PHP结合Ueditor并修改图片上传路径
lxw1844912514 发表于 2022/03/27 04:44:26 2022/03/27
【摘要】 投稿:hebedich 字体:[ 增加 减小] 类型:转载 时间:2016-10-16 我要评论 使用ueditor编辑器,附件默认在ueditor/php/upload/, 但是大家的附件地址的默认路径可不是这个 ,需要修改ueditor,具体如何操作呢,下面我们就来详细讲解下 ...
前言
在使用UEditor编辑器时,一般我们都是需要修改默认的图片上传路径的,下面是我整理好的修改位置和方法供大家参考。
操作
Ueditor PHP版本本身自带了一套上传程序,我们可以在此基础中,找到配置文件修改它。配置文件位置:
ueditor/php/config.json
内容如下:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
   "imageActionName" : "uploadimage" ,
   "imageFieldName" : "upfile" ,
   "imageMaxSize" : 2048000,
   "imageAllowFiles" : [ ".png" , ".jpg" , ".jpeg" , ".gif" , ".bmp" ],
   "imageCompressEnable" : true ,
   "imageCompressBorder" : 1600,
   "imageInsertAlign" : "none" ,
   "imageUrlPrefix" : "" ,
   "imagePathFormat" : "/ueditor/php/upload/image/{yyyy}{mm}{dd}/{time}{rand:6}" ,
   "scrawlActionName ": " uploadscrawl ",
   " scrawlFieldName ": " upfile ",
   " scrawlPathFormat ": " /ueditor/php/upload/image/{yyyy}{mm}{dd}/{time}{rand:6} ",
   " scrawlMaxSize ": 2048000,
   " scrawlUrlPrefix ": " ",
   " scrawlInsertAlign ": " none ",
   " snapscreenActionName ": " uploadimage ",
   " snapscreenPathFormat ": " /ueditor/php/upload/image/{yyyy}{mm}{dd}/{time}{rand:6} ",
   " snapscreenUrlPrefix ": " ",
   " snapscreenInsertAlign ": " none ",
   " catcherLocalDomain ": [" 127.0.0.1 ", " localhost ", " img.baidu.com "],
   " catcherActionName ": " catchimage ",
   " catcherFieldName ": " source ",
   " catcherPathFormat ": " /ueditor/php/upload/image/{yyyy}{mm}{dd}/{time}{rand:6} ",
   " catcherUrlPrefix ": " ",
   " catcherMaxSize ": 2048000,
   " catcherAllowFiles ": [" .png ", " .jpg ", " .jpeg ", " .gif ", " .bmp "],
   " videoActionName ": " uploadvideo ",
   " videoFieldName ": " upfile ",
   " videoPathFormat ": " /ueditor/php/upload/video/{yyyy}{mm}{dd}/{time}{rand:6} ",
   " videoUrlPrefix ": " ",
   " videoMaxSize ": 102400000,
   " videoAllowFiles ": [
     " .flv ", " .swf ", " .mkv ", " .avi ", " .rm ", " .rmvb ", " .mpeg ", " .mpg ",
     " .ogg ", " .ogv ", " .mov ", " .wmv ", " .mp4 ", " .webm ", " .mp3 ", " .wav ", " .mid "],
   " fileActionName ": " uploadfile ",
   " fileFieldName ": " upfile ",
   " filePathFormat ": " /ueditor/php/upload/file/{yyyy}{mm}{dd}/{time}{rand:6} ",
   " fileUrlPrefix ": " ",
   " fileMaxSize ": 51200000,
   " fileAllowFiles ": [
     " .png ", " .jpg ", " .jpeg ", " .gif ", " .bmp ",
     " .ogg ", " .ogv ", " .mov ", " .wmv ", " .mp4 ", " .webm ", " .mp3 ", " .wav ", " .mid ",
     " .rar ", " .zip ", " .tar ", " .gz ", " .7z ", " .bz2 ", " .cab ", " .iso ",
     " .doc ", " .docx ", " .xls ", " .xlsx ", " .ppt ", " .pptx ", " .pdf ", " .txt ", " .md ", " .xml "
   " imageManagerActionName ": " listimage ",
   " imageManagerListPath ": " /ueditor/php/upload/image/ ",
   " imageManagerListSize ": 20,
   " imageManagerUrlPrefix ": " ",
   " imageManagerInsertAlign ": " none ",
   " imageManagerAllowFiles ": [" .png ", " .jpg ", " .jpeg ", " .gif ", " .bmp "],
   " fileManagerActionName ": " listfile ",
   " fileManagerListPath ": " /ueditor/php/upload/file/ ",
   " fileManagerUrlPrefix ": " ",
   " fileManagerListSize ": 20,
   " fileManagerAllowFiles ": [
     " .doc ", " .docx ", " .xls ", " .xlsx ", " .ppt ", " .pptx ", " .pdf ", " .txt ", " .md ", " .xml"
从config.json内容中,我们不难看出(全部都有注释,看不出就见鬼了->_->),几乎所有的上传配置都是在这里。如果想修改上传路径,那么通过修改文件第 12 行就可以做到。
比如,这里我们修改 imagePathFormat :
复制代码 代码如下:
"imagePathFormat": "/upload/ueditor/{yyyy}{mm}{dd}/{time}{rand:6}",
保存,上传,测试,查看源码:
此时可以看出,修改是成功的。
上传配置这款,会因ueditor版本不同,而稍有不同,我刚开始在用新版本时也没有反应过来,寻根索源才找到了这里,大家在修改的时候也要注意下哦。
另外,如果需要修改其他上传,如视频等,也可以在此处文件修改,道理都是一样的。
原文链接:blog.csdn.net/lxw1844912514/article/details/100026622
