蓝桥ROS机器人之第一个功能包helloros
zhangrelay 发表于 2022/03/25 23:23:31 2022/03/25
【摘要】 helloros   cmake_minimum_required(VERSION 2.8.3)project(helloros) ## Compile as C++11, supported in ROS Kinetic and newer# add_compile_options(-std=c++11) ## ...
helloros
  1. cmake_minimum_required(VERSION 2.8.3)
  2. project(helloros)
  3. ## Compile as C++11, supported in ROS Kinetic and newer
  4. # add_compile_options(-std=c++11)
  5. ## Find catkin macros and libraries
  6. ## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
  7. ## is used, also find other catkin packages
  8. find_package(catkin REQUIRED COMPONENTS
  9. roscpp
  10. )
  11. ## System dependencies are found with CMake's conventions
  12. # find_package(Boost REQUIRED COMPONENTS system)
  13. ## Uncomment this if the package has a setup.py. This macro ensures
  14. ## modules and global scripts declared therein get installed
  15. ## See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html
  16. # catkin_python_setup()
  17. ################################################
  18. ## Declare ROS messages, services and actions ##
  19. ################################################
  20. ## To declare and build messages, services or actions from within this
  21. ## package, follow these steps:
  22. ## * Let MSG_DEP_SET be the set of packages whose message types you use in
  23. ## your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
  24. ## * In the file package.xml:
  25. ## * add a build_depend tag for "message_generation"
  26. ## * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
  27. ## * If MSG_DEP_SET isn't empty the following dependency has been pulled in
  28. ## but can be declared for certainty nonetheless:
  29. ## * add a exec_depend tag for "message_runtime"
  30. ## * In this file (CMakeLists.txt):
  31. ## * add "message_generation" and every package in MSG_DEP_SET to
  32. ## find_package(catkin REQUIRED COMPONENTS ...)
  33. ## * add "message_runtime" and every package in MSG_DEP_SET to
  34. ## catkin_package(CATKIN_DEPENDS ...)
  35. ## * uncomment the add_*_files sections below as needed
  36. ## and list every .msg/.srv/.action file to be processed
  37. ## * uncomment the generate_messages entry below
  38. ## * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
  39. ## Generate messages in the 'msg' folder
  40. # add_message_files(
  41. # FILES
  42. # Message1.msg
  43. # Message2.msg
  44. # )
  45. ## Generate services in the 'srv' folder
  46. # add_service_files(
  47. # FILES
  48. # Service1.srv
  49. # Service2.srv
  50. # )
  51. ## Generate actions in the 'action' folder
  52. # add_action_files(
  53. # FILES
  54. # Action1.action
  55. # Action2.action
  56. # )
  57. ## Generate added messages and services with any dependencies listed here
  58. # generate_messages(
  59. # DEPENDENCIES
  60. # std_msgs # Or other packages containing msgs
  61. # )
  62. ################################################
  63. ## Declare ROS dynamic reconfigure parameters ##
  64. ################################################
  65. ## To declare and build dynamic reconfigure parameters within this
  66. ## package, follow these steps:
  67. ## * In the file package.xml:
  68. ## * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
  69. ## * In this file (CMakeLists.txt):
  70. ## * add "dynamic_reconfigure" to
  71. ## find_package(catkin REQUIRED COMPONENTS ...)
