HTTP错误代码大全
lxw1844912514 发表于 2022/03/27 01:14:10 2022/03/27
【摘要】   HTTP出错大全 101 - Switching Protocols Top Success Codes 200 - OK201 - Created202 - Accepted203 - Non-Authoritative...
HTTP出错大全
Top
Success Codes
200 - OK
201 - Created
202 - Accepted
203 - Non-Authoritative Information (for DNS)
204 - No Content
205 - Reset Content
206 - Partial Content
Top
Redirection Codes
300 - Multiple Choices
301 - Moved Permanently
302 - Moved Temporarily
303 - See Other
304 - Not Modified
305 - Use Proxy
307 - Redirect Keep Verb
Top
Failure Codes
400 - Bad Request
401 - Unauthorized
402 - Payment Required
403 - Forbidden
404 - Not Found
405 - Bad Request
406 - Not Acceptable
407 - Proxy Authentication Required
408 - Request Timed-Out
409 - Conflict
410 - Gone
411 - Length Required
412 - Precondition Failed
413 - Request Entity Too Large
414 - Request, URI Too Large
415 - Unsupported Media Type
Top
Server Error Codes
500 - Internal Server Error
501 - Not Implemented
502 - Bad Gateway
503 - Server Unavailable
504 - Gateway Timed-Out
505 - HTTP Version not supported
Top
Internet API Error Codes
12001 - Out of Handles
12002 - Timeout
12003 - Extended Error
12004 - Internal Error
12005 - Invalid URL
12006 - Unrecognized Scheme
12007 - Name Not Resolved
12008 - Protocol Not Found
12009 - Invalid Option
12010 - Bad Option Length
12011 - Option not Settable
12012 - Shutdown
12013 - Incorrect User Name
12014 - Incorrect Password
12015 - Login Failure
12016 - Invalid Option
12017 - Operation Cancelled
12018 - Incorrect Handle Type
12019 - Inccorect Handle State
12020 - Not Proxy Request
12021 - Registry Value Not Found
12022 - Bad Registry Parameter
12023 - No Direct Access
12024 - No Content
12025 - No Callback
12026 - Request Pending
12027 - Incorrect Format
12028 - Item Not Found
12029 - Cannot Connect
12030 - Connection Aborted
12031 - Connection Reset
12032 - Force Retry
12033 - Invalid Proxy Request
12034 - Need UI
12035 - Not Defined in WinInet
12036 - Handle Exists
12037 - See Cert Date Invalid
12038 - See Cert CN Invalid
12039 - HTTP to HTTPS on Redir
12040 - HTTPs to HTTP on Redir
12041 - Mixed Security
12042 - Chg Post is Non Secure
12043 - Post is Non Secure
12044 - Client Auth Cert Needed
12045 - Invalid CA (Cert)
12046 - Client Auth Not Setup
12047 - Async Thread Failed
12048 - Redirect Scheme Changed
