【Nginx】Nginx下的Yii部署
小雨青年 发表于 2022/03/29 00:14:17 2022/03/29
【摘要】 Url的重写 nginx的配置文件 [root@localhost protected]# vim /etc/nginx/conf.d/default.conf server { listen 80; server_name localhost; #charset koi8-r; ...
Url的重写
nginx的配置文件
server {
    listen       80;
    #charset koi8-r;
    #access_log  /var/log/nginx/log/host.access.log  main;
    location = /favicon.ico {
        log_not_found off;
        access_log off;
    location = /robots.txt {
        allow all;
        log_not_found off;
        access_log off;
    location / {
        try_files $uri $uri/ /index.php?$args;
        if (!-e $request_filename){
        rewrite ^/(.*) /index.php last;
        root   /usr/share/nginx/html;
        index  index.php  index.html  index.htm;
    location ~ /(protected|framework|nbproject|themes/\w+/views|index-test\.php) {
        deny all;
        # for production
        internal;
        log_not_found off;
        access_log off;
    #error_page  404              /404.html
文章来源: coderfix.blog.csdn.net,作者:小雨青年,版权归原作者所有,如需转载,请联系作者。
原文链接:coderfix.blog.csdn.net/article/details/42423421
