蓝桥ROS机器人系统更新和功能包安装记录
zhangrelay 发表于 2022/03/28 00:45:12 2022/03/28
【摘要】 直接系统更新会有错误: ☞ ROS域名解析问题记录(蓝桥云课ros.asc) sudo apt update     使用ros.asc如下: -----BEGIN PGP PUBLIC KEY BLOCK-----Version: GnuPG v1 mQINBFzvJpYBEADY8l1...
直接系统更新会有错误:
sudo apt update
使用ros.asc如下:
  1. -----BEGIN PGP PUBLIC KEY BLOCK-----
  2. Version: GnuPG v1
  3. mQINBFzvJpYBEADY8l1YvO7iYW5gUESyzsTGnMvVUmlV3XarBaJz9bGRmgPXh7jc
  4. VFrQhE0L/HV7LOfoLI9H2GWYyHBqN5ERBlcA8XxG3ZvX7t9nAZPQT2Xxe3GT3tro
  5. u5oCR+SyHN9xPnUwDuqUSvJ2eqMYb9B/Hph3OmtjG30jSNq9kOF5bBTk1hOTGPH4
  6. K/AY0jzT6OpHfXU6ytlFsI47ZKsnTUhipGsKucQ1CXlyirndZ3V3k70YaooZ55rG
  7. aIoAWlx2H0J7sAHmqS29N9jV9mo135d+d+TdLBXI0PXtiHzE9IPaX+ctdSUrPnp+
  8. TwR99lxglpIG6hLuvOMAaxiqFBB/Jf3XJ8OBakfS6nHrWH2WqQxRbiITl0irkQoz
  9. pwNEF2Bv0+Jvs1UFEdVGz5a8xexQHst/RmKrtHLct3iOCvBNqoAQRbvWvBhPjO/p
  10. V5cYeUljZ5wpHyFkaEViClaVWqa6PIsyLqmyjsruPCWlURLsQoQxABcL8bwxX7UT
  11. hM6CtH6tGlYZ85RIzRifIm2oudzV5l+8oRgFr9yVcwyOFT6JCioqkwldW52P1pk/
  12. /SnuexC6LYqqDuHUs5NnokzzpfS6QaWfTY5P5tz4KHJfsjDIktly3mKVfY0fSPVV
  13. okdGpcUzvz2hq1fqjxB6MlB/1vtk0bImfcsoxBmF7H+4E9ZN1sX/tSb0KQARAQAB
  14. tCZPcGVuIFJvYm90aWNzIDxpbmZvQG9zcmZvdW5kYXRpb24ub3JnPokCVAQTAQgA
  15. PgIbAwULCQgHAgYVCgkICwIEFgIDAQIeAQIXgBYhBMHPbjHmut6IaLFytPQu1vur
  16. F8ZUBQJgsdhRBQkLTMW7AAoJEPQu1vurF8ZUTMwP/3f7EkOPIFjUdRmpNJ2db4iB
  17. RQu5b2SJRG+KIdbvQBzKUBMV6/RUhEDPjhXZI3zDevzBewvAMKkqs2Q1cWo9WV7Z
  18. PyTkvSyey/Tjn+PozcdvzkvrEjDMftIk8E1WzLGq7vnPLZ1q/b6Vq4H373Z+EDWa
  19. DaDwW72CbCBLWAVtqff80CwlI2x8fYHKr3VBUnwcXNHR4+nRABfAWnaU4k+oTshC
  20. Qucsd8vitNfsSXrKuKyz91IRHRPnJjx8UvGU4tRGfrHkw1505EZvgP02vXeRyWBR
  21. fKiL1vGy4tCSRDdZO3ms2J2m08VPv65HsHaWYMnO+rNJmMZj9d9JdL/9GRf5F6U0
  22. quoIFL39BhUEvBynuqlrqistnyOhw8W/IQy/ymNzBMcMz6rcMjMwhkgm/LNXoSD1
  23. 1OrJu4ktQwRhwvGVarnB8ihwjsTxZFylaLmFSfaA+OAlOqCLS1OkIVMzjW+Ul6A6
  24. qjiCEUOsnlf4CGlhzNMZOx3low6ixzEqKOcfECpeIj80a2fBDmWkcAAjlHu6VBhA
  25. TUDG9e2xKLzV2Z/DLYsb3+n9QW7KO0yZKfiuUo6AYboAioQKn5jh3iRvjGh2Ujpo
  26. 22G+oae3PcCc7G+z12j6xIY709FQuA49dA2YpzMda0/OX4LP56STEveDRrO+CnV6
  27. WE+F5FaIKwb72PL4rLi4
  28. =i0tj
  29. -----END PGP PUBLIC KEY BLOCK-----
sudo apt-key add ros.asc
然后切换为国内源:
sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ `lsb_release -cs` main" > /etc/apt/sources.list.d/ros-latest.list'
sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/ `lsb_release -cs` main" > /etc/apt/sources.list.d/ros-latest.list'
预计5分钟,完成上述配置,然后更新和安装功能包就都没问题啦!!!
sudo apt upgrade
默认情况下,不用更新,此过程复习一下ubuntu维护等基础。
如上错误可以忽略。
安装catkin工具:
 sudo apt install python3-catkin-tools
全部命令如下:
  1. shiyanlou:~/ $ history [11:57:18]
  2. 1 sudo apt update
  3. 2 gedit ros.asc
  4. 3 sudo apt-key add ros.asc
  5. 4 sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ `lsb_release -cs` main" > /etc/apt/sources.list.d/ros-latest.list'
  6. 5 sudo sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/ `lsb_release -cs` main" > /etc/apt/sources.list.d/ros-latest.list'
  7. 6 sudo apt update
  8. 7 sudo apt upgrade
  9. 8 sudo apt install ros-kinetic-rqt-*
  10. 9 sudo apt install python3-catkin-tools
  11. 10 catkin
  12. shiyanlou:~/ $ [11:57:21]
原文链接:zhangrelay.blog.csdn.net/article/details/123761896
