STM32串口配置(1,2,3,4)
嵌入式与Linux那些事 发表于 2022/03/29 00:45:20 2022/03/29
【摘要】    调试程序时,发现代码里面用的是串口1,但是硬件上用的串口2。所以需要改动下,总结了关于STM32四个串口配置的代码(初始化+中断配置+中断接收函数)。 1.串口1 /*=============...
1.串口1
Copyright:
Version:
Author:
Date: 2017/11/3
Description:
    配置独立看门狗初始化函数,在主函数中运行IWDG_ReloadCounter进行喂狗主函数必须在4s内进行一次喂狗不然系统会复位;
    函数功能是将接收固定长度的字符串,并将接收后的字符串通过串口发送出去
revise Description:
#include "stm32f10x_usart.h"
#include "stm32f10x.h"
#include "stm32f10x_iwdg.h"
u8 USART1_RX_BUF[21];
u8 USART1_RX_CNT=0;
void IWDG_Configuration(void);
void Usart1_Init(u32 bound)
    //GPIO端口设置
    GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC, ENABLE);//使能USART1,GPIOA,C时钟
    //USART1_TX   GPIOA.9
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //复用推挽输出
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
    //USART1_RX      GPIOA.10初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
    GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
    //Usart1 NVIC 配置
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);    //设置NVIC中断分组2:2位抢占优先级,2位响应优先级   0-3;
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;        //子优先级3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //IRQ通道使能
    NVIC_Init(&NVIC_InitStructure);    //根据指定的参数初始化VIC寄存器
   //USART 初始化设置
    USART_InitStructure.USART_BaudRate = bound;//串口波特率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
    USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;    //收发模式
    USART_Init(USART1, &USART_InitStructure); //初始化串口1
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
    USART_Cmd(USART1, ENABLE);                    //使能串口1
* USART1发送len个字节.
* buf:发送区首地址
* len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
void USART1_Send_Data(u8 *buf,u16 len)
    u16 t;
    GPIO_SetBits(GPIOC,GPIO_Pin_9);
//  RS485_TX_EN=1;            //设置为发送模式
    for(t=0;t<len;t++)        //循环发送数据
        while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET); //循环发送,直到发送完毕
        USART_SendData(USART1,buf[t]);
    while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
    GPIO_ResetBits(GPIOC,GPIO_Pin_9);
//    RS485_TX_EN=0;                //设置为接收模式
void main(void)
    Usart1_Init(9600);//串口1波特率设置为9600
    IWDG_Configuration();
    while(1)
        IWDG_ReloadCounter();//4s内必须喂狗不然复位
        if(USART1_RX_CNT==21)//数据接收完成
            USART1_RX_CNT=0;//指针复位
            //将接收到的数据发送出去
            USART1_Send_Data(USART1_RX_BUF,21);//通过串口1将接收到的固定长度字符发送出去
* 接收指定长度的字符串
* 比如接收固定大小为21个字节的字符串
void USART1_IRQHandler(void)                    //串口1中断服务程序
    u8 Res;
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
            Res =USART_ReceiveData(USART1);    //读取接收到的数据
            if(USART1_RX_CNT<21)//对于接收指定长度的字符串
                USART1_RX_BUF[USART1_RX_CNT]=Res;        //记录接收到的值
                USART1_RX_CNT++;                                        //接收数据增加1
         //溢出-如果发生溢出需要先读SR,再读DR寄存器则可清除不断入中断的问题
    if(USART_GetFlagStatus(USART1,USART_FLAG_ORE) == SET)
        USART_ClearFlag(USART1,USART_FLAG_ORE);
     USART_ClearFlag(UART1,USART_IT_RXNE); //一定要清除接收中断
Copyright:
Version:
Author:
Date: 2017/11/3
Description:配置独立看门狗初始化函数,在主函数中运行IWDG_ReloadCounter进行喂狗
revise Description:
     /* 写入0x5555,用于允许狗狗寄存器写入功能 */
    IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
     /* 狗狗时钟分频,40K/256=156HZ(6.4ms)*/
    IWDG_SetPrescaler(IWDG_Prescaler_256);    /* 喂狗时间 5s/6.4MS=781 .注意不能大于0xfff*/
    IWDG_SetReload(781);//781(5s时间)
    IWDG_SetReload(3125);//781(20s时间)
    IWDG_Enable();//启用定时器
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
2.串口2
Copyright:
Version:
Author:
Date: 2017/11/3
Description:
revise Description:
u8 USART2_RX_BUF[250];
u8 USART2_RX_CNT=0;
u16 USART2_RX_STA=0;       //接收状态标记
void Usart2_Init(u32 bound)
    //|RCC_APB2Periph_AFIO
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能GPIOA时钟
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;    //PA2
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,ENABLE);//复位串口2
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,DISABLE);//停止复位
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //使能串口2中断
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //先占优先级2级
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级2级
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能外部中断通道
    NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
    USART_InitStructure.USART_BaudRate = bound;//波特率设置
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据长度
    USART_InitStructure.USART_Parity = USART_Parity_No;///奇偶校验位
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式
    USART_Init(USART2, &USART_InitStructure); ; //初始化串口
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启中断
    USART_Cmd(USART2, ENABLE);                    //使能串口
* USART2发送len个字节.