  72. ## * uncomment the "generate_dynamic_reconfigure_options" section below
  73. ## and list every .cfg file to be processed
  74. ## Generate dynamic reconfigure parameters in the 'cfg' folder
  75. # generate_dynamic_reconfigure_options(
  76. # cfg/DynReconf1.cfg
  77. # cfg/DynReconf2.cfg
  78. # )
  79. ###################################
  80. ## catkin specific configuration ##
  81. ###################################
  82. ## The catkin_package macro generates cmake config files for your package
  83. ## Declare things to be passed to dependent projects
  84. ## INCLUDE_DIRS: uncomment this if your package contains header files
  85. ## LIBRARIES: libraries you create in this project that dependent projects also need
  86. ## CATKIN_DEPENDS: catkin_packages dependent projects also need
  87. ## DEPENDS: system dependencies of this project that dependent projects also need
  88. catkin_package(
  89. # INCLUDE_DIRS include
  90. # LIBRARIES helloros
  91. # CATKIN_DEPENDS roscpp
  92. # DEPENDS system_lib
  93. )
  94. ###########
  95. ## Build ##
  96. ###########
  97. ## Specify additional locations of header files
  98. ## Your package locations should be listed before other locations
  99. include_directories(
  100. # include
  101. ${catkin_INCLUDE_DIRS}
  102. )
  103. ## Declare a C++ library
  104. # add_library(${PROJECT_NAME}
  105. # src/${PROJECT_NAME}/helloros.cpp
  106. # )
  107. ## Add cmake target dependencies of the library
  108. ## as an example, code may need to be generated before libraries
  109. ## either from message generation or dynamic reconfigure
  110. # add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
  111. ## Declare a C++ executable
  112. ## With catkin_make all packages are built within a single CMake context
  113. ## The recommended prefix ensures that target names across packages don't collide
  114. # add_executable(${PROJECT_NAME}_node src/helloros_node.cpp)
  115. add_executable(${PROJECT_NAME}_node src/helloros.cpp)
  116. ## Rename C++ executable without prefix
  117. ## The above recommended prefix causes long target names, the following renames the
  118. ## target back to the shorter version for ease of user use
  119. ## e.g. "rosrun someones_pkg node" instead of "rosrun someones_pkg someones_pkg_node"
  120. # set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX "")
  121. ## Add cmake target dependencies of the executable
  122. ## same as for the library above
  123. # add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
  124. ## Specify libraries to link a library or executable target against
  125. # target_link_libraries(${PROJECT_NAME}_node
  126. # ${catkin_LIBRARIES}
  127. # )
  128. target_link_libraries(${PROJECT_NAME}_node
  129. ${catkin_LIBRARIES}
  130. )
  131. #############
  132. ## Install ##
  133. #############
  134. # all install targets should use catkin DESTINATION variables
  135. # See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html
  136. ## Mark executable scripts (Python etc.) for installation
  137. ## in contrast to setup.py, you can choose the destination
  138. # install(PROGRAMS
  139. # scripts/my_python_script
  140. # DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
  141. # )
  142. ## Mark executables and/or libraries for installation
  143. # install(TARGETS ${PROJECT_NAME} ${PROJECT_NAME}_node
  144. # ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  145. # LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  146. # RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
  147. # )
  148. ## Mark cpp header files for installation
  149. # install(DIRECTORY include/${PROJECT_NAME}/
  150. # DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
  151. # FILES_MATCHING PATTERN "*.h"
  152. # PATTERN ".svn" EXCLUDE
  153. # )
  154. ## Mark other files for installation (e.g. launch and bag files, etc.)
  155. # install(FILES
  156. # # myfile1
  157. # # myfile2
  158. # DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
  159. # )
  160. #############
  161. ## Testing ##
  162. #############
  163. ## Add gtest based cpp test target and link libraries
  164. # catkin_add_gtest(${PROJECT_NAME}-test test/test_helloros.cpp)
  165. # if(TARGET ${PROJECT_NAME}-test)
  166. # target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
  167. # endif()
  168. ## Add folders to be run by python nosetests
  169. # catkin_add_nosetests(test)
  1. #include <ros/ros.h>
  2. int main ( int argc , char ** argv ) {
  3. // Initialize the ROS system .
  4. ros::init( argc , argv , "hello_ros" );
  5. // Establish this program as a ROS node .
  6. ros::NodeHandle nh;
  7. // Send some output as a log message .
  8. ROS_INFO_STREAM( "Hello nihao, ROS!" );
  9. }
  1. shiyanlou:src/ $ catkin_create_pkg -h [9:38:58]
  2. usage: catkin_create_pkg [-h] [--meta] [-s [SYS_DEPS [SYS_DEPS ...]]]
  3. [-b [BOOST_COMPS [BOOST_COMPS ...]]] [-V PKG_VERSION]
  4. [-D DESCRIPTION] [-l LICENSE] [-a AUTHOR]
  5. [-m MAINTAINER] [--rosdistro ROSDISTRO]
  6. name [dependencies [dependencies ...]]
  7. Creates a new catkin package
  8. positional arguments:
  9. name The name for the package
  10. dependencies Catkin package Dependencies
  11. optional arguments:
  12. -h, --help show this help message and exit
  13. --meta Creates meta-package files
  14. -s [SYS_DEPS [SYS_DEPS ...]], --sys-deps [SYS_DEPS [SYS_DEPS ...]]
  15. System Dependencies
  16. -b [BOOST_COMPS [BOOST_COMPS ...]], --boost-comps [BOOST_COMPS [BOOST_COMPS ...]]
