laravel5.6 发送邮件附带邮件时,Unable to open file for reading,报错文件路径问题
lxw1844912514 发表于 2022/03/27 23:04:58 2022/03/27
【摘要】 https://stackoverflow.com/questions/48568739/unable-to-open-file-for-reading-swift-ioexception-in-laravel-mailable “Unable to open file for reading” (Swift_IoExcept...
“Unable to open file for reading” (Swift_IoException) in Laravel Mailable
I'm trying to use Mailable in Laravel, I have run into an issue that I haven't come across before and it appears nothing currently out there can help.
In developing a new Mailable, I have everything working except attaching an EXISTING file to the mailable.
An error returns as such:
          "message": "Unable to open file for reading [/public/storage/shipments/CJ2K4u6S6uluEGd8spOdYgwNkg8NgLFoC6cF6fm5.pdf]",
             "exception": "Swift_IoException",
             "file": "E:\\webserver\\htdocs\\truckin\\vendor\\swiftmailer\\swiftmailer\\lib\\classes\\Swift\\ByteStream\\FileByteStream.php",
             "line": 131,
But if you go through the folders and files, there is in fact a file there and I can open it, I can even open it through an ajax popup to view details.
Here is my mailable:
          <?php
          namespace App\Mail;
          use Illuminate\Bus\Queueable;
          use Illuminate\Mail\Mailable;
          use Illuminate\Queue\SerializesModels;
          use Illuminate\Contracts\Queue\ShouldQueue;
          use App\Shipment;
          use App\Shipment_Attachment;
          class shipmentAttachments extends Mailable
             use Queueable, SerializesModels;
           * Create a new message instance.
           * @return void
             public $shipment, $attachment, $storagePath;
             public function __construct($shipment, $attachment, $storagePath)
                 $this->shipment = $shipment;
                 $this->attachment = $attachment;
                 $this->attachmentFile = '/public'.$storagePath;
                 $this->proNumber = $shipment->pro_number;
           * Build the message.
           * @return $this
             public function build()
                  return $this->from('billing@cmxtrucking.com')
                              ->cc('billing@cmxtrucking.com')
                              ->subject('New Attachment(s) - '. $this->proNumber)
                              ->view('emails.shipments.shipmentAttachments',['shipment'=> $this->shipment])
                              ->attach($this->attachmentFile);
And here is my controller that leads to the mailable:
          public function attachmentsEmail(Request $request){
                 $shipment = Shipment::findOrFail($request->shipmentID);
                 $attachment = Shipment_Attachment::findOrFail($request->attachmentID);
                 $storagePath = Storage::url($attachment->attachmentPath);
                 $email = $request->email;
                       Mail::to($email)->send(new shipmentAttachments($shipment, $attachment, $storagePath));  //maybe try to use queue instead of send...
                 return back();
So I'm not sure where this could be coming from.
解决方法:
Try to use public_path() laravel helper function instead of '/public'.
$this->attachmentFile = public_path() . '/' . $storagePath;  亲测可行
Maybe you need to change this variable in public/index.php. I have right below the require bootstrap:
           $app->bind('path.public', function() {
              return __DIR__;
Make some tests.
           dd(public_path());
           dd(public_path() . '/' . $storagePath);
Or maybe verify if file exist with FileSystem class.
Hope this help you!
邮件中的图片问题:
方法一:
 <img src="{{ $message->embed(public_path().$user->avatar) }}">
 方法二:
<img src="http://blog.com/{{$user->avatar}}">
原文链接:blog.csdn.net/lxw1844912514/article/details/100028145
评论(0
