NGINX.conf配置文件支持pathinfo
lxw1844912514 发表于 2022/03/27 03:42:27 2022/03/27
【摘要】 # power by www.php.cn #user nobody; worker_processes 1; #error_log logs/error.log; #error_log logs/error.log notice; #error_log logs/error.log info; #pi...
#user  nobody;
worker_processes  1;
#pid        logs/nginx.pid;
events {
    worker_connections  4096;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #tcp_nodelay on;
  fastcgi_connect_timeout 300;
  fastcgi_send_timeout 300;
  fastcgi_read_timeout 300;
  fastcgi_buffer_size 128k;
  fastcgi_buffers 4 128k;
  fastcgi_busy_buffers_size 256k;
  fastcgi_temp_file_write_size 256k;
  #gzip  on;
  gzip on;
  gzip_min_length  1k;
  gzip_buffers     4 32k;
  gzip_http_version 1.1;
  gzip_comp_level 2;
  gzip_types       text/plain application/x-javascript text/css application/xml;
  gzip_vary on;
  gzip_disable "MSIE [1-6].";
  server_names_hash_bucket_size 128;
  client_max_body_size     100m;
  client_header_buffer_size 256k;
  large_client_header_buffers 4 256k;
    server {
        listen       80;
        server_name  localhost;
        #charset koi8-r;
        #access_log  logs/host.access.log  main;
        root    "D:/phpstudy/PHPTutorial/WWW";
        location / {
            index  index.html index.htm index.php l.php;
           autoindex  off;
        #error_page  404              /404.html;
        # redirect server error pages to the static page /50x.html
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
        # proxy the PHP scripts to Apache listening on 127.0.0.1:80
        #location ~ \.php$ {
        #    proxy_pass   http://127.0.0.1;
        # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
        location ~ \.php(.*)$  {
            fastcgi_pass   127.0.0.1:9000;
            fastcgi_index  index.php;
            fastcgi_split_path_info  ^((?U).+\.php)(/?.+)$;
            fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
            fastcgi_param  PATH_INFO  $fastcgi_path_info;
            fastcgi_param  PATH_TRANSLATED  $document_root$fastcgi_path_info;
            include        fastcgi_params;
        # deny access to .htaccess files, if Apache's document root
        # concurs with nginx's one
        #location ~ /\.ht {
        #    deny  all;
    #以下是移民虚拟主机配置
    server {
        listen       80;
        server_name  hzym.com;
        root    "D:\phpstudy\PHPTutorial\WWW\www.welltrend.com.cn\www";
          location / {
          index  index.php index.html index.htm;
       if (!-e $request_filename) {
       rewrite  ^(.*)$  /index.php?s=$1  last;
       break;
            root   html;
            include        fastcgi.conf;
    server {
        listen       80;
        server_name  m.hzym.com;
          location / {
       break;
            root   html;
###############以下是留学虚拟主机配置#############
        server {
                listen       80;
                server_name  lx.com;
                root    "D:\phpstudy\PHPTutorial\WWW\liuxue";
               location / {
                        break;
                    root   html;
#留学移动端虚拟主机配置#
        server {
                listen       80;
                server_name  m.lx.com;
                root    "D:\phpstudy\PHPTutorial\WWW\m.welltrend-edu.com\public";
               location / {
                        break;
                    root   html;
##########################laravel  #
            server {
                listen       80;
                #server_name  blog.com;   #暂时关闭这个域名
                #root    "D:\phpstudy\PHPTutorial\WWW\laravel\blog\public";
               location / {
                     index  index.php server.php index.html index.htm ;
                       try_files $uri $uri/ /index.php?$query_string;
                        break;
                    root   html;
            #weibo jiekou
            server {
                listen       80;
                server_name  test.open.lixiaowang.top;
               location / {
                        break;
                    root   html;
###################weibo#####################
server {
                listen       80;
                #server_name  test.open.lixiaowang.top;
                root    "D:\phpstudy\PHPTutorial\WWW\2018bak/libweibo-master/";
               location / {
                        break;
                    root   html;
###################QQ登录#####################
server {
                listen       80;
                server_name qq.open.lixiaowang.top;
                root    "D:\phpstudy\PHPTutorial\WWW\2018bak/qqConnect2.1/";
               location / {
                        break;
                    root   html;
    # another virtual host using mix of IP-, name-, and port-based configuration
    #server {
    #    listen       8000;
    #    listen       somename:8080;
    #    server_name  somename  alias  another.alias;
    #    location / {
    #        root   html;
    #        index  index.html index.htm;
    # HTTPS server
    #server {
    #    listen       443;
    #    server_name  localhost;
    #    ssl                  on;
    #    ssl_certificate      cert.pem;
    #    ssl_certificate_key  cert.key;
    #    ssl_session_timeout  5m;
    #    ssl_protocols  SSLv2 SSLv3 TLSv1;
    #    ssl_ciphers  HIGH:!aNULL:!MD5;
    #    ssl_prefer_server_ciphers   on;
    #    location / {
    #        root   html;
include vhosts.conf;
原文链接:blog.csdn.net/lxw1844912514/article/details/100029341
