使用OBSFilesystem多线程删除目录
南瓜星人 发表于 2022/03/25 15:02:56 2022/03/25
【摘要】 1. 多线程删除示例代码package org.example;import org.apache.hadoop.conf.Configuration;import org.apache.hadoop.fs.FileStatus;import org.apache.hadoop.fs.FileSystem;import org.apache.hadoop.fs.Path;import jav...
1. 多线程删除示例代码
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import java.util.concurrent.ExecutionException;
import java.util.concurrent.Future;
import java.util.concurrent.LinkedBlockingQueue;
import java.util.concurrent.ThreadPoolExecutor;
import java.util.concurrent.TimeUnit;
public class MultiThreadDelete {
    public static void main(String[] args) throws IOException, ExecutionException, InterruptedException {
        String ak = args[0];
        String sk = args[1];
        String endpoint = args[2];
        String p = args[3];
        int threadNum = Integer.parseInt(args[4]);
        // get filesystem
        Configuration conf = new Configuration();
        conf.set("fs.obs.impl", "org.apache.hadoop.fs.obs.OBSFileSystem");
        conf.set("fs.obs.access.key", ak);
        conf.set("fs.obs.secret.key", sk);
        conf.set("fs.obs.endpoint", endpoint);
        conf.setBoolean("fs.obs.trash.enable", false);
        Path path = new Path(p);
        FileSystem fs = path.getFileSystem(conf);
        FileStatus[] fileStatuses = fs.listStatus(path);
        // get thread pool
        ThreadPoolExecutor deleteThreadPool = new ThreadPoolExecutor(threadNum, threadNum,
            1000, TimeUnit.SECONDS, new LinkedBlockingQueue<>(10000));
        // 并发删除
        List<Future<?>> futures = new ArrayList<>();
        for (FileStatus fileStatus : fileStatuses) {
            Path deletePath = fileStatus.getPath();
            futures.add(deleteThreadPool.submit(() -> {
                try {
                    if (!fs.delete(deletePath, true)) {
                        System.out.printf("delete [%s] failed!\n", deletePath);
                } catch (IOException e) {
                    System.out.printf("delete [%s] failed! cause by %s\n", deletePath, e);
        for (Future<?> f : futures) {
            f.get();
        deleteThreadPool.shutdown();
        if (!fs.delete(path, true)) {
            System.out.printf("delete base [%s] failed!\n", path);
2. POM依赖
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <parent>
        <artifactId>obs-test</artifactId>
        <groupId>org.example</groupId>
        <version>1.0-SNAPSHOT</version>
    </parent>
    <modelVersion>4.0.0</modelVersion>
    <artifactId>multithread-delete</artifactId>
    <properties>
        <maven.compiler.source>8</maven.compiler.source>
        <maven.compiler.target>8</maven.compiler.target>
    </properties>
    <dependencies>
        <dependency>
            <groupId>com.huaweicloud</groupId>
            <artifactId>hadoop-huaweicloud</artifactId>
            <version>2.8.3-hw-46</version>
        </dependency>
        <dependency>
            <groupId>org.apache.hadoop</groupId>
            <artifactId>hadoop-common</artifactId>
            <version>2.8.3</version>
        </dependency>
    </dependencies>
</project>
3. 操作步骤
  1. 将以上示例打包为jar包
  2. 使用java命令运行:java -cp XXX.jar:hadoop-common-XXX.jar:hadoop-huaweicloud-XXX.jar org.example.MultiThreadDelete <ak> <sk> <endpoint> <delete-path: example obs://xxx/xxx> <threadNum>
注意:
  1. classpath需要有:1). 第一步编译出的jar包,2). hadoop-common jar包,3). obsa jar包。
  2. delete-path为需要删除的目录(该目录也会被删除)
  3. threadNum为启动${threadNum}个线程并发的删除${delete-path}下的子目录。