  17. Boost Components
  18. -V PKG_VERSION, --pkg_version PKG_VERSION
  19. Initial Package version
  20. -D DESCRIPTION, --description DESCRIPTION
  21. Description
  22. -l LICENSE, --license LICENSE
  23. Name for License, (e.g. BSD, MIT, GPLv3...)
  24. -a AUTHOR, --author AUTHOR
  25. A single author, may be used multiple times
  26. -m MAINTAINER, --maintainer MAINTAINER
  27. A single maintainer, may be used multiple times
  28. --rosdistro ROSDISTRO
  29. The ROS distro (default: environment variable
  30. ROS_DISTRO if defined)
  31. shiyanlou:src/ $ catkin_create_pkg helloros roscpp [9:39:09]
  32. Created file helloros/package.xml
  33. Created file helloros/CMakeLists.txt
  34. Created folder helloros/include/helloros
  35. Created folder helloros/src
  36. Successfully created files in /home/shiyanlou/Code/helloros/src/helloros. Please adjust the values in package.xml.
  37. shiyanlou:src/ $ cd helloros/src [9:40:06]
  38. shiyanlou:src/ $ ls [9:41:00]
  39. shiyanlou:src/ $ gedit helloros.cpp [9:41:05]
  40. (gedit:1618): GVFS-RemoteVolumeMonitor-WARNING **: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
  41. (gedit:1618): Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
  42. shiyanlou:src/ $ ls [9:48:07]
  43. helloros.cpp
  44. shiyanlou:src/ $ cd .. [9:48:11]
  45. shiyanlou:helloros/ $ l [9:48:14]
  46. \u603b\u7528\u91cf 28K
  47. drwxrwxr-x 4 shiyanlou shiyanlou 4.0K 3\u6708 25 09:47 .
  48. drwxrwxr-x 3 shiyanlou shiyanlou 4.0K 3\u6708 25 09:40 ..
  49. -rw-rw-r-- 1 shiyanlou shiyanlou 6.8K 3\u6708 25 09:47 CMakeLists.txt
  50. drwxrwxr-x 3 shiyanlou shiyanlou 4.0K 3\u6708 25 09:40 include
  51. -rw-rw-r-- 1 shiyanlou shiyanlou 2.6K 3\u6708 25 09:40 package.xml
  52. drwxrwxr-x 2 shiyanlou shiyanlou 4.0K 3\u6708 25 09:44 src
  53. shiyanlou:helloros/ $ cd .. [9:48:16]
  54. shiyanlou:src/ $ cd .. [9:48:21]
  55. shiyanlou:helloros/ $ catkin_make [9:48:23]
  56. Base path: /home/shiyanlou/Code/helloros
  57. Source space: /home/shiyanlou/Code/helloros/src
  58. Build space: /home/shiyanlou/Code/helloros/build
  59. Devel space: /home/shiyanlou/Code/helloros/devel
  60. Install space: /home/shiyanlou/Code/helloros/install
  61. Creating symlink "/home/shiyanlou/Code/helloros/src/CMakeLists.txt" pointing to "/opt/ros/kinetic/share/catkin/cmake/toplevel.cmake"
  62. ####
  63. #### Running command: "cmake /home/shiyanlou/Code/helloros/src -DCATKIN_DEVEL_PREFIX=/home/shiyanlou/Code/helloros/devel -DCMAKE_INSTALL_PREFIX=/home/shiyanlou/Code/helloros/install -G Unix Makefiles" in "/home/shiyanlou/Code/helloros/build"
  64. ####
  65. -- The C compiler identification is GNU 5.4.0
  66. -- The CXX compiler identification is GNU 5.4.0
  67. -- Check for working C compiler: /usr/bin/cc
  68. -- Check for working C compiler: /usr/bin/cc -- works
  69. -- Detecting C compiler ABI info
  70. -- Detecting C compiler ABI info - done
  71. -- Detecting C compile features
  72. -- Detecting C compile features - done
  73. -- Check for working CXX compiler: /usr/bin/c++
  74. -- Check for working CXX compiler: /usr/bin/c++ -- works
  75. -- Detecting CXX compiler ABI info
  76. -- Detecting CXX compiler ABI info - done
  77. -- Detecting CXX compile features
  78. -- Detecting CXX compile features - done
  79. -- Using CATKIN_DEVEL_PREFIX: /home/shiyanlou/Code/helloros/devel
  80. -- Using CMAKE_PREFIX_PATH: /opt/ros/kinetic
  81. -- This workspace overlays: /opt/ros/kinetic
  82. -- Found PythonInterp: /usr/bin/python (found version "2.7.12")
  83. -- Using PYTHON_EXECUTABLE: /usr/bin/python
  84. -- Using Debian Python package layout
  85. -- Using empy: /usr/bin/empy
  86. -- Using CATKIN_ENABLE_TESTING: ON
  87. -- Call enable_testing()
  88. -- Using CATKIN_TEST_RESULTS_DIR: /home/shiyanlou/Code/helloros/build/test_results
