ajax无刷新删除
原来是咔咔 发表于 2022/03/27 00:49:38 2022/03/27
【摘要】  author:咔咔 wechat:fangkangfk 总结:其实就是点击删除的时候,直接将父级移除就可以了 //js代码$('.coupondelete').click(function(){ var that = $(this); if(confirm('您确定要删除')) { var ...
 author:咔咔
wechat:fangkangfk
  1. //js代码
  2. $('.coupondelete').click(function(){
  3. var that = $(this);
  4. if(confirm('您确定要删除')) {
  5. var data = {'id':that.data('id')}
  6. $.ajax({
  7. url:"{:U('/addon/WeiuidDeit/web/foodcouponDelect')}",
  8. type:'POST',
  9. data:data,
  10. dataType:'json',
  11. success:function(data){
  12. data = JSON.parse(data);
  13. if(data.error == 200){
  14. //直接移除父级的标签
  15. that.parents('tr').remove();
  16. }
  17. alert(data.msg);
  18. },
  19. error:function(){alert('删除出错')}
  20. })
  21. }
  22. })
后台控制器
  1. // 优惠卷删除
  2. public function foodcouponDelect()
  3. {
  4. $id = $_POST['id'];
  5. if (M('foodcoupon')->delete($id)) {
  6. $code['msg'] = '删除成功';
  7. $code['error'] = '200';
  8. } else {
  9. $code['msg'] = '删除失败';
  10. $code['error'] = '400';
  11. }
  12. $this->ajaxReturn(json_encode($code));
  13. }
文章来源: blog.csdn.net,作者:咔咔-,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/fangkang7/article/details/83477147
