【树莓派】使用DHT11连接树莓派读取传感器数字并通过0.96寸屏展示
小雨青年 发表于 2022/03/28 22:11:13 2022/03/28
【摘要】 设备 树莓派3b+温湿度传感器DHT11 接线 VCC - 电源3.3v或者5v data - 数据读取 GND - 接地 这个的接线方式和上次的接线很像,其实其他的也都差不多,电源正负和数据...
设备
  • 树莓派3b+
  • 温湿度传感器DHT11
接线
VCC - 电源3.3v或者5v
data - 数据读取
GND - 接地
这个的接线方式和上次的接线很像,其实其他的也都差不多,电源正负和数据读取写入
读取
在上面的接线中,我把DHT11放在了22号针脚上,所以下面的针脚号都是22,如果你接在了其他部分,注意修改~
使用官方库
官方的安装方式和上次用显示屏的方式一样,都是clone,安装,执行
git clone git://github.com/adafruit/Adafruit_Python_DHT.git
cd Adafruit_Python_DHT/
sudo python setup.py install
cd examples/
python AdafruitDHT.py 11 22
最终的结果是
Temp=25.0*  Humidity=22.0%
如果是用python3,就把上面的python改成python3即可。
sudo python3 setup.py install
python3 AdafruitDHT.py 11 22
也是可以执行的。
AdafruitDHT.py文件内容如下
#!/usr/bin/python
# Copyright (c) 2014 Adafruit Industries
# Author: Tony DiCola
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import sys
import Adafruit_DHT
# Parse command line parameters.
sensor_args = { '11': Adafruit_DHT.DHT11,
                '22': Adafruit_DHT.DHT22,
                '2302': Adafruit_DHT.AM2302 }
if len(sys.argv) == 3 and sys.argv[1] in sensor_args:
    sensor = sensor_args[sys.argv[1]]
    pin = sys.argv[2]
else:
    print('Usage: sudo ./Adafruit_DHT.py [11|22|2302] <GPIO pin number>')
    print('Example: sudo ./Adafruit_DHT.py 2302 4 - Read from an AM2302 connected to GPIO pin #4')
    sys.exit(1)
# Try to grab a sensor reading.  Use the read_retry method which will retry up
# to 15 times to get a sensor reading (waiting 2 seconds between each retry).
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
# Un-comment the line below to convert the temperature to Fahrenheit.
# temperature = temperature * 9/5.0 + 32
# Note that sometimes you won't get a reading and
# the results will be null (because Linux can't
# guarantee the timing of calls to read the sensor).
# If this happens try again!
if humidity is not None and temperature is not None:
    print('Temp={0:0.1f}*  Humidity={1:0.1f}%'.format(temperature, humidity))
else:
    print('Failed to get reading. Try again!')
    sys.exit(1)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
使用GPIO读取
我们也可以直接通过python直接读取GPIO针脚的数据
import RPi.GPIO as GPIO
import time
channel = 22			#引脚号
data = []			#温湿度值
j = 0				#计数器
GPIO.setmode(GPIO.BCM)		#以BCM编码格式
time.sleep(1)			#时延一秒
GPIO.setup(channel, GPIO.OUT)
GPIO.output(channel, GPIO.LOW)
time.sleep(0.02)		#给信号提示传感器开始工作
GPIO.output(channel, GPIO.HIGH)
GPIO.setup(channel, GPIO.IN)
while GPIO.input(channel) == GPIO.LOW:
	continue
while GPIO.input(channel) == GPIO.HIGH:
	continue
while j < 40:
	k = 0
		continue
		k += 1
		if k > 100:
			break
	if k < 8:
		data.append(0)
	else:
		data.append(1)
	j += 1
print("sensor is working.")
print(data)				#输出初始数据高低电平
humidity_bit = data[0:8]		#分组
humidity_point_bit = data[8:16]
temperature_bit = data[16:24]
temperature_point_bit = data[24:32]
check_bit = data[32:40]
humidity = 0
humidity_point = 0
temperature = 0
temperature_point = 0
check = 0
for i in range(8):
	humidity += humidity_bit[i] * 2 ** (7 - i)				#转换成十进制数据
	humidity_point += humidity_point_bit[i] * 2 ** (7 - i)
	temperature += temperature_bit[i] * 2 ** (7 - i)
	temperature_point += temperature_point_bit[i] * 2 ** (7 - i)
	check += check_bit[i] * 2 ** (7 - i)
tmp = humidity + humidity_point + temperature + temperature_point		#十进制的数据相加
if check == tmp:								#数据校验,相等则输出
	print ("temperature : ", temperature, ", humidity : " , humidity)
else:										#错误输出错误信息,和校验数据
	print ("wrong")
	print ("temperature : ", temperature, ", humidity : " , humidity, " check : ", check, " tmp : ", tmp)
GPIO.cleanup()
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
执行之后也可以得到传感器结果
pi@xiaoyupi:~/RaspberryPiScript $ python3 DHT11.py
sensor is working.
[0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 1, 0, 1, 1]
temperature :  25 , humidity :  16
使用0.96寸oled屏展示温湿度
代码如下
#!/usr/bin/python
import time
import Adafruit_GPIO.SPI as SPI
import Adafruit_SSD1306
import Adafruit_DHT
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
import subprocess
# Raspberry Pi pin configuration:
RST = None     # on the PiOLED this pin isnt used
# Note the following are only used with SPI:
DC = 23
SPI_PORT = 0
SPI_DEVICE = 0
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST)
# Initialize library.
disp.begin()
# Clear display.
disp.clear()
disp.display()
# Create blank image for drawing.
# Make sure to create image with mode '1' for 1-bit color.
width = disp.width
height = disp.height
image = Image.new('1', (width, height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Draw a black filled box to clear the image.
draw.rectangle((0,0,width,height), outline=0, fill=0)
# Draw some shapes.
# First define some constants to allow easy resizing of shapes.
padding = -2
top = padding
bottom = height-padding
# Move left to right keeping track of the current x position for drawing shapes.
x = 0
# Load default font.
font = ImageFont.load_default()
# Alternatively load a TTF font.  Make sure the .ttf font file is in the same directory as the python script!
# Some other nice fonts to try: http://www.dafont.com/bitmap.php
# font = ImageFont.truetype('Minecraftia.ttf', 8)
while True:
    sensor  = 11 # 传感器型号
    pin = 22 # 针脚
        Temp = 'Temp={0:0.1f}*'.format(temperature)
        H = 'Humidity={0:0.1f}%'.format(humidity)
    now = time.strftime("%Y-%m-%d-%H:%M:%S", time.localtime())
    draw.text((x, top),       str(now),  font=font, fill=255)
    draw.text((x, top+8),     str(Temp), font=font, fill=255)
    draw.text((x, top+16),     str(H), font=font, fill=255)
    # Display image.
    disp.image(image)
    disp.display()
    time.sleep(1)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
最终实现效果如图
文章来源: coderfix.blog.csdn.net,作者:小雨青年,版权归原作者所有,如需转载,请联系作者。
原文链接:coderfix.blog.csdn.net/article/details/104547804
