PHP 7.2警告: “Cannot change session name when session is active”
lxw1844912514 发表于 2022/03/26 23:41:24 2022/03/26
【摘要】 项目在php7.1 版本正常,迁移服务器php 7.2 报错   Maybe it's a warning but with Tracy I have an error. To solve this I put session_write_close(); before sessio...
To solve this I put session_write_close(); before session_set_cookie_params();. It's not a good fix but it's works
session_name() as well as session_set_cookie_params() are always nonesense if the session is already running.
翻译: session_name()以及session_set_cookie_params()总是不存在意义的,如果会话已在运行。
I had a similar problem but finally found a way through. The code below was my first approach that gave me errors.
  1. static function startmysession($lifetime, $path, $domain, $secure, $httponly){
  2. session_set_cookie_params($lifetime, $path, $domain, $secure, $httponly);
  3. session_regenerate_id(true);
  4. if(!isset($_SESSION)){
  5. session_start();
  6. }
  7. }
Now Earlier versions of php overlooked our mistake(We were practically renaming and giving a session that already exists properties which is very wrong. So how did i solve this problem?(现在php的早期版本忽略了我们的错误(我们实际上是在重命名和提供一个已经存在的会话属性,这是非常错误的)。那么我是如何解决这个问题的呢?)
  2. if(!isset($_SESSION)){
  3. session_set_cookie_params($lifetime, $path, $domain, $secure, $httponly);
  4. @session_regenerate_id(true);
  5. session_start();
  6. }
  7. }
I now bound the session_set_cookie_params() just before session start and I test if the session already exists before doing so.(现在,我在会话开始之前绑定了会话session_set_cookie_params(),并在此之前测试会话是否已经存在。)
My solution:
Originally:
  1. $cookieParams = session_get_cookie_params();
  3. $seconds,
  4. $cookieParams['path'],
  5. $cookieParams['domain'],
  6. $cookieParams['secure']
  7. );
Now:
  1. if(isset($_SESSION)) {
  2. if ($seconds != 0) {
  3. setcookie(session_name(), session_id(), time() + $seconds);
  4. } else {
  5. setcookie(session_name(), session_id(), $seconds);
  6. }
  7. } else {
  8. $cookieParams = session_get_cookie_params();
  9. session_set_cookie_params(
  10. $seconds,
  11. $cookieParams['path'],
  12. $cookieParams['domain'],
  13. $cookieParams['secure']
  14. );
  15. }
参考:PHP 7.2 Warning: "Cannot change session name when session is active" - Stack Overflow
原文链接:blog.csdn.net/lxw1844912514/article/details/115113162
