【Github】GPG密钥的使用以及和SSH密钥的区别
小雨青年 发表于 2022/03/28 23:23:40 2022/03/28
【摘要】 环境 macOS 10.13.6 (17G65) 创建GPG密钥 Github支持下面的加密协议的GPG密钥 RSAElGamalDSAECDHECDSAEdDSA 安装gnupg ...
环境
创建GPG密钥
  • RSA
  • ElGamal
  • DSA
  • ECDH
  • ECDSA
  • EdDSA
安装gnupg
从https://www.gnupg.org/download/ 中下载gnupg
gnupg链接为 https://www.gnupg.org/ftp/gcrypt/gnupg/gnupg-2.2.9.tar.bz2
./configure
configure:
*** You need libgpg-error to build this program.
**  This library is for example available at
***   https://gnupg.org/ftp/gcrypt/libgpg-error
*** (at least version 1.24 is required.)
configure:
*** You need libgcrypt to build this program.
***   https://gnupg.org/ftp/gcrypt/libgcrypt/
*** (at least version 1.7.0 (API 1) is required.)
configure:
*** You need libassuan to build this program.
*** This library is for example available at
***   https://gnupg.org/ftp/gcrypt/libassuan/
*** (at least version 2.5.0 (API 2) is required).
configure:
*** You need libksba to build this program.
***   https://gnupg.org/ftp/gcrypt/libksba/
*** (at least version 1.3.4 using API 1 is required).
configure:
*** It is now required to build with support for the
*** New Portable Threads Library (nPth). Please install this
*** library first.  The library is for example available at
***   https://gnupg.org/ftp/gcrypt/npth/
*** (at least version 1.2 (API 1) is required).
configure: error:
*** Required libraries not found. Please consult the above messages
*** and install them before running configure again.
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
也就是我们要安装下面几个软件
libgpg-error
最低版本 1.24
访问网站 https://gnupg.org/ftp/gcrypt/libgpg-error/
 wget https://gnupg.org/ftp/gcrypt/libgpg-error/libgpg-error-1.32.tar.bz2
lixiaoyudeMBP:soft lxy$ tar -jxvf libgpg-error-1.32.tar.bz2
lixiaoyudeMBP:libgpg-error-1.32 lxy$ cd libgpg-error-1.32
lixiaoyudeMBP:libgpg-error-1.32 lxy$ ./configure
lixiaoyudeMBP:libgpg-error-1.32 lxy$ make && make install
make[3]: Nothing to be done for `install-exec-am'.
 ../../build-aux/install-sh -c -d '/usr/local/share/common-lisp/source/gpg-error'
 /usr/bin/install -c -m 644 gpg-error.asd gpg-error-package.lisp gpg-error.lisp '/usr/local/share/common-lisp/source/gpg-error'
 /usr/bin/install -c -m 644 gpg-error-codes.lisp '/usr/local/share/common-lisp/source/gpg-error'
make[3]: Nothing to be done for `install-data-am'.
make[2]: Nothing to be done for `install-exec-am'.
/Library/Developer/CommandLineTools/usr/bin/make  install-data-hook
make[3]: Nothing to be done for `install-data-hook'.
