拿php写一个投票系统出来,比较简单de啦
陈业贵 发表于 2022/03/29 00:42:07 2022/03/29
【摘要】 sql: -- phpMyAdmin SQL Dump -- version 4.5.1 -- http://www.phpmyadmin.net -- -- Host: 127.0.0.1 --...
sql:
-- version 4.5.1
-- Host: 127.0.0.1
-- Generation Time: 2022-03-28 05:42:05
-- 服务器版本: 10.1.13-MariaDB
-- PHP Version: 5.6.21
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
SET time_zone = "+00:00";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8mb4 */;
-- Database: `a`
-- 表的结构 `voto`
CREATE TABLE `voto` (
  `id` int(10) NOT NULL,
  `titleid` int(10) DEFAULT NULL,
  `item` varchar(50) DEFAULT NULL,
  `count` int(10) DEFAULT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
-- 转存表中的数据 `voto`
INSERT INTO `voto` (`id`, `titleid`, `item`, `count`) VALUES
(24, 1, '张学友', 0),
(25, 1, '陈奕迅', 0),
(26, 1, '林俊杰', 0),
(27, 1, '萧敬腾', 0),
(29, 1, '', 0),
(30, 1, 'aaa', 0);
-- Indexes for dumped tables
-- Indexes for table `voto`
ALTER TABLE `voto`
  ADD PRIMARY KEY (`id`);
-- 在导出的表使用AUTO_INCREMENT
-- 使用表AUTO_INCREMENT `voto`
ALTER TABLE `voto`
  MODIFY `id` int(10) NOT NULL AUTO_INCREMENT, AUTO_INCREMENT=31;
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
1.php
<!DOCTYPE html>
<html lang="en">
<head>
	<meta charset="UTF-8">
	<title>Document</title>
</head>
<body>
	<a href="admin.php">增删改查投票的选项</a>
<br>
	<a href="index.php">投票给谁呢</a>
</body>
</html>
admin.php(增删改查投票的页面)密码:admin
<?php
ob_start(); //打开缓冲区
session_start();
header("Content-type:text/html;charset=utf-8");
$link = mysqli_connect('localhost','root','','a');
mysqli_set_charset($link, "utf8");
if (!$link) {
  die("连接失败:".mysqli_connect_error());
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <title>PHP+mysql开发的简单投票系统</title>
  <style type="text/css">
    /*全局样式*/
    body { font-family: "宋体"; font-size: 12pt; color: #333333; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px;background-color: #d4d4d4;}
    table { font-family: "宋体"; font-size: 9pt; line-height: 20px; color: #333333}
    /*全局样式结束*/
  </style>
  <script language="javascript">
    function selectAll()
      node=window.document.frm.itm;
      for(i=0;i<node.length;i++)
        node[i].checked=true;//全选
    function cancelAll()
      node=frm.itm;
        node[i].checked=false;//取消全部
    function del()
      node=frm.itm;
      id="";
        if(node[i].checked)
          if(id=="")//删除
            id=node[i].value
          else
            id=id+","+node[i].value
      if(id=="")
        alert("您没有选择删除项");
      else
        location.href="?type=del&id="+id
  </script>
</head>
<body>
<?php
if(isset($_GET['tj']) == 'out'){
  session_destroy();//删除当前用户对应的session文件以及释放session
  echo "<script language=javascript>alert('退出成功!');window.location='index.php'</script>";
<?php
if(isset($_POST['Submit10'])){
  if($_POST['pwd']=='admin'){
    $_SESSION['pwd']=2;
    echo "<script language=javascript>alert('登陆成功!');window.location='admin.php'</script>";
  }else{
    echo "<script language=javascript>alert('登陆失败,请检查您的密码!');window.location='admin.php'</script>";
<?php if($_SESSION['pwd']<>2){ ?>
  <form action="" method="post">
    <table width="365" border="0" align="center" cellpadding="5" cellspacing="1" bgcolor="#C2C2C2">
      <tr>
        <td height="30" align="right" bgcolor="#FFFFFF"><label>输入密码:</label></td>
        <td align="left" bgcolor="#FFFFFF"><input name="pwd" type="text" id="pwd" /></td>
      </tr>
      <tr>
        <td height="30" colspan="2" align="center" bgcolor="#FFFFFF"><label>
            <input name="Submit10" type="submit" id="Submit10" value="登陆" />
          </label>
          <label>
            <input type="reset" name="Submit5" value="重置" />
          </label></td>
      </tr>
      <tr>
          软件版本:<script type="text/javascript" src="http://www.04ie.com/net/phpvoto1_1.js"></script></td>
