linux下vi操作Found a swap file by the name
lxw1844912514 发表于 2022/03/27 03:08:31 2022/03/27
【摘要】 当我在linux下用vi打开Test.java文件时 [root@localhost tmp]# vi Test.java 会出现如下信息:   Dos代码   E325: ATTENTION Found ...
会出现如下信息:
Dos代码   收藏代码
  1. E325: ATTENTION
  2. Found a swap file by the name ".Test.java.swp"
  3. owned by: root dated: Wed Dec 7 13:52:56 2011
  4. file name: /var/tmp/Test.java
  5. modified: YES
  6. user name: root host name: localhost
  7. process ID: 26153 (still running)
  8. While opening file "Test.java"
  9. dated: Wed Dec 7 14:00:46 2011
  10. NEWER than swap file!
  11. (1) Another program may be editing the same file.
  12. If this is the case, be careful not to end up with two
  13. different instances of the same file when making changes.
  14. Quit, or continue with caution.
  15. (2) An edit session for this file crashed.
  16. If this is the case, use ":recover" or "vim -r Test.java"
  17. to recover the changes (see ":help recovery").
  18. If you did this already, delete the swap file ".Test.java.swp"
  19. to avoid this message.
  20. "Test.java" 11L, 237C
  21. Press ENTER or type command to continue
原因是我之前有一次使用vi 操作Test.java文件时出现了异常中断,所以在当前目录下产生了一个.Test.java.swp文件
但是我使用ls命令查看该目录下,却发现没有这个文件,后来使用ls -a命令查看才知道Test.java.swp是一个隐藏文件。
注:以.开头的文件就是隐藏文件
当我把该隐藏文件删除后再次打开就没有上面的警告了。
[root@localhost tmp]# rm .Test.java.swp
rm: remove regular file `.Test.java.swp'? y
原文链接:blog.csdn.net/lxw1844912514/article/details/100029050