12049 - Dialog Pending
12050 - Retry Dialog
12052 - Https Http Submit Redir
12053 - Insert Cdrom
12171 - Failed DueToSecurityCheck
Top
FTP API Error Codes
12110 - Transfer in Progress
12111 - FTP Dropped
Top
Gopher API Error Codes
12130 - Protocol Error
12131 - Not File
12132 - Data Error
12133 - End of Data
12134 - Invalid Locator
12135 - Invalid Locator Type
12136 - Not Gopher Plus
12137 - Attribute Not Found
12138 - Unknown Locator
Top
HTTP API Error Codes
12150 - Header Not Found
12151 - Downlevel Server
12152 - Invalid Server Response
12153 - Invalid Header
12154 - Invalid Query Request
12155 - Header Already Exists
12156 - Redirect Failed
12157 - Security Channel Error
12158 - Unable to Cache File
12159 - TCP/IP not installed
12160 - Not Redirected
12161 - Cookie Needs Confirmation
12162 - Cookie Declined
12168 - Redirect Needs Confirmation
Top
Additional Internet API Error Codes
12158 - Unable To Cache File
12159 - Tcpip Not Installed
12163 - Disconnected
12164 - Server Unreachable
12165 - Proxy Server Unreachable
12166 - Bad Auto Proxy Script
12167 - Unable To Download Script
12169 - Sec Invalid Cert
12170 - Sec Cert Revoked
HTTP常见错误
HTTP 错误 400
400 请求出错
由于语法格式有误,服务器无法理解此请求。不作修改,客户程序就无法重复此请求。
HTTP 错误 401
401.1 未授权:登录失败
此错误表明传输给服务器的证书与登录服务器所需的证书不匹配。
请与 Web 服务器的管理员联系,以确认您是否具有访问所请求资源的权限。
401.2 未授权:服务器的配置导致登录失败
此错误表明传输给服务器的证书与登录服务器所需的证书不匹配。此错误通常由未发送正确的 WWW 验证表头字段所致。
401.3 未授权:由于资源中的 ACL 而未授权
此错误表明客户所传输的证书没有对服务器中特定资源的访问权限。此资源可能是客户机中的地址行所列出的网页或文件,也可能是处理客户机中的地址行所列出的文件所需服务器上的其他文件。
请记录试图访问的完整地址,并与 Web 服务器的管理员联系以确认您是否具有访问所请求资源的权限。
401.4 未授权:授权服务被筛选程序拒绝
此错误表明 Web 服务器已经安装了筛选程序,用以验证连接到服务器的用户。此筛选程序拒绝连接到此服务器的真品证书的访问。
401.5 未授权:ISAPI/CGI 应用程序的授权失败
此错误表明试图使用的 Web服务器中的地址已经安装了 ISAPI 或 CGI程序,在继续之前用以验证用户的证书。此程序拒绝用来连接到服务器的真品证书的访问。
请记录试图访问的完整地址,并与 Web服务器的管理员联系以确认您是否具有访问所请求资源的权限
HTTP 错误 403
403.1 禁止:禁止执行访问
如果从并不允许执行程序的目录中执行 CGI、ISAPI或其他执行程序就可能引起此错误。
如果问题依然存在,请与 Web 服务器的管理员联系。
403.2 禁止:禁止读取访问
如果没有可用的默认网页或未启用此目录的目录浏览,或者试图显示驻留在只标记为执行或脚本权限的目录中的HTML 页时就会导致此错误。
403.3 禁止:禁止写访问
如果试图上载或修改不允许写访问的目录中的文件,就会导致此问题。
如果问题依然存在,请与 Web服务器的管理员联系。
403.4 禁止:需要 SSL
此错误表明试图访问的网页受安全套接字层(SSL)的保护。要查看,必须在试图访问的地址前输入https:// 以启用 SSL。
403.5 禁止:需要 SSL 128
此错误消息表明您试图访问的资源受 128位的安全套接字层(SSL)保护。要查看此资源,需要有支持此SSL 层的浏览器。
请确认浏览器是否支持 128 位 SSL安全性。如果支持,就与 Web服务器的管理员联系,并报告问题。
403.6 禁止:拒绝 IP 地址
如果服务器含有不允许访问此站点的 IP地址列表,并且您正使用的 IP地址在此列表中,就会导致此问题。
403.7 禁止:需要用户证书