* buf:发送区首地址
void USART2_Send_Data(u8 *buf,u16 len)
    u16 t;
        while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
        USART_SendData(USART2,buf[t]);
* 这也是一个接收函数,可以用,也可以用下面main函数的方法调用
* USART2查询接收到的数据
* buf:接收缓存首地址
* len:读到的数据长度
void USART2_Receive_Data(u8 *buf)
    u8 rxlen=USART2_RX_CNT;
    u8 i=0;
    delay_ms(10);        //等待10ms,连续超过10ms没有接收到一个数据,则认为接收结束
    while(rxlen!=USART2_RX_CNT)
        delay_ms(10);
        for(i=0;i<(USART2_RX_CNT);i++)
            buf[i] = USART2_RX_BUF[i];
            USART2_RX_BUF[i] = 0;
        USART2_RX_CNT=0;        //清零
void main(void)
    Usart2_Init(9600);//串口1波特率设置为9600
    while(1)
        if(USART2_RX_STA)//数据接收完成
            USART2_RX_STA=0;
            //将接收到的数据发送出去
            USART2_Send_Data(USART2_RX_BUF,USART2_RX_CNT);//通过串口1将接收到的固定长度字符发送出去
            USART2_RX_CNT=0;//指针复位
void USART2_IRQHandler(void)
    u8 res;
     if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //接收到数据
        res =USART_ReceiveData(USART2);     //读取接收到的数据
        if(USART2_RX_STA==0)
            USART2_RX_BUF[USART2_RX_CNT] = res;        //记录接收到的值
            //当数据结尾收到0xA0和0xA1代表数据接收完成,是一串完整的数据
            if(USART2_RX_BUF[USART2_RX_CNT-1]==0xA0&&USART2_RX_BUF[USART2_RX_CNT]==0xA1)
                USART2_RX_STA=1;//表示接收数据结束
            USART2_RX_CNT++;                        //接收数据增加1
    if(USART_GetFlagStatus(USART2,USART_FLAG_ORE) == SET)
        USART_ClearFlag(USART2,USART_FLAG_ORE);
     USART_ClearFlag(UART2,USART_IT_RXNE); //一定要清除接收中断
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
3.串口3
Copyright:
Version:
Author:
Date: 2017/11/3
Description:
    通过滴答定时器方式获取数据
revise Description:
#define USART3_TIMEOUT_Setting 800  //(ms)
u8 USART3_RX_BUF[250];
u16 USART3_RX_CNT=0;
u16 USART3_RX_TIMEOUT=0;       //接收状态标记
void Timer1CountInitial(void);
void USART3_Init(u32 baud)
    GPIO_InitTypeDef GPIO_InitStructure;    //声明一个结构体变量,用来初始化GPIO
    //使能串口的RCC时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE); //使能UART3所在GPIOB的时钟
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
    //串口使用的GPIO口配置
    // Configure USART3 Rx (PB.11) as input floating
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    // Configure USART3 Tx (PB.10) as alternate function push-pull
    //配置串口
    USART_InitStructure.USART_BaudRate = baud;
    // Configure USART3
    USART_Init(USART3, &USART_InitStructure);//配置串口3
    // Enable USART3 Receive interrupts 使能串口接收中断
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
    // Enable the USART3
    USART_Cmd(USART3, ENABLE);//使能串口3
    //串口中断配置
    //Configure the NVIC Preemption Priority Bits
    // Enable the USART3 Interrupt
    NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;        //子优先级3
void USART3_Sned_Char(u8 temp)
    USART_SendData(USART3,(u8)temp);
    while(USART_GetFlagStatus(USART3,USART_FLAG_TXE)==RESET);
void USART3_Sned_Char_Buff(u8 buf[],u32 len)
    u32 i;
    for(i=0;i<len;i++)
    USART3_Sned_Char(buf[i]);
void main(void)
    Timer1CountInitial();
    Usart3_Init(9600);//串口1波特率设置为9600
    while(1)
