vagrant up 网络问题
lxw1844912514 发表于 2022/03/27 22:44:05 2022/03/27
【摘要】 Stderr: VBoxManage.exe: error: Failed to open/create the internal network 'HostInterfaceNetworking-VirtualBox Host-Only Ethernet Adapter' (VERR_INTNET_FLT_IF_NOT_FOUND)....
  1. Stderr: VBoxManage.exe: error: Failed to open/create the internal network 'HostInterfaceNetworking-VirtualBox Host-Only Ethernet Adapter' (VERR_INTNET_FLT_IF_NOT_FOUND).
  2. VBoxManage.exe: error: Failed to attach the network LUN (VERR_INTNET_FLT_IF_NOT_FOUND)
  3. VBoxManage.exe: error: Details: code E_FAIL (0x80004005), component ConsoleWrap, interface IConsole
 win 打开Oracle VM VirtualBox 客户端,设置->设置->网卡1 改为网络地址换(NAT)
修改:
原文链接:blog.csdn.net/lxw1844912514/article/details/119318410
