linux系统安装Memcache
lxw1844912514 发表于 2022/03/27 01:12:05 2022/03/27
【摘要】 Linux系统安装memcached 首先要先安装libevent库。 centos  下执行 yum install libevent libevent-devel 查看memcached 是否已经安装   which memcached //如果已经安...
centos  下执行
查看memcached 是否已经安装
which  memcached    //如果已经安装  输出类似“/usr/bin/memcached”
安装memcached 执行:
yum install memcached
安装php memcached 扩展 php-pecl-memcached
yum -y install php72w-pecl-memcached  //我的PHP版本是php7.2的,如果版本不对会报错误:php72w-common conflicts with php-common-5.4.16-45.el7.x86_64错误
查看是否安装php-pecl-memcached 扩展
php  -m  |  grep  memcache     // 安装成功会输出memcached, 否则没有输
设置开机启动
sudo systemctl enable memcached
启动memcached
1
sudo systemctl start memcached
启动memcached 服务,在终端输入
1
# /usr/local/bin/memcached -d -m 10 -u root -l 192.168.0.200 -p 11211 -c 256 -P /tmp/memcached.pid
查看memcached 监听情况
1
lsof -i tcp:11211   <br>输出<br>COMMAND    PID    USER   FD   TYPE DEVICE SIZE/OFF NODE NAME<br>memcached 5821 vagrant   26u  IPv6  42350      0t0  TCP localhost:memcache (LISTEN)<br>memcached 5821 vagrant   27u  IPv4  42351      0t0  TCP php-site:memcache (LISTEN)
说明监听11211端口成功
会在/usr/lib64/php/modules/ 下生成memcached.so
在php.ini中开启 extension=/usr/lib64/php/modules/memcached.so
1
[Memcache]<br>extension=/usr/lib64/php/modules/memcached.so
 在php.ini文件中添加memcache扩展文件后,在xshell中执行会报错,但不影响web浏览器端效果,
然后重启php-fpm
1
sudo systemctl restart php-fpm
phpinfo()中能够看到memcached
测试:
1
2
3
4
5
6
7
8
9
10
11
12
13
<?php
$mem = new Memcached;
$mem->connect( "127.0.0.1" , 11211);
$mem-> set ( 'key' , 'hello test!' , 0, 60);
$val = $mem-> get ( 'key' );
echo $val;
上面测试代码有问题,我的测试代码:
  1. <?php
  2. $mem = new Memcached;
  3. $mem->addServer("127.0.0.1", 11211);
  4. $mem->set('key', 'hello test!', 10);
  5. $val = $mem->get('key');
  6. echo $val;
原文链接:blog.csdn.net/lxw1844912514/article/details/100028089