        if(USART3_RX_TIMEOUT==USART3_TIMEOUT_Setting)
            USART3_Sned_Char_Buff(USART3_RX_BUF,USART3_RX_CNT);//将接收到的数据发送出去
            USART3_RX_CNT=0;
void USART3_IRQHandler(void)                    //串口3中断服务程序
    u8 Res;
    if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
        USART3_RX_BUF[USART3_RX_CNT++] = USART_ReceiveData(USART3);    //读取接收到的数据
    if(USART_GetFlagStatus(USART3,USART_FLAG_ORE) == SET)
        USART_ClearFlag(USART3,USART_FLAG_ORE);
    USART_ClearITPendingBit(USART3, USART_IT_RXNE);
//放到主函数的初始化中初始化
    //定时=36000/72000x2=0.001s=1ms;
        TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        TIM_TimeBaseStructure.TIM_Period = 100-1;//自动重装值(此时改为10ms)
        TIM_TimeBaseStructure.TIM_Prescaler = 7200-1;//时钟预分频
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上计数
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;        //时钟分频1
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
        TIM_ClearFlag(TIM1,TIM_FLAG_Update);
        TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
        TIM_Cmd(TIM1, ENABLE);
void TIM1_UP_IRQHandler(void)
    //TIM_TimeBaseStructure.TIM_Period = 100-1;//自动重装值(此时改为10ms)
    if (TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET)
        if(USART3_RX_TIMEOUT<USART3_TIMEOUT_Setting)
                USART3_RX_TIMEOUT++;
    TIM_ClearITPendingBit(TIM1,TIM_IT_Update);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
4.串口4
注意串口四的中断优先级没有贴出来,和前面的三个一样的配置,为了不占用过多的篇幅就不贴中断优先级配置了
Copyright:
Version:
Author:
Date: 2017/11/3
Description:
    通过滴答定时器方式获取数据
revise Description:
#define USART4_TIMEOUT_Setting 800  //(ms)
u8 USART4_RX_BUF[250];
u16 USART4_RX_CNT=0;
void Systick_delay_init(u8 SYSCLK);
u8 virtual_delay(u32 num,u8 unit);
//通用异步收发器UART4
void UART4_Init(u32 bound)
    //used for USART3 full remap
    //GPIO_PinRemapConfig(GPIO_FullRemap_USART3, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);//for UART4
    //Configure RS485_TX_EN PIN
    GPIO_InitStructure.GPIO_Pin = RS485_TX_EN_PIN;                 //PC9端口配置
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //推挽输出
    GPIO_Init(RS485_TX_EN_PORT, &GPIO_InitStructure);
    RS485_TX_EN=0;            //设置485默认为接收模式
    /* Configure USART Tx as alternate function push-pull */
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    /* Configure USART Rx as input floating */
    USART_InitStructure.USART_Parity = USART_Parity_No ;
    USART_Init(UART4, &USART_InitStructure);
    //USART_Init(USART3, &USART_InitStructure);
    /* Enable the USART */
    USART_Cmd(UART4, ENABLE);
    USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);//开启串口接受中断
    USART_ClearFlag(UART4,USART_FLAG_TC);
//USART1查询接收到的数据
//buf:接收缓存首地址
//len:读到的数据长度
void UART4_Receive_Data(u8 *buf)
    u8 rxlen=21;
    u8 i=0;
    RS485_RX_FLAG = 0;
    if((UART4_RX_BUF[0]==0x01)&&(UART4_RX_BUF[1]==0x03))
        for(i=0;i<rxlen;i++)
            buf[i]=UART4_RX_BUF[i];
            UART4_RX_BUF[i] = 0;
        RS485_RX_FLAG = 1;
        UART4_RX_CNT=0;        //清零
//USART1发送len个字节.
