【前端】优化网页样式之Reset CSS
小雨青年 发表于 2022/03/28 23:36:34 2022/03/28
【摘要】 Reset CSS的目的在于 去掉元素默认样式中不符合审美的部分调整整个页面的基线有利于页面元素的样式修改 下面给出一个参考,你可以随意变更内容使其符合自己的项目需要 html, body, di...
Reset CSS的目的在于
  • 去掉元素默认样式中不符合审美的部分
  • 调整整个页面的基线
  • 有利于页面元素的样式修改
html, body, div, span, applet, object, iframe,
h1, h2, h3, h4, h5, h6, p, blockquote, pre,
a, abbr, acronym, address, big, cite, code,
del, dfn, em, img, ins, kbd, q, s, samp,
small, strike, strong, sub, sup, tt, var,
b, u, i, center,
dl, dt, dd, ol, ul, li,
fieldset, form, label, legend,
table, caption, tbody, tfoot, thead, tr, th, td,
article, aside, canvas, details, embed,
figure, figcaption, footer, header, hgroup,
menu, nav, output, ruby, section, summary,
time, mark, audio, video {
    margin: 0;
    padding: 0;
    border: 0;
    font-size: 100%;
    font: inherit;
    vertical-align: baseline;
article, aside, details, figcaption, figure,
footer, header, hgroup, menu, nav, section {
    display: block;
body {
    line-height: 1;
ol, ul {
    list-style: none;
blockquote, q {
    quotes: none;
blockquote:before, blockquote:after,
q:before, q:after {
    content: '';
    content: none;
table {
    border-collapse: collapse;
    border-spacing: 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
文章来源: coderfix.blog.csdn.net,作者:小雨青年,版权归原作者所有,如需转载,请联系作者。
原文链接:coderfix.blog.csdn.net/article/details/80997177