  89. -- Found gmock sources under '/usr/src/gmock': gmock will be built
  90. -- Looking for pthread.h
  91. -- Looking for pthread.h - found
  92. -- Looking for pthread_create
  93. -- Looking for pthread_create - not found
  94. -- Looking for pthread_create in pthreads
  95. -- Looking for pthread_create in pthreads - not found
  96. -- Looking for pthread_create in pthread
  97. -- Looking for pthread_create in pthread - found
  98. -- Found Threads: TRUE
  99. -- Found gtest sources under '/usr/src/gmock': gtests will be built
  100. -- Using Python nosetests: /usr/bin/nosetests-2.7
  101. -- catkin 0.7.14
  102. -- BUILD_SHARED_LIBS is on
  103. -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  104. -- ~~ traversing 1 packages in topological order:
  105. -- ~~ - helloros
  106. -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  107. -- +++ processing catkin package: 'helloros'
  108. -- ==> add_subdirectory(helloros)
  109. -- Configuring done
  110. -- Generating done
  111. -- Build files have been written to: /home/shiyanlou/Code/helloros/build
  112. ####
  113. #### Running command: "make -j4 -l4" in "/home/shiyanlou/Code/helloros/build"
  114. ####
  115. Scanning dependencies of target helloros_node
  116. [ 50%] Building CXX object helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o
  117. /home/shiyanlou/Code/helloros/src/helloros/src/helloros.cpp: In function \u2018int main(int, char**)\u2019:
  118. /home/shiyanlou/Code/helloros/src/helloros/src/helloros.cpp:7:2: error: \u2018NodeHandlenh\u2019 is not a member of \u2018ros\u2019
  119. ros::NodeHandlenh;
  120. ^
  121. helloros/CMakeFiles/helloros_node.dir/build.make:62: recipe for target 'helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o' failed
  122. make[2]: *** [helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o] Error 1
  123. CMakeFiles/Makefile2:907: recipe for target 'helloros/CMakeFiles/helloros_node.dir/all' failed
  124. make[1]: *** [helloros/CMakeFiles/helloros_node.dir/all] Error 2
  125. Makefile:138: recipe for target 'all' failed
  126. make: *** [all] Error 2
  127. Invoking "make -j4 -l4" failed
  128. shiyanlou:helloros/ $ catkin_make [9:48:42]
  129. Base path: /home/shiyanlou/Code/helloros
  130. Source space: /home/shiyanlou/Code/helloros/src
  131. Build space: /home/shiyanlou/Code/helloros/build
  132. Devel space: /home/shiyanlou/Code/helloros/devel
  133. Install space: /home/shiyanlou/Code/helloros/install
  134. ####
  135. #### Running command: "make cmake_check_build_system" in "/home/shiyanlou/Code/helloros/build"
  136. ####
  137. ####
  138. #### Running command: "make -j4 -l4" in "/home/shiyanlou/Code/helloros/build"
  139. ####
  140. Scanning dependencies of target helloros_node
  141. [ 50%] Building CXX object helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o
  142. [100%] Linking CXX executable /home/shiyanlou/Code/helloros/devel/lib/helloros/helloros_node
  143. [100%] Built target helloros_node
  144. shiyanlou:helloros/ $ source devel/setup.zsh [9:49:29]
  145. shiyanlou:helloros/ $ rosrun helloros helloros_node [9:49:50]
  146. terminate called after throwing an instance of 'ros::InvalidNameException'
  147. what(): Character [ ] is not valid as the first character in Graph Resource Name [ hello_ros ]. Valid characters are a-z, A-Z, / and in some cases ~.
  148. [1] 2109 abort (core dumped) rosrun helloros helloros_node
  149. shiyanlou:helloros/ $ rosrun helloros helloros_node [9:50:11]
  150. terminate called after throwing an instance of 'ros::InvalidNameException'
  151. what(): Character [ ] is not valid as the first character in Graph Resource Name [ hello_ros ]. Valid characters are a-z, A-Z, / and in some cases ~.