libgcrypt
最低版本 1.7.0 (API 1)
访问网站 https://gnupg.org/ftp/gcrypt/libgcrypt/
lixiaoyudeMBP:libgcrypt-1.8.3 lxy$ wget https://gnupg.org/ftp/gcrypt/libgcrypt/libgcrypt-1.8.3.tar.bz2
lixiaoyudeMBP:libgcrypt-1.8.3 lxy$ tar -jxvf libgcrypt-1.8.3.tar.bz2
lixiaoyudeMBP:libgcrypt-1.8.3 lxy$ cd libgcrypt-1.8.3
lixiaoyudeMBP:libgcrypt-1.8.3 lxy$ ./configure
        Libgcrypt v1.8.3 has been configured as follows:
        Platform:                  Darwin (x86_64-apple-darwin17.7.0)
        Hardware detection module: hwf-x86
        Enabled cipher algorithms: arcfour blowfish cast5 des aes twofish
                                   serpent rfc2268 seed camellia idea salsa20
                                   gost28147 chacha20
        Enabled digest algorithms: crc gostr3411-94 md4 md5 rmd160 sha1
                                   sha256 sha512 sha3 tiger whirlpool stribog
                                   blake2
        Enabled kdf algorithms:    s2k pkdf2 scrypt
        Enabled pubkey algorithms: dsa elgamal rsa ecc
        Random number generator:   default
        Try using jitter entropy:  yes
        Using linux capabilities:  no
        Try using Padlock crypto:  yes
        Try using AES-NI crypto:   yes
        Try using Intel PCLMUL:    yes
        Try using Intel SSE4.1:    yes
        Try using DRNG (RDRAND):   yes
        Try using Intel AVX:       yes
        Try using Intel AVX2:      yes
        Try using ARM NEON:        n/a
        Try using ARMv8 crypto:    n/a
lixiaoyudeMBP:libgcrypt-1.8.3 lxy$ make && make install
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
libassuan
最低版本 2.5.0 (API 2)
访问网站 https://gnupg.org/ftp/gcrypt/libassuan/
lixiaoyudeMBP:soft lxy$ wget https://gnupg.org/ftp/gcrypt/libassuan/libassuan-2.5.1.tar.bz2
lixiaoyudeMBP:soft lxy$ tar -jxvf libassuan-2.5.1.tar.bz2
lixiaoyudeMBP:soft lxy$ cd libassuan-2.5.1
lixiaoyudeMBP:libassuan-2.5.1 lxy$ ./configure
Libassuan v2.5.1 has been configured as follows:
        Revision: 8fc922c  (36809)
        Platform: x86_64-apple-darwin17.7.0
lixiaoyudeMBP:libassuan-2.5.1 lxy$ make && make install
libksba
最低版本 1.3.4 using API 1
访问网站
lixiaoyudeMBP:libksba-1.3.5 lxy$ wget https://gnupg.org/ftp/gcrypt/libksba/libksba-1.3.5.tar.bz2
lixiaoyudeMBP:libksba-1.3.5 lxy$ tar -jxvf libksba-1.3.5.tar.bz2
lixiaoyudeMBP:libksba-1.3.5 lxy$ cd libksba-1.3.5
lixiaoyudeMBP:libksba-1.3.5 lxy$ ./configure
        Libksba v1.3.5 has been configured as follows:
        Revision:  25cc42c  (9676)
lixiaoyudeMBP:libksba-1.3.5 lxy$ make && make install
npth
最低版本 1.2 (API 1)
访问网站 https://gnupg.org/ftp/gcrypt/npth/
lixiaoyudeMBP:soft lxy$ wget https://gnupg.org/ftp/gcrypt/npth/npth-1.6.tar.bz2
lixiaoyudeMBP:soft lxy$ tar -jxvf npth-1.6.tar.bz2
lixiaoyudeMBP:soft lxy$ cd npth-1.6
lixiaoyudeMBP:npth-1.6 lxy$ ./configure
        npth v1.6 prepared for make
        Revision: 7712879  (30482)
lixiaoyudeMBP:npth-1.6 lxy$ make && make install
再次编译gnupg
lixiaoyudeMBP:gnupg-2.2.9 lxy$ ./configure
        GnuPG v2.2.9 has been configured as follows:
        Revision:  2b82db61c  (11138)
        OpenPGP:   yes
        S/MIME:    yes
        Agent:     yes
        Smartcard: yes (without internal CCID driver)
        G13:       no
        Dirmngr:   yes
        Gpgtar:    yes
        WKS tools: no
        Protect tool:      (default)
        LDAP wrapper:      (default)
        Default agent:     (default)
        Default pinentry:  (default)
        Default scdaemon:  (default)
        Default dirmngr:   (default)
        Dirmngr auto start:  yes
        Readline support:    no
        LDAP support:        yes
        TLS support:         no
        TOFU support:        no
        Tor support:         yes
lixiaoyudeMBP:gnupg-2.2.9 lxy$ make && make install
mkdir: /usr/local/libexec: Permission denied
make[2]: *** [install-libexecPROGRAMS] Error 1
make[1]: *** [install-am] Error 2
make: *** [install-recursive] Error 1
lixiaoyudeMBP:gnupg-2.2.9 lxy$ sudo su root
Password:
sh-3.2# make && make install
 build-aux/install-sh -c -d '/usr/local/share/doc/gnupg'
 /usr/bin/install -c -m 644 README '/usr/local/share/doc/gnupg'
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
验证邮箱
在Github个人页面中选择Emails -> Send verification email
生成密钥
lixiaoyudeMBP:~ lxy$ gpg --full-generate-key
gpg (GnuPG) 2.2.9; Copyright (C) 2018 Free Software Foundation, Inc.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Please select what kind of key you want:
   (1) RSA and RSA (default)
   (2) DSA and Elgamal
   (3) DSA (sign only)
   (4) RSA (sign only)
Your selection? 1
RSA keys may be between 1024 and 4096 bits long.
