nginx.conf文件
lxw1844912514 发表于 2022/03/27 01:52:05 2022/03/27
【摘要】 user  www www; worker_processes auto; error_log  /home/wwwlogs/nginx_error.log  crit; pid        /usr/lo...
user  www www;
pid        /usr/local/nginx/logs/nginx.pid;
#Specifies the value for maximum file descriptors that can be opened by this process.
worker_rlimit_nofile 51200;
events
        use epoll;
        worker_connections 51200;
        multi_accept on;
http
        include       mime.types;
        default_type  application/octet-stream;
        server_names_hash_bucket_size 128;
        client_header_buffer_size 32k;
        large_client_header_buffers 4 32k;
        client_max_body_size 50m;
        sendfile   on;
        tcp_nopush on;
        keepalive_timeout 60;
        tcp_nodelay on;
        fastcgi_connect_timeout 300;
        fastcgi_send_timeout 300;
        fastcgi_read_timeout 300;
        fastcgi_buffer_size 64k;
        fastcgi_buffers 4 64k;
        fastcgi_busy_buffers_size 128k;
        fastcgi_temp_file_write_size 256k;
        gzip on;
        gzip_min_length  1k;
        gzip_buffers     4 16k;
        gzip_http_version 1.1;
        gzip_comp_level 2;
        gzip_types     text/plain application/javascript application/x-javascript text/javascript text/css application/xml application/xml+rss;
        gzip_vary on;
        gzip_proxied   expired no-cache no-store private auth;
        gzip_disable   "MSIE [1-6]\.";
原文链接:blog.csdn.net/lxw1844912514/article/details/100027298