      </tr>
    </table>
  </form>
<?php }else{ ?>
<?php
if(isset($_POST["Submit"]))
$title=$_POST["title"];
$sql="update vototitle set vototitle='$title'";
mysqli_query($link,$sql);
    alert("修改成功");
  </script>
<?php
if(isset($_POST["Submit2"]))
  $newitem=$_POST["newitem"];
  $sql="insert into voto (titleid,item,count) values (1,'$newitem',1)";
  <form id="frm" name="frm" method="post" action="" style="margin-bottom:3px;">
      <tr>
        <td colspan="4" bgcolor="#FFFFFF"><label>
            <?php
            $sql="select * from vototitle";
            $rs=mysqli_query($link,$sql);
            $rows=mysqli_fetch_assoc($rs);
            <input name="title" type="text" id="title" size="35" value="<?php echo $rows["vototitle"]?>" />
          </label></td>
        <td width="68" align="center" bgcolor="#FFFFFF"><label>
            <input type="submit" name="Submit" value="修改标题" />
          </label></td>
      </tr>
      <tr>
        <th width="30" bgcolor="#FFFFFF">编号</th>
        <th width="45" bgcolor="#FFFFFF">项目</th>
        <th width="52" bgcolor="#FFFFFF">票数</th>
        <th width="50" align="center" bgcolor="#FFFFFF">修改</th>
        <th align="center" bgcolor="#FFFFFF">删除</th>
      </tr>
      <?php
      $sql="select * from voto order by count desc";
      while($rows=mysqli_fetch_assoc($rs))
        <tr>
          <td align="center" bgcolor="#FFFFFF"><input type="checkbox" name="itm" value="<?php echo $rows["id"]?>" /><?php echo $rows["id"]?></td>
          <td align="center" bgcolor="#FFFFFF"><?php echo $rows["item"]?></td>
          <td align="center" bgcolor="#FFFFFF"><?php echo $rows["count"]?></td>
          <td align="center" bgcolor="#FFFFFF"><input type="button" value="修改" onclick="location.href='?type=modify&id=<?php echo $rows["id"]?>'" /></td>
          <td align="center" bgcolor="#FFFFFF"><input type="button" value="删除" onclick="location.href='?type=del&id=<?php echo $rows["id"]?>'"  /></td>
        </tr>
        <?php
      <tr>
        <td colspan="5" align="center" bgcolor="#FFFFFF">
          <input type="button" value="选择全部" onclick="selectAll()" />
          <input type="button" value="取消全部" onclick="cancelAll()" />
          <input type="button" value="删除所选" onclick="del()" />   </td>
      </tr>
      <tr>
        <td colspan="3" bgcolor="#FFFFFF"><label>
            <input name="newitem" type="text" id="newitem" />
          </label></td>
        <td colspan="2" bgcolor="#FFFFFF"><label>
            <input type="submit" name="Submit2" value="添加新项" />
              </label>
          <a href="?tj=out">退出管理</a></td>
      </tr>
    </table>
  </form>
<?php
$type = isset($_GET["type"])?$_GET["type"]:"";
if($type =="modify"){
$id=$_GET["id"];
if(isset($_POST["Submit3"]))
  $item=$_POST["itm"];
  $count=$_POST["count"];
  $sql="update voto set item='$item',count=$count where id=$id";
  echo "<script language=javascript>alert('修改成功!');window.location='admin.php'</script>";
$sql="select * from voto where id=$id";
  <form id="form1" name="form1" method="post" action="" style="margin-top:2px;">
      <tr>
        <th colspan="2" bgcolor="#FFFFFF">修改投票项目</th>
      </tr>
      <tr>
        <td align="center" bgcolor="#FFFFFF">名称:</td>
        <td bgcolor="#FFFFFF"><label>
            <input name="itm" type="text" id="itm" value="<?php echo $rows["item"]?>" />
          </label></td>
      </tr>
      <tr>
        <td align="center" bgcolor="#FFFFFF">票数:</td>
            <input name="count" type="text" id="count" value="<?php echo $rows["count"]?>" />
          </label></td>
      </tr>
      <tr>
        <td colspan="2" align="center" bgcolor="#FFFFFF"><label>
            <input type="submit" name="Submit3" value="修改" />
