vagrant up提示“Couldn‘t open file /path/to/base“的错误解决方法
lxw1844912514 发表于 2022/03/27 01:15:45 2022/03/27
【摘要】 在vagrant使用命令vagrant up启动虚拟机时 出错: C:\Vagrant>vagrant upBringing machine 'default' up with 'virtualbox' provider...==> default: Box 'base' could not be fo...
出错:
  1. C:\Vagrant>vagrant up
  2. Bringing machine 'default' up with 'virtualbox' provider...
  3. ==> default: Box 'base' could not be found. Attempting to find and install...
  4. default: Box Provider: virtualbox
  5. default: Box Version: >= 0
  6. ==> default: Box file was not detected as metadata. Adding it directly...
  7. ==> default: Adding box 'base' (v0) for provider: virtualbox
  8. default: Downloading: base
  9. default:
  10. An error occurred while downloading the remote file. The error
  11. message, if any, is reproduced below. Please fix this error and try
  12. again.
  13. Couldn't open file /E:/WorkSpace/Vagrant/base
原因分析:
在使用vagrant init命令初始化配置文件的时候未指定虚拟机名称,也就是命令:vagrant box add BoxName boxpath中的BoxName。
解决办法:
1.再来一遍,重新生成Vagrantfile配置文件
vagrant init BoxName
2.修改Vagrantfile文件中config.vm.box参数:
config.vm.box = "base"
将base修改为你的虚拟机名称。
参考:官方链接
原文链接:blog.csdn.net/lxw1844912514/article/details/100028772
