weight, HC[i]);
	return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
文章来源: blog.csdn.net,作者:肥学,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jiahuiandxuehui/article/details/110200699