            <input type="reset" name="Submit" value="重置" />
          </label></td>
      </tr>
    </table>
  </form>
  <?php
  <?php
  if($type =="del"){
    $id=$_GET["id"];
    $sql="delete from voto where id in ($id)";
    echo "<script language=javascript>alert('删除成功!');window.location='admin.php'</script>";
<?php } ?>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
index.php(投票的页面)
<?php
ob_start();
session_start();
if (!$link) {
<!doctype html>
<html>
<head>
  <title>投票系统</title>
  <script type="text/javascript" src="//cdn.bootcss.com/jquery/1.12.4/jquery.js"></script>
    /*全局样式*/
    body { font-family: "宋体"; font-size: 12pt; color: #333333; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px;background-color: #A6C7E1;}
    a:link { font-size: 9pt; color: #333333; text-decoration: none}
    a:visited { font-size: 9pt; color: #333333; text-decoration: none}
    a:hover { font-size: 9pt; color: #E7005C; text-decoration: underline}
    a:active { font-size: 9pt; color: #333333; text-decoration: none}
    /*全局样式结束*/
  </style>
    function check()
      node=frm.itm;
      flag=false;
        if(node[i].checked)
          flag=true;
      if(!flag)
        alert("您没有选择")
        return false;
      return true;
  </script>
  <?php
  if(isset($_POST["submit"])){
    if($_POST){
      $id = $_POST["selected_id"];
      $sql = "update voto set count = count+1 where id=$id";
    if($_SESSION["voto"]==session_id())
        alert("您已经投票了");
        location.href="index.php";
      </script>
    <?php
    exit();
    $id=$_POST["itm"];
    $sql="update voto set count=count+1 where id=$id";
    if(mysqli_query($link,$sql))
    $_SESSION["voto"]=session_id();
      <script language="javascript">alert("投票成功,点确定查看结果");location.href="index.php?id=ck";</script>
    <?php
    else
      <script language="javascript">alert("投票失败");location.href="index.php";</script>
      <?php
</head>
<body>
<form name="frm" action="" method="post" onsubmit=return(check()) style="margin-bottom:5px;">
    <tr>
      <th bgcolor="#FFFFCC">
        <?php
        $row=mysqli_fetch_assoc($rs);
        echo $row["vototitle"];
        ?> </th>
    </tr>
    <?php
    $sql="select * from voto";
      <tr>
        <td bgcolor="#FFFFFF"><input type="radio" name="itm" value="<?php echo $rows["id"]?>" />
      </tr>
      <?php
    <tr>
        <input type="submit" name="submit" value="投票"/>
        <input type="hidden" id="selected_id" name="selected_id" value="">
        <input type="button" value="查看结果" onClick="location.href='index.php?id=ck'"/>
        <script type="text/javascript">
            $("[type='radio']").click(function(){
               $("#selected_id").val($(this).val());
        </script></td>
    </tr>
  </table>
</form>
<?php
if(isset($_GET["id"])=="ck"){?>
  <?php
  $sql="select sum(count) as 'total' from voto";
  $sum=$rows["total"];  //得出总票数
  <table id="click" width="365" border="0" align="center" cellpadding="5" cellspacing="1" bgcolor="#C2C2C2" >
    <tr>
      <th bgcolor="#FFFFFF">项目</th>
      <th bgcolor="#FFFFFF">票数</th>
      <th bgcolor="#FFFFFF">百分比</th>
    </tr>
    <?php
      <tr>
        <td bgcolor="#FFFFFF"><?php echo $rows["item"]?></td>
        <td bgcolor="#FFFFFF"><?php echo $rows["count"]?></td>
          <?php
          $per=$rows["count"]/$sum;
          $per=number_format($per,4);
          <img src="" height="4" width="<?php echo $per*100?>" />
          <?php echo $per*100?>%      </td>
      </tr>
      <?php
  </table>
  <div align="center">
    <a href="index.php">隐藏结果</a>
  </div>
<?php } ?>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
文章来源: blog.csdn.net,作者:贵哥的编程之路(热爱分享),版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_37805832/article/details/123791601