  152. [1] 2121 abort (core dumped) rosrun helloros helloros_node
  153. shiyanlou:helloros/ $ catkin_make [9:50:27]
  154. Base path: /home/shiyanlou/Code/helloros
  155. Source space: /home/shiyanlou/Code/helloros/src
  156. Build space: /home/shiyanlou/Code/helloros/build
  157. Devel space: /home/shiyanlou/Code/helloros/devel
  158. Install space: /home/shiyanlou/Code/helloros/install
  159. ####
  160. #### Running command: "make cmake_check_build_system" in "/home/shiyanlou/Code/helloros/build"
  161. ####
  162. ####
  163. #### Running command: "make -j4 -l4" in "/home/shiyanlou/Code/helloros/build"
  164. ####
  165. Scanning dependencies of target helloros_node
  166. [ 50%] Building CXX object helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o
  167. [100%] Linking CXX executable /home/shiyanlou/Code/helloros/devel/lib/helloros/helloros_node
  168. [100%] Built target helloros_node
  169. shiyanlou:helloros/ $ source devel/setup.zsh [9:51:22]
  170. shiyanlou:helloros/ $ rosrun helloros helloros_node [9:51:33]
  171. [ INFO] [1648173097.607466664]: Hello, ROS!
  172. shiyanlou:helloros/ $ catkin_make [9:51:37]
  173. Base path: /home/shiyanlou/Code/helloros
  174. Source space: /home/shiyanlou/Code/helloros/src
  175. Build space: /home/shiyanlou/Code/helloros/build
  176. Devel space: /home/shiyanlou/Code/helloros/devel
  177. Install space: /home/shiyanlou/Code/helloros/install
  178. ####
  179. #### Running command: "make cmake_check_build_system" in "/home/shiyanlou/Code/helloros/build"
  180. ####
  181. ####
  182. #### Running command: "make -j4 -l4" in "/home/shiyanlou/Code/helloros/build"
  183. ####
  184. Scanning dependencies of target helloros_node
  185. [ 50%] Building CXX object helloros/CMakeFiles/helloros_node.dir/src/helloros.cpp.o
  186. [100%] Linking CXX executable /home/shiyanlou/Code/helloros/devel/lib/helloros/helloros_node
  187. [100%] Built target helloros_node
  188. shiyanlou:helloros/ $ rosrun helloros helloros_node [9:52:34]
  189. [ INFO] [1648173164.205589203]: Hello nihao, ROS!
  190. shiyanlou:helloros/ $ [9:52:44]
  1. shiyanlou:~/ $ history [11:37:17]
  2. 1 git clone https://gitcode.net/ZhangRelay/v-rep_pro_edu_v3_6_2_ubuntu16_04.git
  3. 2 tar
  4. 3 tar --help
  5. 4 tar --usage
  6. 5 tar -xf v-rep_pro_edu_v3_6_2_ubuntu16_04/V-REP_PRO_EDU_V3_6_2_Ubuntu16_04.tar.xz
  7. 6 cd V-REP_PRO_EDU_V3_6_2_Ubuntu16_04
  8. 7 ls
  9. 8 gedit vrep.sh
  10. 9 vrep.sh
  11. 10 ./vrep.sh
  12. 11 roscore
  13. 12 rosrun turtlesim turtlesim_node
  14. 13 rosrun turtlesim turtle_teleop_key
  15. 14 rosrun turtlesim turtlesim_node
  16. 15 rospack list
  17. 16 catkin_create_pkg
  18. 17 catkin_create_pkg -h
  19. 18 catkin_create_pkg helloros
  20. 19 catkin_create_pkg -h
  21. 20 catkin_create_pkg helloros roscpp
  22. 21 cd helloros/src
  23. 22 ls
  24. 23 gedit helloros.cpp
  25. 24 ls
  26. 25 cd ..
  27. 26 l
  28. 27 cd ..
  29. 28 catkin_make
  30. 29 source devel/setup.zsh
  31. 30 roscore
  32. 31 rosrun helloros helloros_node
  33. 32 catkin_make
  34. 33 source devel/setup.zsh
  35. 34 rosrun helloros helloros_node
  36. 35 catkin_make
  37. 36 rosrun helloros helloros_node
  38. shiyanlou:~/ $ [11:37:20]
原文链接:zhangrelay.blog.csdn.net/article/details/123731254