What keysize do you want? (2048) 4096
Requested keysize is 4096 bits
Please specify how long the key should be valid.
         0 = key does not expire
      <n>  = key expires in n days
      <n>w = key expires in n weeks
      <n>m = key expires in n months
      <n>y = key expires in n years
Key is valid for? (0) 0
Key does not expire at all
Is this correct? (y/N) y
GnuPG needs to construct a user ID to identify your key.
Real name: ********@qq.com
Name may not start with a digit
Real name: calvin
Email address: ********@qq.com
Comment: Xiaoyu
You selected this USER-ID:
    "calvin (Xiaoyu) <********@qq.com>"
Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o
We need to generate a lot of random bytes. It is a good idea to perform
some other action (type on the keyboard, move the mouse, utilize the
disks) during the prime generation; this gives the random number
generator a better chance to gain enough entropy.
gpg: agent_genkey failed: No pinentry
Key generation failed: No pinentry
lixiaoyudeMBP:~ lxy$ unset DISPLAY
lixiaoyudeMBP:~ lxy$ sudo gpg --list-secret-keys --keyid-format LONG
lixiaoyudeMBP:~ lxy$ brew install pinentry
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
再次重试
lixiaoyudeMBP:~ lxy$ sudo gpg --full-generate-key
Password:
   (2) DSA and Elgamal
   (3) DSA (sign only)
   (4) RSA (sign only)
Your selection? 1
Real name: calvin
Email address: ***************@qq.com
Comment: Xiaoyu
    "calvin (Xiaoyu) <***************@qq.com>"
gpg: /Users/lxy/.gnupg/trustdb.gpg: trustdb created
gpg: key 26AD3F854E18718F marked as ultimately trusted
gpg: directory '/Users/lxy/.gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/Users/lxy/.gnupg/openpgp-revocs.d/***************.rev'
public and secret key created and signed.
pub   rsa4096 2018-07-21 [SC]
uid                      calvin (Xiaoyu) <***************@qq.com>
sub   rsa4096 2018-07-21 [E]
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
在上面期间要输入密码
这里写图片描述
查看密钥
gpg: checking the trustdb
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
/Users/lxy/.gnupg/pubring.kbx
sec   rsa4096/26AD3F854E18718F 2018-07-21 [SC]
      ***********  //拿着这个在下面作为参数
uid                 [ultimate] calvin (Xiaoyu) <*******@qq.com>
ssb   rsa4096/55B0ED84AFE603E4 2018-07-21 [E]
lixiaoyudeMBP:~ lxy$ sudo gpg --armor --export ***********
-----BEGIN PGP PUBLIC KEY BLOCK-----
mQINBFtTVB0BEAC0QjmqPO7EUW6rtLv6Htaje+sY19eUvv4I844BlGg0e4l1bd6b
1WsJSTtVO++3K9hBpeaIitfON3ClEK91db8zFnxXYjK/4GrVyQb460vp4riKDJCv
GO39PnOYieRAoV/3PbfPjEJR7hL/NexIOev2Rz8bFc17lQMkBXbH7pr7jQSCJg==
=djPM
-----END PGP PUBLIC KEY BLOCK-----
上面的结果中间的部分就是公钥的部分。我们将这部分放到下面的页面中,就可以了。
这里写图片描述
这里写图片描述
优点
  • 可以设置过期时间
缺点
  • 初始配置环境比较麻烦
文章来源: coderfix.blog.csdn.net,作者:小雨青年,版权归原作者所有,如需转载,请联系作者。
原文链接:coderfix.blog.csdn.net/article/details/81147966
