window下phpstudy的nginx配置虚拟主机
lxw1844912514 发表于 2022/03/28 01:16:40 2022/03/28
【摘要】 由于很长时间没有配置Apache,虽然说知道怎么配置nginx,但是还是花费了一些时间这次记下来下次直接用 在其他选项文件菜单中->打开配置文件->选择vhosts-conf nginx的话使用 server { listen 80; server_...
nginx的话使用
server {
        listen       80;
        server_name  你的虚拟目录名称;
        root   "你要操作的目录路径";
        location / {
            index  index.html index.htm index.php;
            #autoindex  on;
            if ($request_filename !~ (static|robots/.txt|index/.php.*)) {
                rewrite ^/(.*)$ /index.php?$1 last;
                break;
        location ~ \.php(.*)$ {
            fastcgi_pass   127.0.0.1:9000;
            fastcgi_index  index.php;
            fastcgi_split_path_info  ^((?U).+\.php)(/?.+)$;
            fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
            fastcgi_param  PATH_INFO  $fastcgi_path_info;
            fastcgi_param  PATH_TRANSLATED  $document_root$fastcgi_path_info;
            include        fastcgi_params;
之后最重要一点就是DNS解析了:在C:\Windows\System32\drivers\etc下打开hosts
加入你配置的域名解析到本地的代码例如
127.0.0.1       localhost                               这个是默认有的
127.0.0.1       www.mycomment.com
 apache的虚拟主机的话代码可以参考
<VirtualHost *:80>
ServerAdmin fudesign2008@163.com
DocumentRoot "F:\workspace\vim\YNote\src"
    ServerName editor.fuyg.cn
    ServerAlias editor.fuyg.cn
    ErrorLog "logs/dummy-host.localhost-error.log"
    CustomLog "logs/dummy-host.localhost-access.log" combined
    <Directory "F:\workspace\vim\YNote\src">
        Options Indexes FollowSymLinks
        AllowOverride All
        Order allow,deny
        Allow from all
    </Directory>
</VirtualHost>
 以下为亲测有效:
<VirtualHost _default_:80>
DocumentRoot "D:\phpstudy\PHPTutorial\WWW"
  <Directory "D:\phpstudy\PHPTutorial\WWW">
    Options -Indexes -FollowSymLinks +ExecCGI
    AllowOverride All
    Order allow,deny
    Allow from all
    Require all granted
  </Directory>
</VirtualHost>
<VirtualHost *:80>
ServerAdmin hzym.com
DocumentRoot "D:\phpstudy\PHPTutorial\WWW\welltrend\www"
    ServerName hzym.com
    ServerAlias hzym.com
    <Directory "D:\phpstudy\PHPTutorial\WWW\welltrend\www">
        AllowOverride All
        Order allow,deny
        Allow from all
    </Directory>
</VirtualHost>
原文链接:blog.csdn.net/lxw1844912514/article/details/100027996
