php 使用 ffmpeg 转换视频,截图,并生成缩略图
lxw1844912514 发表于 2022/03/27 03:11:28 2022/03/27
【摘要】 http://blog.csdn.net/toss156/article/details/7003059 把ffmpeg 和  生成缩略图整合了一下。 include("ImageResize.class.php")   //转视频   $cmd="ffm...
  1. include("ImageResize.class.php")
  2.  //转视频
  3.  $cmd="ffmpeg.exe -i starwar.avi -ab 56 -ar 22050 -b 500 -r 15 -s 320x240 1.flv";
  4.  exec($cmd);
  5.  //视频截图
  6.  $cmd="ffmpeg.exe -i starwar.avi -f image2 -ss 10 -s 400*300 -vframes 1 1.jpg";
  7.  exec($cmd);
  8.  //生成缩略图
  9.  $thumbnail = new ImageResize();
  10.  $thumbnail->resizeimage("1.jpg", 30,30, 0, "small1.jpg");
  11.
  12.
  13. class ImageResize {
  14.
  15.     //图片类型
  16.     var $type;
  17.
  18.     //实际宽度
  19.     var $width;
  20.
  21.     //实际高度
  22.     var $height;
  23.
  24.     //改变后的宽度
  25.     var $resize_width;
  26.
  27.     //改变后的高度
  28.     var $resize_height;
  29.
  30.     //是否裁图
  31.     var $cut;
  32.
  33.     //源图象
  34.     var $srcimg;
  35.
  36.     //目标图象地址
  37.     var $dstimg;
  38.
  39.     //临时创建的图象
  40.     var $im;
  41.
  42. function resizeimage($img, $wid, $hei,$c,$dstpath) {
  43.         $this->srcimg = $img;
  44.         $this->resize_width = $wid;
  45.         $this->resize_height = $hei;
  46.         $this->cut = $c;
  47.
  48.         //图片的类型
  49.         $this->type = strtolower(substr(strrchr($this->srcimg,"."),1));
  50.
  51.         //初始化图象
  52.         $this->initi_img();
  53.
  54.         //目标图象地址
  55.         $this -> dst_img($dstpath);
  56.
  57.         //--
  58.         $this->width = imagesx($this->im);
  59.         $this->height = imagesy($this->im);
  60.
  61.         //生成图象
  62.         $this->newimg();
  63.
  64.         ImageDestroy ($this->im);
  65.     }
  66.
  67. function newimg() {
  68.
  69. //改变后的图象的比例
  70.         $resize_ratio = ($this->resize_width)/($this->resize_height);
  71.
  72. //实际图象的比例
  73.         $ratio = ($this->width)/($this->height);
  74.
  75. if(($this->cut)=="1") {
  76.             //裁图 高度优先
  77.             if($ratio>=$resize_ratio){
  78.                 $newimg = imagecreatetruecolor($this->resize_width,$this->resize_height);
  79.                 imagecopyresampled($newimg, $this->im, 0, 0, 0, 0, $this->resize_width,$this->resize_height, (($this->height)*$resize_ratio), $this->height);
  80.                 ImageJpeg ($newimg,$this->dstimg);
  81.             }
  82.
  83.             //裁图 宽度优先
  84.             if($ratio<</span>$resize_ratio) {
  85.                 $newimg = imagecreatetruecolor($this->resize_width,$this->resize_height);
  86.                 imagecopyresampled($newimg, $this->im, 0, 0, 0, 0, $this->resize_width, $this->resize_height, $this->width, (($this->width)/$resize_ratio));
  87.                 ImageJpeg ($newimg,$this->dstimg);
  88.             }
  89.         } else {
  90.             //不裁图
  91.             if($ratio>=$resize_ratio) {
  92.                 $newimg = imagecreatetruecolor($this->resize_width,($this->resize_width)/$ratio);
  93.                 imagecopyresampled($newimg, $this->im, 0, 0, 0, 0, $this->resize_width, ($this->resize_width)/$ratio, $this->width, $this->height);
  94.                 ImageJpeg ($newimg,$this->dstimg);
  95.             }
  96.             if($ratio<</span>$resize_ratio) {
  97.                 $newimg = imagecreatetruecolor(($this->resize_height)*$ratio,$this->resize_height);
  98.                 imagecopyresampled($newimg, $this->im, 0, 0, 0, 0, ($this->resize_height)*$ratio, $this->resize_height, $this->width, $this->height);
  99.                 ImageJpeg ($newimg,$this->dstimg);
  100.             }
  101.         }
  102.     }
  103.
  104. //初始化图象
  105.     function initi_img() {
  106.         if($this->type=="jpg") {
  107.             $this->im = imagecreatefromjpeg($this->srcimg);
  108.         }
  109.
  110.         if($this->type=="gif") {
  111.             $this->im = imagecreatefromgif($this->srcimg);
  112.         }
  113.
  114.         if($this->type=="png") {
  115.             $this->im = imagecreatefrompng($this->srcimg);
  116.         }
  117.
  118.         if($this->type=="bmp") {
  119.             $this->im = $this->imagecreatefrombmp($this->srcimg);
  120.         }
  121.     }
  122.
  123. //图象目标地址
  124.     function dst_img($dstpath) {
  125.         $full_length  = strlen($this->srcimg);
  126.         $type_length  = strlen($this->type);
  127.         $name_length  = $full_length-$type_length;
  128.         $name = substr($this->srcimg,0,$name_length-1);
  129.         $this->dstimg = $dstpath;
  130.         //echo $this->dstimg;
  131.     }
  132.
