nginx 80端口重定向到443端口
lxw1844912514 发表于 2022/03/27 01:08:56 2022/03/27
【摘要】 nginx 80端口重定向到443端口,也就是http访问自动跳转到https配置如下:一、按照如下格式修改nginx.conf 配置文件,80端口会自动转给443端口,这样就强制使用SSL证书加密了。访问http的时候会自动跳转到https上面。 server { listen 80; server_...
配置如下:
server {
    listen 80;
    server_name www.域名.com;
    rewrite ^(.*)$ https://${server_name}$1 permanent;
server {
    listen 443;
    root /home/wwwroot;
    ssl on;
    ssl_certificate /etc/nginx/certs/server.crt;
    ssl_certificate_key /etc/nginx/certs/server.key;
备注: ${server_name}可以换成$host
二、重启nginx。
三、示例(以下是我们生产的配置)
server {
    listen 80;
    server_name www.test.com;
server {
    listen 443;
    ssl on;
    ssl_certificate   /etc/pki/CA/certs/214321311540956.pem;
    ssl_certificate_key  /etc/pki/CA/certs/214321311540956.key;
    ssl_session_timeout 5m;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    index index.php index.htm index.html;
    error_page 404 /404.html;
    error_page 500 502 503 504 /50x.html;
    location ~ \.php {
    root /alidata/www/html;
    fastcgi_pass unix:/tmp/php-cgi.sock;
    fastcgi_index index.php;
    include   fastcgi.conf;
    set $path_info "";
    set $fastcgi_script_name_new $fastcgi_script_name;
        if ($fastcgi_script_name ~*   "^(.+\.php)(/.+)$"  ) {
            set $fastcgi_script_name_new $1;
        set $path_info $2;
    fastcgi_param   SCRIPT_FILENAME   $document_root$fastcgi_script_name_new;
    fastcgi_param   SCRIPT_NAME   $fastcgi_script_name_new;
    fastcgi_param   PATH_INFO $path_info;
    location / {
    index index.php index.html index.htm;
    if (!-e  $request_filename){
        rewrite ^(.*)$ /index.php$1 last;
作者:幸福丶如此
来源:CSDN
原文:https://blog.csdn.net/m0_37886429/article/details/72271983
版权声明:本文为博主原创文章,转载请附上博文链接!
原文链接:blog.csdn.net/lxw1844912514/article/details/100029324
