php内置函数分析之str_pad()
lxw1844912514 发表于 2022/03/27 01:23:28 2022/03/27
【摘要】 PHP_FUNCTION(str_pad) { /* Input arguments */ zend_string *input; /* Input string 输入字符串*/ zend_long pad_length; /* Length to...
    zend_long pad_length;            /* Length to pad to 填充到多长.*/
    /* Helper variables */
    size_t num_pad_chars;        /* Number of padding characters (total - input size) 要填充进去的字符个数*/
    char *pad_str = " "; /* Pointer to padding string */
    size_t pad_str_len = 1; // 填充字符的个数
    zend_long   pad_type_val = STR_PAD_RIGHT; /* The padding type value 填充类型,左填充、右填充、左右填充。默认右填充*/
    size_t       i, left_pad=0, right_pad=0;
    zend_string *result = NULL;    /* Resulting string 返回值*/
    if (zend_parse_parameters(ZEND_NUM_ARGS(), "Sl|sl", &input, &pad_length, &pad_str, &pad_str_len, &pad_type_val) == FAILURE) {
        return;
    /* If resulting string turns out to be shorter than input string,
       we simply copy the input and return. */
    /* 如果pad_length(参数2)小于等于输入字符串的长度,则返回原始的输入字符串。*/
    if (pad_length < 0  || (size_t)pad_length <= ZSTR_LEN(input)) {
        RETURN_STRINGL(ZSTR_VAL(input), ZSTR_LEN(input));
    /* 填充字符串长度为0,如:str_pad("abc", 10, ""),则Warning级别的错误。
       填充字符串的默认长度为1,即str_pad("abc", 10),的情况下pad_str_len=1。*/
    if (pad_str_len == 0) {
        php_error_docref(NULL, E_WARNING, "Padding string cannot be empty");
        return;
    /*pad_type只能为STR_PAD_LEFT, STR_PAD_RIGHT, or STR_PAD_BOTH 或 0, 1, 2*/
    if (pad_type_val < STR_PAD_LEFT || pad_type_val > STR_PAD_BOTH) {
        php_error_docref(NULL, E_WARNING, "Padding type has to be STR_PAD_LEFT, STR_PAD_RIGHT, or STR_PAD_BOTH");
        return;
    num_pad_chars = pad_length - ZSTR_LEN(input); // 需要被填充进去的字符的数量
    if (num_pad_chars >= INT_MAX) { // num_pad_chars的最大值是2147483647。#define INT_MAX 2147483647
        php_error_docref(NULL, E_WARNING, "Padding length is too long");
        return;
    result = zend_string_safe_alloc(1, ZSTR_LEN(input), num_pad_chars, 0);
    ZSTR_LEN(result) = 0;
    /* We need to figure out the left/right padding lengths. */
    switch (pad_type_val) {
        case STR_PAD_RIGHT:
            left_pad = 0;
            right_pad = num_pad_chars;
            break;
        case STR_PAD_LEFT:
            left_pad = num_pad_chars;
            right_pad = 0;
            break;
        // 左填充数量小于右,left_pad <= right_pad
        case STR_PAD_BOTH:
            left_pad = num_pad_chars / 2;
            right_pad = num_pad_chars - left_pad;
            break;
    /* First we pad on the left. */
    /* 左填充:循环添加字符 */
    for (i = 0; i < left_pad; i++)
        ZSTR_VAL(result)[ZSTR_LEN(result)++] = pad_str[i % pad_str_len];
    /* Then we copy the input string. */
    /* 左填充完成后,附加输入字符串 */
    memcpy(ZSTR_VAL(result) + ZSTR_LEN(result), ZSTR_VAL(input), ZSTR_LEN(input));
    ZSTR_LEN(result) += ZSTR_LEN(input);
    /* Finally, we pad on the right. */
    /* 右填充:循环添加字符串 */
    for (i = 0; i < right_pad; i++)
    // 添加字符串结束标志'\0'
    ZSTR_VAL(result)[ZSTR_LEN(result)] = '\0';
    // 返回新字符串
    RETURN_NEW_STR(result);
原文链接:blog.csdn.net/lxw1844912514/article/details/100028324