  133.     function ConvertBMP2GD($src, $dest = false) {
  134.         if(!($src_f = fopen($src, "rb"))) {
  135.             return false;
  136.         }
  137.         if(!($dest_f = fopen($dest, "wb"))) {
  138.             return false;
  139.         }
  140.         $header = unpack("vtype/Vsize/v2reserved/Voffset", fread($src_f,14));
  141.         $info = unpack("Vsize/Vwidth/Vheight/vplanes/vbits/Vcompression/Vimagesize/Vxres/Vyres/Vncolor/Vimportant", fread($src_f, 40));
  142.
  143.         extract($info);
  144.         extract($header);
  145.
  146.         if($type != 0x4D42) { // signature "BM"
  147.             return false;
  148.         }
  149.
  150.         $palette_size = $offset - 54;
  151.         $ncolor = $palette_size / 4;
  152.         $gd_header = "";
  153.         // true-color vs. palette
  154.         $gd_header .= ($palette_size == 0) ? "\xFF\xFE" : "\xFF\xFF";
  155.         $gd_header .= pack("n2", $width, $height);
  156.         $gd_header .= ($palette_size == 0) ? "\x01" : "\x00";
  157.         if($palette_size) {
  158.             $gd_header .= pack("n", $ncolor);
  159.         }
  160.         // no transparency
  161.         $gd_header .= "\xFF\xFF\xFF\xFF";
  162.
  163. fwrite($dest_f, $gd_header);
  164.
  165. if($palette_size) {
  166.             $palette = fread($src_f, $palette_size);
  167.             $gd_palette = "";
  168.             $j = 0;
  169.             while($j < $palette_size) {
  170.                 $b = $palette{$j++};
  171.                 $g = $palette{$j++};
  172.                 $r = $palette{$j++};
  173.                 $a = $palette{$j++};
  174.                 $gd_palette .= "$r$g$b$a";
  175.             }
  176.             $gd_palette .= str_repeat("\x00\x00\x00\x00", 256 - $ncolor);
  177.             fwrite($dest_f, $gd_palette);
  178.         }
  179.
  180. $scan_line_size = (($bits * $width) + 7) >> 3;
  181.         $scan_line_align = ($scan_line_size & 0x03) ? 4 - ($scan_line_size &
  182.         0x03) : 0;
  183.
  184. for($i = 0, $l = $height - 1; $i < $height; $i++, $l--) {
  185.             // BMP stores scan lines starting from bottom
  186.             fseek($src_f, $offset + (($scan_line_size + $scan_line_align) * $l));
  187.             $scan_line = fread($src_f, $scan_line_size);
  188.             if($bits == 24) {
  189.                 $gd_scan_line = "";
  190.                 $j = 0;
  191.                 while($j < $scan_line_size) {
  192.                     $b = $scan_line{$j++};
  193.                     $g = $scan_line{$j++};
  194.                     $r = $scan_line{$j++};
  195.                     $gd_scan_line .= "\x00$r$g$b";
  196.                 }
  197.             }
  198.             else if($bits == 8) {
  199.                 $gd_scan_line = $scan_line;
  200.             }
  201.             else if($bits == 4) {
  202.                 $gd_scan_line = "";
  203.                 $j = 0;
  204.                 while($j < $scan_line_size) {
  205.                     $byte = ord($scan_line{$j++});
  206.                     $p1 = chr($byte >> 4);
  207.                     $p2 = chr($byte & 0x0F);
  208.                     $gd_scan_line .= "$p1$p2";
  209.                 }
  210.                 $gd_scan_line = substr($gd_scan_line, 0, $width);
  211.             }
  212.             else if($bits == 1) {
  213.                 $gd_scan_line = "";
  214.                 $j = 0;
  215.                 while($j < $scan_line_size) {
  216.                     $byte = ord($scan_line{$j++});
  217.                     $p1 = chr((int) (($byte & 0x80) != 0));
  218.                     $p2 = chr((int) (($byte & 0x40) != 0));
  219.                     $p3 = chr((int) (($byte & 0x20) != 0));
  220.                     $p4 = chr((int) (($byte & 0x10) != 0));
  221.                     $p5 = chr((int) (($byte & 0x08) != 0));
  222.                     $p6 = chr((int) (($byte & 0x04) != 0));
  223.                     $p7 = chr((int) (($byte & 0x02) != 0));
  224.                     $p8 = chr((int) (($byte & 0x01) != 0));
  225.                     $gd_scan_line .= "$p1$p2$p3$p4$p5$p6$p7$p8";
  226.                 }
  227.                 $gd_scan_line = substr($gd_scan_line, 0, $width);
  228.             }
  229.             fwrite($dest_f, $gd_scan_line);
  230.         }
  231.         fclose($src_f);
  232.         fclose($dest_f);
  233.         return true;
  234.     }
  235.
  236. function imagecreatefrombmp($filename) {
  237.         $tmp_name = tempnam("/tmp", "GD");
  238.         if($this->ConvertBMP2GD($filename, $tmp_name)) {
  239.             $img = imagecreatefromgd($tmp_name);
  240.             unlink($tmp_name);
  241.             return $img;
  242.         }
  243.         return false;
  244.     }
  245.
  246. }
源代码下载链接:
                      php使用ffmpeg视频转换,截图,生成缩略图_ffmpeg视频格式转换-PHP代码类资源-CSDN下载
原文链接:blog.csdn.net/lxw1844912514/article/details/100029185
