百度地图API显示多个标注点并添加百度样式检索窗口
lxw1844912514 发表于 2022/03/27 03:01:52 2022/03/27
【摘要】 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/...
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <title>百度地图API显示多个标注点带百度样式信息检索窗口的代码</title>
    <!-- 原作博客地址:http://blog.csdn.net/a497785609/article/details/24009031 -->
    <!--css-->
    <link href="style/demo.css" rel="stylesheet" type="text/css" />
    <!--javascript-->
    <script src="scripts/jquery-1.9.1.js" type="text/javascript"></script>
    <script src="scripts/demo.js" type="text/javascript"></script>
<script type="text/javascript" src="http://api.map.baidu.com/api?v=2.0&ak=IDvNBsejl9oqMbPF316iKsXR"></script>
<script type="text/javascript" src="http://api.map.baidu.com/library/SearchInfoWindow/1.5/src/SearchInfoWindow_min.js"></script>
<link rel="stylesheet" href="http://api.map.baidu.com/library/SearchInfoWindow/1.5/src/SearchInfoWindow_min.css" />
</head>
<body>
    <div class="demo_main">
        <fieldset class="demo_title">
            百度地图API显示多个标注点带提示的代码
        </fieldset>
        <fieldset class="demo_content">
            <div style="min-height: 300px; width: 100%;" id="map">
            </div>
            <script type="text/javascript">
                var markerArr = [
                    { title: "名称:广州火车站", point: "113.264531,23.157003", address: "广东省广州市广州火车站", tel: "12306" },
                    { title: "名称:广州塔(赤岗塔)", point: "113.330934,23.113401", address: "广东省广州市广州塔(赤岗塔) ", tel: "18500000000" },
                    { title: "名称:广州动物园", point: "113.312213,23.147267", address: "广东省广州市广州动物园", tel: "18500000000" },
                    { title: "名称:天河公园", point: "113.372867,23.134274", address: "广东省广州市天河公园", tel: "18500000000" }
                function map_init() {undefined
                    var map = new BMap.Map("map"); // 创建Map实例
                    var point = new BMap.Point(113.312213, 23.147267); //地图中心点,广州市
                    map.centerAndZoom(point, 13); // 初始化地图,设置中心点坐标和地图级别。
                    map.enableScrollWheelZoom(true); //启用滚轮放大缩小
                    //地图、卫星、混合模式切换
                    map.addControl(new BMap.MapTypeControl({mapTypes: [BMAP_NORMAL_MAP, BMAP_SATELLITE_MAP, BMAP_HYBRID_MAP]}));
                    //向地图中添加缩放控件
                    var ctrlNav = new window.BMap.NavigationControl({undefined
                        anchor: BMAP_ANCHOR_TOP_LEFT,
                        type: BMAP_NAVIGATION_CONTROL_LARGE
                    map.addControl(ctrlNav);
                    //向地图中添加缩略图控件
                    var ctrlOve = new window.BMap.OverviewMapControl({undefined
                        anchor: BMAP_ANCHOR_BOTTOM_RIGHT,
                        isOpen: 1
                    map.addControl(ctrlOve);
                    //向地图中添加比例尺控件
                    var ctrlSca = new window.BMap.ScaleControl({undefined
                        anchor: BMAP_ANCHOR_BOTTOM_LEFT
                    map.addControl(ctrlSca);
                    var point = new Array(); //存放标注点经纬信息的数组
                    var marker = new Array(); //存放标注点对象的数组
                    var info = new Array(); //存放提示信息窗口对象的数组
                    var searchInfoWindow =new Array();//存放检索信息窗口对象的数组
                    for (var i = 0; i < markerArr.length; i++) {undefined
                        var p0 = markerArr[i].point.split(",")[0]; //
                        var p1 = markerArr[i].point.split(",")[1]; //按照原数组的point格式将地图点坐标的经纬度分别提出来
                        point[i] = new window.BMap.Point(p0, p1); //循环生成新的地图点
                        marker[i] = new window.BMap.Marker(point[i]); //按照地图点坐标生成标记
                        map.addOverlay(marker[i]);
                        marker[i].setAnimation(BMAP_ANIMATION_BOUNCE); //跳动的动画
              //显示marker的title,marker多的话可以注释掉
                        var label = new window.BMap.Label(markerArr[i].title, { offset: new window.BMap.Size(20, -10) });
                        marker[i].setLabel(label);
                        // 创建信息窗口对象
                        info[i] = "<p style=’font-size:12px;lineheight:1.8em;’>" + "</br>地址:" + markerArr[i].address + "</br> 电话:" + markerArr[i].tel + "</br></p>";
                        //创建百度样式检索信息窗口对象
                        searchInfoWindow[i] = new BMapLib.SearchInfoWindow(map, info[i], {undefined
                                title  : markerArr[i].title,      //标题
                                width  : 290,             //宽度
                                height : 55,              //高度
                                panel  : "panel",         //检索结果面板
                                enableAutoPan : true,     //自动平移
                                searchTypes   :[
                                    BMAPLIB_TAB_SEARCH,   //周边检索
                                    BMAPLIB_TAB_TO_HERE,  //到这里去
                                    BMAPLIB_TAB_FROM_HERE //从这里出发
                        //添加点击事件
                        marker[i].addEventListener("click",
                            (function(k){undefined
                                // js 闭包
                                return function(){undefined
                                    //将被点击marker置为中心
                                    //map.centerAndZoom(point[k], 18);
                                    //在marker上打开检索信息窗口
                                    searchInfoWindow[k].open(marker[k]);
                            })(i)
                //异步调用百度js
                function map_load() {undefined
                    var load = document.createElement("script");
                    load.src = "http://api.map.baidu.com/api?v=2.0&ak=IDvNBsejl9oqMbPF316iKsXR&callback=map_init";
                    document.body.appendChild(load);
                window.onload = map_load;
            </script>
        </fieldset>
    </div>
</body>
</html>
原文链接:blog.csdn.net/lxw1844912514/article/details/100029348