当试图访问的资源要求浏览器具有服务器可识别的用户安全套接字层(SSL)证书时就会导致此问题。可用来验证您是否为此资源的合法用户。
请与 Web服务器的管理员联系以获取有效的用户证书。
403.8 禁止:禁止站点访问
如果 Web服务器不为请求提供服务,或您没有连接到此站点的权限时,就会导致此问题。
请与 Web 服务器的管理员联系。
403.9 禁止访问:所连接的用户太多
如果 Web太忙并且由于流量过大而无法处理您的请求时就会导致此问题。请稍后再次连接。
403.10 禁止访问:配置无效
此时 Web 服务器的配置存在问题。
403.11 禁止访问:密码已更改
在身份验证的过程中如果用户输入错误的密码,就会导致此错误。请刷新网页并重试。
403.12 禁止访问:映射程序拒绝访问
拒绝用户证书试图访问此 Web 站点。
请与站点管理员联系以建立用户证书权限。如果必要,也可以更改用户证书并重试。
HTTP 错误 404
404 找不到
Web 服务器找不到您所请求的文件或脚本。请检查URL 以确保路径正确。
如果问题依然存在,请与服务器的管理员联系。
HTTP 错误 405
405 不允许此方法
对于请求所标识的资源,不允许使用请求行中所指定的方法。请确保为所请求的资源设置了正确的 MIME 类型。
HTTP 错误 406
406 不可接受
根据此请求中所发送的“接受”标题,此请求所标识的资源只能生成内容特征为“不可接受”的响应实体。
HTTP 错误 407
407 需要代理身份验证
在可为此请求提供服务之前,您必须验证此代理服务器。请登录到代理服务器,然后重试。
HTTP 错误 412
412 前提条件失败
在服务器上测试前提条件时,部分请求标题字段中所给定的前提条件估计为FALSE。客户机将前提条件放置在当前资源 metainformation(标题字段数据)中,以防止所请求的方法被误用到其他资源。
HTTP 错误 414
414 Request-URI 太长
Request-URL太长,服务器拒绝服务此请求。仅在下列条件下才有可能发生此条件:
客户机错误地将 POST 请求转换为具有较长的查询信息的 GET 请求。
客户机遇到了重定向问题(例如,指向自身的后缀的重定向前缀)。
服务器正遭受试图利用某些服务器(将固定长度的缓冲区用于读取或执行 Request-URI)中的安全性漏洞的客户干扰。
HTTP 错误 500
500 服务器的内部错误
Web 服务器不能执行此请求。请稍后重试此请求。
HTTP 错误 501
501 未实现
Web 服务器不支持实现此请求所需的功能。请检查URL 中的错误,如果问题依然存在,请与 Web服务器的管理员联系。
HTTP 错误 502
502 网关出错
当用作网关或代理时,服务器将从试图实现此请求时所访问的upstream 服务器中接收无效的响应。
如果问题依然存在,请与 Web服务器的管理员联HTTP常见错误
HTTP 错误 400
400 请求出错
HTTP 错误 401
401.1 未授权:登录失败
HTTP 错误 403
403.1 禁止:禁止执行访问
403.2 禁止:禁止读取访问
403.3 禁止:禁止写访问
403.4 禁止:需要 SSL
403.5 禁止:需要 SSL 128
403.6 禁止:拒绝 IP 地址
403.7 禁止:需要用户证书
403.8 禁止:禁止站点访问
请与 Web 服务器的管理员联系。
403.9 禁止访问:所连接的用户太多
403.10 禁止访问:配置无效
此时 Web 服务器的配置存在问题。
403.11 禁止访问:密码已更改
拒绝用户证书试图访问此 Web 站点。
HTTP 错误 404
404 找不到
HTTP 错误 405
405 不允许此方法
HTTP 错误 406
406 不可接受
HTTP 错误 407
407 需要代理身份验证
HTTP 错误 412
412 前提条件失败
HTTP 错误 414
414 Request-URI 太长
HTTP 错误 500
500 服务器的内部错误
HTTP 错误 501
501 未实现
HTTP 错误 502
502 网关出错
HTTP 错误 400
400 请求出错
HTTP 错误 401
401.1 未授权:登录失败
HTTP 错误 403
403.1 禁止:禁止执行访问
403.2 禁止:禁止读取访问
403.3 禁止:禁止写访问
403.4 禁止:需要 SSL
403.5 禁止:需要 SSL 128
403.6 禁止:拒绝 IP 地址
403.7 禁止:需要用户证书
403.8 禁止:禁止站点访问
请与 Web 服务器的管理员联系。
403.9 禁止访问:所连接的用户太多
403.10 禁止访问:配置无效
此时 Web 服务器的配置存在问题。
403.11 禁止访问:密码已更改
拒绝用户证书试图访问此 Web 站点。
HTTP 错误 404
404 找不到
HTTP 错误 405
405 不允许此方法
HTTP 错误 406
406 不可接受
HTTP 错误 407
407 需要代理身份验证
HTTP 错误 412
412 前提条件失败
HTTP 错误 414
414 Request-URI 太长
HTTP 错误 500
500 服务器的内部错误
HTTP 错误 501
501 未实现
HTTP 错误 502
502 网关出错
原文链接:blog.csdn.net/lxw1844912514/article/details/100027894