//buf:发送区首地址
//len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
void UART4_Send_Data(u8 *buf,u16 len)
    u16 t;
        while(USART_GetFlagStatus(UART4,USART_FLAG_TC)==RESET); //循环发送,直到发送完毕
        USART_SendData(UART4,buf[t]);
    while(USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET);
void main(void)
    Systick_delay_init(72);
    Usart4_Init(9600);//串口1波特率设置为9600
    while(1)
        if(USART2_RX_STA)
            if(virtual_delay(USART4_TIMEOUT_Setting,MS))//超过800ms空闲则可以读取数据
                UART4_Send_Data(UART4_RX_BUF,UART4_RX_CNT);
                USART2_RX_STA=0;
                UART4_RX_CNT=0;
void UART4_IRQHandler(void)                    //UART4 Receive Interrupt
    u8 Res;
    if(USART_GetITStatus(UART4, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
        Res =USART_ReceiveData(UART4);//(USART1->DR);    //读取接收到的数据
        UART4_RX_BUF[UART4_RX_CNT&0XFF]=Res;        //回传的数据存入数组,0X3F限制为64个数值
            UART4_RX_CNT++;
        USART2_RX_STA=1;
    if( USART_GetITStatus(UART4, USART_IT_TC) == SET )
        USART_ClearFlag(UART4, USART_FLAG_TC);
    if(USART_GetFlagStatus(UART4,USART_FLAG_ORE) == SET)
        USART_ClearFlag(UART4,USART_FLAG_ORE);
//    USART_ITConfig(UART4, USART_IT_RXNE, DISABLE);//临时关闭接收中断
    USART_ClearFlag(UART4,USART_IT_RXNE); //一定要清除接收中断
//初始化延迟函数
//SYSTICK的时钟固定为HCLK时钟的1/8
//SYSCLK:系统时钟
    SysTick->CTRL&=0xfffffffb;//bit2清空,选择外部时钟  HCLK/8
//    SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);    //选择外部时钟  HCLK/8
    fac_us=SYSCLK/8;
    fac_ms=(u16)fac_us*1000;
Author:peter pan
Date:
Description: 查询式分时或叫做轮询式(近似延时)。本函数是用于执行高效率场合的查询延时,但是一个for or while 循环中只能用一次。
revise Description:
@ num :    //分时查询的周期计数值
@ unit :    //分时查询的周期单位
    @@ParaValue :
        MS    //周期单位为MS毫秒级
        US    //周期单位为US微秒级
@ virtual_delay_status :    //静态变量
    @@ParaValue :
        SET    //SYSTICK正在占用中,请勿用
        RESET  //SYSTICK空闲,可以使用
@ReValue :
    with zero mean Time non-arrive ,one representative Time arrived ,you can do task;
##example             if(virtual_delay(1000,MS)) LedFlash();    //1000ms LED闪烁一下
    u32 temp;
    if(virtual_delay_status==RESET)    //  SYSTICK空闲,可以使用
          if(unit==MS)
                SysTick->LOAD=(u32)num*Delay_SYSCLK*125;//时间加载(SysTick->LOAD为24bit)
                SysTick->VAL =0x00;           //清空计数器
                SysTick->CTRL=0x01 ;          //开始倒数
          }else if(unit==US)
                SysTick->LOAD=num*Delay_SYSCLK/8; //时间加载
                SysTick->VAL=0x00;        //清空计数器
          virtual_delay_status=SET;
          return 0;
    else
        {        //virtual_delay_status==SET SYSTICK被占用
            temp=SysTick->CTRL;
            if(!(temp&0x01&&!(temp&(1<<16))))//等待时间到达
                SysTick->CTRL=0x00;       //关闭计数器
                SysTick->VAL =0X00;       //清空计数器
                virtual_delay_status=RESET;
                return 1;
            }else return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
文章来源: blog.csdn.net,作者:嵌入式与Linux那些事,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_16933601/article/details/102635090
