手动清除memcached缓存方法
lxw1844912514 发表于 2022/03/27 01:58:09 2022/03/27
【摘要】 1.查memcache状态/usr/bin/perl /usr/local/src/memcached-1.4.5/scripts/memcached-tool localhost:11211或者telnet localhost 112112.手动清除memcached测试 1). flush_all  ech...
1.查memcache状态
或者
2.手动清除memcached测试
 1). flush_all
  echo "flush_all" | nc localhost 11211
# telnet localhost 11211
Trying 127.0.0.1...
Connected to localhost.localdomain (127.0.0.1).
Escape character is '^]'.
get var_key
VALUE var_key 0 13
test variable
END
flush_all
OK
get var_key
END
quit
Connection closed by foreign host.
 2). 重启memcached进程
 kill $(ps aux|grep memcached|grep -v grep |awk '{print $2}')
/usr/local/memcached/bin/memcached -d -m 256 -p 11211 -u nobody
3)Memcache::flush() immediately invalidates all existing items.
/* procedural API */
$memcache_obj = memcache_connect('memcache_host', 11211);
memcache_flush($memcache_obj);
/* OO API */
$memcache_obj = new Memcache;
$memcache_obj->connect('memcache_host', 11211);
$memcache_obj->flush();
这个测试的表现是请求Memcache::flush()以后仍可以get $key取到值,而且通过memcached-tool 查到该item的max_age并无变化.
参考链接
MicrosoftInternetExplorer402DocumentNotSpecified7.8Normal0
理解 Memcache 的服务器端与客户端
原文链接:blog.csdn.net/lxw1844912514/article/details/100029027
