win7下php7.1运行getenv('REMOTE_ADDR')fastcgi停止运行
lxw1844912514 发表于 2022/03/27 03:34:35 2022/03/27
【摘要】 ```  // 本地环境phpStudy, PHP7.1.13nts+nginx,切换Apache也不行 //ps:php版本<=7.0正常 echo "<pre>"; // $_SERVER获取,正常 var_dump($_SERVER['SERVER_PORT']); // 获取其他环境变量...
//ps:php版本<=7.0正常
echo "<pre>";
// $_SERVER获取,正常
// 获取其他环境变量,正常
var_dump($_SERVER['REMOTE_ADDR']);
// 第二个参数设为true,正常
var_dump(getenv('REMOTE_ADDR', true));
// 崩溃,直接报fastcgi停止运行
var_dump(getenv('REMOTE_ADDR'));
Nginx 错误日志
2018/07/20 11:54:13 [error] 10192#8652: *1 WSARecv() failed (10054: An existing connection was forcibly closed by the remote host) while reading response header from upstream, client: 127.0.0.1, server: localhost, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "127.0.0.1"
分割线
查阅php手册发现正好php7.1.13和7.2.10有此问题,本地环境恰好是这两个版本,更换版本即可。
原文链接:blog.csdn.net/lxw1844912514/article/details/100028830
