cURL error 60: SSL certificate problem...
lxw1844912514 发表于 2022/03/27 02:07:51 2022/03/27
【摘要】 https://blog.csdn.net/buer2202/article/details/75364589 php在curl的时候报此错误: cURL error 60: SSL certificate problem: unable to get local issuer certificate...
php在curl的时候报此错误:
cURL error 60: SSL certificate problem: unable to get local issuer certificate (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)
根据报错后面提示的地址查询60错误:
  1. CURLE_SSL_CACERT (60)
  2. Peer certificate cannot be authenticated with known CA certificates.
无法获取本地颁发者证书
网上搜的解决方法:(http://stackoverflow.com/questions/29822686/curl-error-60-ssl-certificate-unable-to-get-local-issuer-certificate)
关于“SSL证书问题:无法获取本地颁发者证书”错误。显然,这适用于发送CURL请求的系统(并且没有接收请求的服务器)
===================(亲测可行)===============================
1)从 https://curl.haxx.se/ca/cacert.pem 下载最新的cacert.pem
2)将以下行添加到php.ini(如果这是共享托管和您没有访问php.ini然后你可以添加到.user.ini在public_html)
curl.cainfo=/path/to/downloaded/cacert.pem
3)默认情况下,FastCGI进程将每隔300秒解析新文件(如果需要,您可以通过添加几个文件来更改频率,如这里建议的https://ss88.uk/blog/fast-cgi-and-user-ini -files-the-new-htaccess /)
======================(亲测可行)=============================
原文链接:blog.csdn.net/lxw1844912514/article/details/100028572
